install and build asset tracker on Mac OS Catalina
OS: Mac OS Catalina
I installed build tools,nrf connect sdk, sesames, tool chain by following the instructions mentioned in "Getting started assistant" of nRF connect 3.6.0. I am using SDK 1.4.0
I start SES, Open nRF Connect SDK project and select 1.4.0 for SDK (and NONE (use SES settings/environment PATH for tool chain version given that's the only choice I am given)
Projects: asset_tracker
Board name: thingy91_nrf9160ns
Extra Cake build options: -DWEST=/Users/sshenoy105/Library/Python/3.8/bin/west
Clean build directory is checked..
and I get the following error: "create_nordic_project.py failed(1)
The SES console has the following:
Kconfig header saved to '/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 8.3.1
-- The CXX compiler identification is GNU 8.3.1
-- Found assembler: /opt/gnuarmemb/bin/arm-none-eabi-gcc
See also "/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/CMakeFiles/CMakeOutput.log".
See also "/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/CMakeFiles/CMakeError.log".
Including boilerplate (Zephyr base): /Users/sshenoy105/Documents/code/ncs/zephyr/cmake/app/boilerplate.cmake
thingy91_nrf9160ns.dts.pre.tmp:357.32-361.5: Warning (simple_bus_reg): /soc/cryptocell-sw: missing or empty reg/ranges property
thingy91_nrf9160ns.dts.pre.tmp:56.42-68.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
thingy91_nrf9160ns.dts.pre.tmp:305.19-311.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
CMake Error at /Users/sshenoy105/Documents/code/ncs/zephyr/cmake/extensions.cmake:1557 (message):
  Assertion failed: The toolchain is unable to build a dummy C file.  See
  CMakeError.log.
  /Users/sshenoy105/Documents/code/ncs/zephyr/CMakeLists.txt:42 (assert)
error: cmake failed
create_nordic_project.py failed (1)
CMakeError.log has the following:
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
Compiler: /opt/gnuarmemb/bin/arm-none-eabi-g++
Build flags:
Id flags:
The output was:
1
/opt/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/../../../../arm-none-eabi/bin/ld: /opt/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/../../../../arm-none-eabi/lib/libc.a(lib_a-exit.o): in function `exit':
exit.c:(.text.exit+0x2c): undefined reference to `_exit'
collect2: error: ld returned 1 exit status
I have already tried
  • Run xattr -r -d com.apple.quarantine /path/to/folder where path/to/folder is the path to the enclosing folder where the executables you want to run are located.
  • Open “System Preferences” -> “Security and Privacy” -> “Privacy” and then scroll down to “Developer Tools”. Then unlock the lock to be able to make changes and check the checkbox corresponding to your terminal emulator of choice. This will apply to any executable being launched from such terminal program.
I have been asked to "try" Tool chai manager but it has a not-so-encouraging note right at the top that says "experimental" and I am wondering if getting started can't get me going, will this experimental procesdue do any better..
any help, pointers, will be greatly appreciated
