Unable to configure Port 1 as input.
Dear Team,
Greetings,
I am facing a problem for configuring Port 1 as input. I have connected a push button on P1.4 and an led on P0.0. I want to perform a simple task, i.e. when I press button then LED must turn on, else LED must be off. I have used NRF24LE1, 32 pin package.
#include "reg24le1.h"
void main()
	P0DIR = 0x00;  // set PORT0 as output
	P1DIR = 0xff;  // set PORT1 as input
	while(1)  // infinite loop
		if (P1 == 0x10)     // check P1.4 is high
			P0 = 0x01;
			P0 = 0x00;
Parents Reply
    Is the nRF24LE1 device in "flash mode" (PROG pin high), or something like this (see chapter 6.3.5 in the nRF24LE1 ps for the pins the FSPI uses) ? Is your programmer properly disconnected, and the nRF power cycled after you test this?
    I haven't used that programmer, so I do not have any knowledge on how it works. Do you have a nRFGo motherboard available to program with to see if the behavior is the same here?
    Nitesh Dubey said:
    then only P1.0 and P0.4-P0.7
     Do you mean P1.4-P1.7? Note that the nRF24LE1 QFN32 doesn't have P1.7 (it goes up to P1.6)
    Håkon
