install and build asset tracker on Mac OS Catalina
OS: Mac OS Catalina
I installed build tools,nrf connect sdk, sesames, tool chain by following the instructions mentioned in "Getting started assistant" of nRF connect 3.6.0. I am using SDK 1.4.0
I start SES, Open nRF Connect SDK project and select 1.4.0 for SDK (and NONE (use SES settings/environment PATH for tool chain version given that's the only choice I am given)
Projects: asset_tracker
Board name: thingy91_nrf9160ns
Extra Cake build options: -DWEST=/Users/sshenoy105/Library/Python/3.8/bin/west
Clean build directory is checked..
and I get the following error: "create_nordic_project.py failed(1)
The SES console has the following:
Kconfig header saved to '/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 8.3.1
-- The CXX compiler identification is GNU 8.3.1
-- Found assembler: /opt/gnuarmemb/bin/arm-none-eabi-gcc
See also "/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/CMakeFiles/CMakeOutput.log".
See also "/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/CMakeFiles/CMakeError.log".
Including boilerplate (Zephyr base): /Users/sshenoy105/Documents/code/ncs/zephyr/cmake/app/boilerplate.cmake
thingy91_nrf9160ns.dts.pre.tmp:357.32-361.5: Warning (simple_bus_reg): /soc/cryptocell-sw: missing or empty reg/ranges property
thingy91_nrf9160ns.dts.pre.tmp:56.42-68.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
thingy91_nrf9160ns.dts.pre.tmp:305.19-311.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
CMake Error at /Users/sshenoy105/Documents/code/ncs/zephyr/cmake/extensions.cmake:1557 (message):
  Assertion failed: The toolchain is unable to build a dummy C file.  See
  CMakeError.log.
  /Users/sshenoy105/Documents/code/ncs/zephyr/CMakeLists.txt:42 (assert)
error: cmake failed
create_nordic_project.py failed (1)
CMakeError.log has the following:
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
Compiler: /opt/gnuarmemb/bin/arm-none-eabi-g++
Build flags:
Id flags:
The output was:
1
/opt/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/../../../../arm-none-eabi/bin/ld: /opt/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/../../../../arm-none-eabi/lib/libc.a(lib_a-exit.o): in function `exit':
exit.c:(.text.exit+0x2c): undefined reference to `_exit'
collect2: error: ld returned 1 exit status
I have already tried
  • Run xattr -r -d com.apple.quarantine /path/to/folder where path/to/folder is the path to the enclosing folder where the executables you want to run are located.
  • Open “System Preferences” -> “Security and Privacy” -> “Privacy” and then scroll down to “Developer Tools”. Then unlock the lock to be able to make changes and check the checkbox corresponding to your terminal emulator of choice. This will apply to any executable being launched from such terminal program.
I have been asked to "try" Tool chai manager but it has a not-so-encouraging note right at the top that says "experimental" and I am wondering if getting started can't get me going, will this experimental procesdue do any better..
any help, pointers, will be greatly appreciated
  • Hmm. I think we have progress. Could ensure that you have the correct values for the "ZEPHYR_TOOLCHAIN_VARIANT" and "GNUARMEMB_TOOLCHAIN_PATH" environment variables? They are supposed to be the following if you followed the getting started guide:
    ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
    GNUARMEMB_TOOLCHAIN_PATH=/opt/gnuarmemb
    Try building on both command line and SES after these are set.
    Carl Richard
  • I still see nothing when I do echo $ZEPHYR_BASE.. should we fix that first ?
    I created a .zshrc and added
    export ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
    export GNUARMEMB_TOOLCHAIN_PATH=/opt/gnuarmemb
    and tried running SES again.. and here's what I see and it seems like I am back to square one
    Creating solution asset_tracker.emProject
    /usr/local/bin/cmake -GNinja -DBOARD=thingy91_nrf9160ns -DBOARD_DIR=/Users/sshenoy105/Documents/code/ncs/nrf/boards/arm/thingy91_nrf9160 -B/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns -S/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/opt/gnuarmemb -DPYTHON_EXECUTABLE=/usr/local/bin/python3 -DCMAKE_MAKE_PROGRAM=/usr/local/bin/ninja -DDTC=/usr/local/bin/dtc -DWEST=/Users/sshenoy105/Library/Python/3.8/bin/west -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=/Users/sshenoy105/Documents/arm_segger_embedded_studio_v510d_macos_x64_nordic/html/configure_nordic_project_menuconfig.py
    -- Application: /Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker
    -- Zephyr version: 2.4.0 (/Users/sshenoy105/Documents/code/ncs/zephyr)
    -- Found Python3: /usr/bin/python3 (found suitable exact version "3.8.2") found components: Interpreter
    -- Found west (found suitable version "0.8.0", minimum required is "0.7.1")
    -- Board: thingy91_nrf9160ns
    -- Cache files will be written to: /Users/sshenoy105/Library/Caches/zephyr
    -- Found dtc: /usr/local/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (/opt/gnuarmemb)
    -- Found BOARD.dts: /Users/sshenoy105/Documents/code/ncs/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160ns.dts
    -- Generated zephyr.dts: /Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/zephyr/include/generated/devicetree_unfixed.h
    Parsing /Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/Kconfig
    Loaded configuration '/Users/sshenoy105/Documents/code/ncs/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160ns_defconfig'
    Merged configuration '/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/prj_thingy91_nrf9160ns.conf'
    Configuration saved to '/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/zephyr/.config'
    -- Application: /Users/sshenoy105/Documents/code/ncs/nrf/samples/spm
    -- Found BOARD.dts: /Users/sshenoy105/Documents/code/ncs/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160.dts
    -- Generated zephyr.dts: /Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/spm/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/spm/zephyr/include/generated/devicetree_unfixed.h
    Parsing /Users/sshenoy105/Documents/code/ncs/zephyr/Kconfig
    Loaded configuration '/Users/sshenoy105/Documents/code/ncs/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_defconfig'
    Merged configuration '/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/spm.conf'
    Merged configuration '/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/spm/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to '/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/spm/zephyr/.config'
    Kconfig header saved to '/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/spm/zephyr/include/generated/autoconf.h'
    See also "/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build_thingy91_nrf9160ns/spm/CMakeFiles/CMakeOutput.log".
    Changed board to secure thingy91_nrf9160 (NOT NS)
    === child image spm -  begin ===
    CMake Error: CMake was unable to find a build program corresponding to "Ninja".  CMAKE_MAKE_PROGRAM is not set.  You probably need to select a different build tool.
    CMake Error at ../../cmake/multi_image.cmake:214 (message):
      CMake generation for spm failed, aborting.  Command: 1
      ../../cmake/multi_image.cmake:75 (add_child_image_from_source)
      ../../samples/CMakeLists.txt:22 (add_child_image)
    error: cmake failed
    _______________________________________________________________________
    Build flags:
    Id flags:
    The output was:
    1
    then I tried command line build
    sshenoy105@MacBook-Pro-4 ~ % ninja --version
    1.10.1
    sshenoy105@MacBook-Pro-4 ~ % echo $ZEPHYR_BASE
    sshenoy105@MacBook-Pro-4 ~ % cd Documents/code
    sshenoy105@MacBook-Pro-4 code % ls
    ncs
    sshenoy105@MacBook-Pro-4 code % cd ncs
    sshenoy105@MacBook-Pro-4 ncs % source zephyr/zephyr-env.sh
    sshenoy105@MacBook-Pro-4 ncs % cd nrf/applications/asset_tracker
    sshenoy105@MacBook-Pro-4 asset_tracker % west build -b thingy91_nrf9160ns -p
    -- west build: making build dir /Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build pristine
    -- Found Python3: /usr/local/bin/python3.9 (found suitable exact version "3.9.0") found components: Interpreter
    CMake Error at /Users/sshenoy105/Documents/code/ncs/zephyr/cmake/generic_toolchain.cmake:65 (include):
      include could not find load file:
        /Users/sshenoy105/Documents/code/ncs/zephyr/cmake/toolchain//generic.cmake
      /Users/sshenoy105/Documents/code/ncs/zephyr/cmake/app/boilerplate.cmake:589 (include)
      /Users/sshenoy105/Documents/code/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
      /Users/sshenoy105/Documents/code/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
      CMakeLists.txt:20 (find_package)
    CMake Error at /Users/sshenoy105/Documents/code/ncs/zephyr/cmake/dts.cmake:164 (message):
      command failed with return code: No such file or directory
      /Users/sshenoy105/Documents/code/ncs/zephyr/cmake/app/boilerplate.cmake:590 (include)
    FATAL ERROR: command exited with status 1: /usr/local/bin/cmake -DWEST_PYTHON=/usr/local/opt/[email protected]/bin/python3.9 -B/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker/build -S/Users/sshenoy105/Documents/code/ncs/nrf/applications/asset_tracker -GNinja -DBOARD=thingy91_nrf9160ns
  • Hi guys,
    I am experiencing the same problem, and am also on MacOS Catalina (10.15.7). I installed the SDK (nRF Connect 3.6.0. with SDK 1.4.0) via Toolchain Manager. I am able to open single image projects in the SES, e.g. for the nRF52480 but have no luck with multi_images, e.g. for the nRF9160.
    I should note that I have previously installed the SDK manually - developer.nordicsemi.com/.../gs_installing.html, and had no problems whatsoever.
    I have observed the same anomaly in earlier versions of nRF Connect and SDK - manual installation works fine, but had no success with the "Toolchain Manager" and "Getting Started Assistant" paths.
    I hope someone can help shed light so we can migrate away from the manual path.
    Ta.
  • Further discoveries:
    I am only able to get things working when I start SES from the terminal:
    /opt/nordic/ncs/v1.4.0/toolchain/segger_embedded_studio/SEGGER\ Embedded\ Studio.app/Contents/MacOS/emStudio
    and configure ninja under Tools > Options > nRF Connect to the instance I installed using brew:
    brew install ninja
    I tried the ninja instance that comes bundled with the SDK, but encountered the anomalies all over again. My hypothesis therefore is that something's probably amiss with the bundled ninja. It also appears that starting SES from the Toolchain Manager (as opposed to the terminal) 'forces' the bundled tools into play, so will result in anomalies resurfacing. However, I cannot dismiss the possibility that the fault could be rooted in my setup.
  • Hi again, sshenoy. My apologies, I should have mentioned this: ZEPHYR_BASE should be set by the "source <ncs_root>/zephyr/zephyr-env.sh" script, but it seems like this is not happening. Could you try to do the following:
    - set ZEPHYR_BASE to <path_to_ncs_root>/zephyr
    - Add <path_to_ncs_root>/zephyr/scripts to the PATH environment variable
    Carl Richard
