How to use external app firmware update
I would like to use external app firmware to update over BLE a secondary microncontroler behind a NRF52832. I read that it's an experimental feature but it's very intersting because this avoids to implement an other mecanism in mobile application to update the other MCU.
I already developped the DFU over BLE for application, bootloader and soft device. I now try to make work the external app update.
SDK 17.0.2, SoftDevice s112
The process I imagine :
  • Run the NRF52 in DFU mode
  • Upload the external firmware (in Bank 1 to preserve app in Bank 0)
  • Once done, run boot the secondary MCU by driving GPIO (nReset/Boot)
  • Send the firmware over UART
  • Restart in normal mode
I already created a zip package using nrfutil : nrfutil pkg generate --hw-version 52 --application-version-string 1.0.0 --application XYZ_Project.hex --external-app --key-file private.key XYZ_Project.zip
where XYZ_Project.hex is a STM32 hex file.
I succeed in downloading the zip file in the NRF52 and I check the internal memory of the MCU. Everythong looks good in Bank 1 ;)
Now, I want to push the Bank 1 data to the other MCU. Searhing the code, I saw I have to implement this method :
nrf_dfu_result_t nrf_dfu_validation_post_external_app_execute(dfu_init_command_t const * p_init, bool is_trusted)
However, it's never called; I ran the code in debbuger mode and saw this code section in postvalidate function nrf_dfu_validation.c but don't really understand how it works :
#if NRF_DFU_SUPPORTS_EXTERNAL_APP
        else if (p_init->type == DFU_FW_TYPE_EXTERNAL_APPLICATION)
            if (!is_trusted)
                // This function must be implemented externally
                ret_val = nrf_dfu_validation_post_external_app_execute(p_init, is_trusted);
                s_dfu_settings.bank_1.bank_code = NRF_DFU_BANK_VALID_EXT_APP;
#endif // NRF_DFU_SUPPORTS_EXTERNAL_APP
The method nrf_dfu_validation_post_external_app_execute is never executed (in debugger mode, I put a breakpoint on the function).
Help is welcome Smiley
    The nrf_dfu_validation_post_external_app_execute() that you implement is called if the update is for an external app, and that is enabled in the bootloader and the whole firmware is received and the command is NRF_DFU_OP_OBJECT_EXECUTE. Generally, what the external app feature gives you is a way to transfer the image to the nRF, and then call your nrf_dfu_validation_post_external_app_execute(). From then you are responsible for all the rest.
    Regarding the code snippet you refer to, NRF_DFU_SUPPORTS_EXTERNAL_APP is an sdk_config.h macro that must be enabled. The is_trusted parameter is used to signal if the function can make permanent changes on the nRF state (has been validated etc.). You can see how it is used in the various post_validate functions etc.
    I think to understand the issue here it would be good if you enable debug logging so that we can see what happens in the bootloader, and compare that with what you would expected to happen.
  • Hi Einar,
    thanks a lot for your support ;)
    I confirm I enabled all necessary macro on sdk_config.h
    I will try to produce some traces as soons as possible.
    Regards
    Sorry for the delay, I had some diffculties to compile with the debug logging options.
    For the next one, if the following error occurs :
    1> Linking diego_isp4520_bl.elf
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.10/gcc/arm-none-eabi/bin/ld: error: .rodata is too large to fit in FLASH memory segment
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.10/gcc/arm-none-eabi/bin/ld: error: .data is too large to fit in FLASH memory segment
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.10/gcc/arm-none-eabi/bin/ld: error: section .tdata overlaps absolute placed section .mbr_params_page
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.10/gcc/arm-none-eabi/bin/ld: Output/Release/Obj/diego_isp4520_bl/main.o: in function `main':
    1> C:\TRO\DevE\DIEGO\diego_isp4520_bl/main.c:154: undefined reference to `nrf_log_default_backends_init'
    Build failed
    It's necessary to modify the Section Placement Maccro to enlarge Flash Size
    I went from :
    FLASH_START=0x78000
    FLASH_SIZE=0x6000
    To :
    FLASH_START=0x72000
    FLASH_SIZE=0x12000
    This the log when I upload the external app (no application in Bank 0 so I think data goes to this bank) :
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025D58, src=0x20006620, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025D58, pending 1
    <debug> nrf_dfu_ble: Freeing buffer 0x20006620
    <debug> nrf_dfu_ble: Buffer 0x20006620 acquired, len 244 (244)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025E4C, src=0x20006620, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025E4C, pending 1
    <debug> nrf_dfu_ble: Buffer 0x20006620 acquired, len 192 (244)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025F40, src=0x20006620, len=192 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025F40, pending 1
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:53248, CRC:0x672E882D
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    <debug> app: timer_stop (0x20005984)
    <debug> app: timer_activate (0x20005984)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00026000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_req_handler: Creating object with size: 424. Offset: 0x0000D000, CRC: 0x672E882D
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00026000, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x20006620, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026000, pending 1
    <debug> nrf_dfu_ble: Buffer 0x20006620 acquired, len 180 (244)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000260F4, src=0x20006620, len=180 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000260F4, pending 1
    <debug> nrf_dfu_req_handler: Offset:53672, CRC:0x37073ED7
    <debug> nrf_dfu_req_handler: Whole firmware image received. Postvalidating.
    <debug> nrf_dfu_validation: Hash verification. start address: 0x19000, size: 0xD1A8
    <debug> nrf_dfu_settings: Writing settings...
    <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0E000.
    0x1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 4
    <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 3
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0007E000, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0007E000, pending 1
    <debug> nrf_dfu_req_handler: All flash operations have completed. DFU completed.
    <debug> app: Shutting down transports (found: 1)
    <debug> nrf_dfu_ble: Shutting down BLE transport.
    <debug> nrf<info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> nrf_dfu_settings: Using settings page.
    <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
    <debug> nrf_dfu_settings: Destination settings are identical to <info> app: Entering DFU mode.
    It seems that some messages are fragmented. I try to produce a better log in the afternoon.
    Thanks again.
    Thib
  • The full log :
    <warning> nrf_dfu_settings: Resetting bootloader settings since neither the settings page nor the backup are valid (CRC error).
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x2000787C, len=896 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_ble: Initializing BLE DFU transport
    <debug> nrf_dfu_ble: Setting up vector table: 0x00072000
    <debug> nrf_dfu_ble: Enabling SoftDevice.
    <debug> nrf_dfu_ble: Configuring BLE stack.
    <debug> nrf_dfu_ble: Enabling the BLE stack.
    <debug> nrf_dfu_ble: Advertising...
    <debug> nrf_dfu_ble: Connected
    <debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
    <debug> nrf_dfu_ble: max_conn_interval: 12
    <debug> nrf_dfu_ble: min_conn_interval: 12
    <debug> nrf_dfu_ble: slave_latency: 0
    <debug> nrf_dfu_ble: conn_sup_timeout: 600
    <debug> nrf_dfu_ble: Finished handling conn sec update
    <debug> nrf_dfu_ble: Set receipt notif
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
    <debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 247, reply: 247).
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    <debug> nrf_dfu_ble: Buffer 0x200067E0 acquired, len 143 (244)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
    <debug> nrf_dfu_ble: Freeing buffer 0x200067E0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    <debug> nrf_dfu_validation: PB: Init packet data len: 66
    <info> nrf_dfu_validation: Signature required. Checking signature.
    <info> nrf_dfu_validation: Calculating hash (len: 66)
    <info> nrf_dfu_validation: Verify signature
    <info> nrf_dfu_validation: Image verified
    <debug> app: Enter nrf_dfu_cache_prepare()
    <debug> app: required_size: 0xD1A8.
    <debug> app: single_bank: false.
    <debug> app: keep_app: true.
    <debug> app: keep_softdevice: true.
    <debug> app: SD_PRESENT: true.
    <debug> app: Bank contents:
    <debug> app: Bank 0 code: 0x00: Size: 0x0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (data)
    <debug> nrf_dfu_req_handler: crc = 0x0, offset = 0x0, max_size = 0x1000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00019000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00000000, CRC: 0x00000000
    <debug> nrf_dfu_ble: Buffer 0x200067E0 acquired, len 244 (244)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019000, src=0x200067E0, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00019000, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019000, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000190F4, src=0x200067E0, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000190F4, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000191E8, src=0x200067E0, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000191E8, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025E4C, src=0x200067E0, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_ble: Buffer 0x200067E0 acquired, len 192 (244)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025F40, src=0x200067E0, len=192 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x200067E0, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_ble: Buffer 0x200067E0 acquired, len 180 (244)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000260F4, src=0x200067E0, len=180 bytes), queue usage: 1
    <debug> nrf_df<info> app: Inside main
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <info> app: Boot validation failed. No valid app to boot.
    <debug> app: DFU mode because app is not valid.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: Enter main loop
    Thib
    It looks like this is correctly written to bank 1 as you write, and then the code is set to NRF_DFU_BANK_VALID_EXT_APP. Then the nrf_dfu_validation_post_external_app_execute() function is never called, and you normally don't need it. So now after successfully performing this operation you have the external app in flash (with bank 1 code indicating that). Then you can check that using nrf_dfu_validation_valid_external_app() and update your external MCU.
    Note that the external app code is not used much which is probably why it does not always make sense out of the box. You can see an example of external app in the Thread and ZigBee SDK (though I do not think it is very relevant, but it is the only example I am aware of).
