nRF52840 bonded devices
Good morning,
I have my BLE application developed on the nRF52840 and S140.
My application is perfectly working and I'm able to bond (pin required) any Android smartphone.
At this point I have two questions:
1.- Is there any limit regarding the number of smartphones I can bond to a device? If yes, how can I manage this?
2.- When doing same operation with an Apple device, Smartphone is never asking for a pin code. Why? Is there any different setting for this?
Dani.
  • In general you may find documentation useful:
    https://infocenter.nordicsemi.com/topic/sdk_nrf5_v17.0.2/group__peer__manager.html
    There is no specific limit to the number of bonds that the peer manager can handle. So typically you can call pm_peer_count(), use pm_next_peer_id_get() to for instance call pm_peer_delete() if you exceed the number of bonds you want to support.
    For instance to loop through stored bonds you can call the following in a while()-loop:
    pm_peer_id_t peer_id;
    peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
    while ((peer_id != PM_PEER_ID_INVALID))
        // You can delete the bond if you like by calling pm_peer_delete(peer_id)
        peer_id = pm_next_peer_id_get(peer_id);
    Typically you can include pm_handler_flash_clean() in pm_evt_handler(), such that if flash storage is full, it will delete the oldest bond that have not been used.
    I do not understand why Apple does not display a pin code, are you sure you have configured characteristics which require MITM security level?
  • Hi Kenneth,
    Thank you for the bonding inputs. In what regards this: I'm already calling 'pm_handelr_flash_clean()' in pm_evt_handler. Should it be enough to be sure bonding space will not be full? Should I also call 'pm_handler_flash_clean_on_return' when NRF_ERROR_STORAGE_FULL event is given? And I guess, that using this fucntions, it is not necessary to call pm_peer_delete(), right?
    In what regards connection with Apple device: by using nRFConnect app, I'm able to read data that my device is sending without being asked for a passkey. If I want to send some data, then I'm asked for the passkey. But, as in Android, I should be asked for a passkey when connecting to device.
    In what regards services and characterisitics: for each service, I have one characteristic to send data (like button example) and another one to received data (like LED example).
    In what regards 'button example', when adding the characteristic:
    ble_gatts_char_md_t char_md;
    ble_gatts_attr_md_t cccd_md;
    ble_gatts_attr_t attr_char_value;
    ble_uuid_t ble_uuid;
    ble_gatts_attr_md_t attr_md;
    memset(&cccd_md, 0, sizeof(cccd_md));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
    //BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&cccd_md.write_perm);
    cccd_md.vloc = BLE_GATTS_VLOC_STACK;
    memset(&char_md, 0, sizeof(char_md));
    char_md.char_props.read = 1;
    char_md.char_props.notify = 1;
    char_md.p_char_user_desc = NULL;
    char_md.p_char_pf = NULL;
    char_md.p_user_desc_md = NULL;
    char_md.p_cccd_md = &cccd_md;
    char_md.p_sccd_md = NULL;
    ble_uuid.type = p_lbs->uuid_type;
    ble_uuid.uuid = FABRICA_UUID_TX_CHAR;
    memset(&attr_md, 0, sizeof(attr_md));
    BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&attr_md.write_perm);
    attr_md.vloc = BLE_GATTS_VLOC_STACK;
    attr_md.rd_auth = 0;
    attr_md.wr_auth = 0;
    attr_md.vlen = 0;
    memset(&attr_char_value, 0, sizeof(attr_char_value));
    attr_char_value.p_uuid = &ble_uuid;
    attr_char_value.p_attr_md = &attr_md;
    attr_char_value.init_len = sizeof(u8);
    attr_char_value.init_offs = 0;
    attr_char_value.max_len = BLE_TAMANY_FABRICA_RX_TX_CHAR;
    attr_char_value.p_value = NULL;
    return sd_ble_gatts_characteristic_add(p_lbs->service_handle, &char_md,
    &attr_char_value,
    &p_lbs->tx_char_handles);
    And in what regards 'LED example':
    u32 err_code;
    //Metadata Structure for the Characteristic, which has info about properties available (read, write, notification,...)
    char_md.char_props.write = 1;
    char_md.p_cccd_md = NULL;
    ble_uuid.type=p_lbs->uuid_type;
    ble_uuid.uuid=FABRICA_UUID_RX_CHAR;
    //attr_md: Description of the value attribute
    BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&attr_md.write_perm);
    attr_md.vlen = 0;
    err_code = sd_ble_gatts_characteristic_add(p_lbs->service_handle, &char_md,
    &attr_char_value,
    &p_lbs->rx_char_handles);
    if (err_code != NRF_SUCCESS)
    return err_code;
    return NRF_SUCCESS;
    This is perfectly working on Android. Which is the difference with Apple?
    Dani
  • Hi Kenneth,
    I've sniffer already working, but what information do you need to be catched?
    As I'm using a 8-digit passkey, I have entered this passkey into Wireshark passkey field. This is right?
    I'm deeping a bit more into this application, but meanwhile, if you can detail the information that is useful for you, it will be great!!!
    All the best,
    Dani.
    Here you have the sniffer trace in following situation:
    My device was advertising and using nRF Connect (ioS) I have been able to connect and receive some data. When I want to write into a characteristic, I'm prompted for the passkey: when entering it, it is always impossible and device disconnects... (This happens at item 3359 in trace and LL_TERMINATE_IND is received)
    Hope to solve this.IoS_pairing_problem.pcapng
  • 8-digit passkey? It should be 6 digit in BLE.
    Kenneth
  • I'll go back to 6 digit?
    Is this code internally used for authentication? Could the 8-digit passkey be the reason of my problem with Apple? (It works fine with Android...)
    Dani
  • In BLE it is not configurable (PASSKEY_LENGTH must be 6). So maybe Android discard the last 2-digits?
    case BLE_GAP_EVT_PASSKEY_DISPLAY:
        char passkey[PASSKEY_LENGTH + 1];
        memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, PASSKEY_LENGTH);
        passkey[PASSKEY_LENGTH] = 0;
        NRF_LOG_INFO("Passkey: %s", nrf_log_push(passkey));
    } break;
    Kenneth
    } break;
    Kenneth
