Hello, this is the person who asked about "devzone.nordicsemi.com/.../question-serial-output-uart". First of all, thank you very much for your sincere reply.
The reason why I want to use 2 UARTs is because I want to see the 'Data' which is received by connecting 2 boards to UART communication and 1 board to PC.
Now that the two boards and the PC (UART) communication have been resolved, I am inquiring about what I am trying to do with this method.
Please look at the picture below.
Used three boards (nrf52840) as shown in the figure above. (End Device, Coordinator (zb_cli_agent),Serial_UARTE)
And each one.
We used zigbee_right(zr), zigbee_cli_agent(cli), and serial_uartes(su) sdk.
'zr' and 'cli' are.
I connected by looking at
and
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_tz_v4.1.0%2Fzigbee_example_cli_agent.html
and I saw that the value was coming in.
And I wanted to communicate UART with Cli and su, so I porting the UART definitions and functions in su.
But, if serial is initialed, command window does not appear.
ret_code_t ret;
zb_ieee_addr_t ieee_addr;
/* UART */
int i;
char ReadData[100];
/* END UART */
/* Intiialise the leds */
bsp_board_leds_off();
/* Initialize loging system and GPIOs. */
nrf_drv_power_init(NULL);
log_init();
#if defined(APP_USBD_ENABLED) && APP_USBD_ENABLED
ret = nrf_drv_clock_init();
APP_ERROR_CHECK(ret);
ret = app_timer_init();
/* UART */ // Serial_init
ret = nrf_serial_init(&serial0_uarte, &m_uarte0_drv_config, &serial0_config);
ret = nrf_serial_init(&serial1_uarte, &m_uarte1_drv_config, &serial1_config);
/* END UART */
/* Initialize the Zigbee CLI subsystem */
zb_cli_init(ZIGBEE_CLI_ENDPOINT);
/* Set Zigbee stack logging level and traffic dump subsystem. */
ZB_SET_TRACE_LEVEL(ZIGBEE_TRACE_LEVEL);
ZB_SET_TRACE_MASK(ZIGBEE_TRACE_MASK);
ZB_SET_TRAF_DUMP_OFF();
/* Initialize Zigbee stack. */
ZB_INIT("cli_agent_router");
/* Set device address to the value read from FICR registers. */
zb_osif_get_ieee_eui64(ieee_addr);
zb_set_long_address(ieee_addr);
zb_set_bdb_primary_channel_set(IEEE_CHANNEL_MASK);
zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG);
/* Register CLI Agent device context (endpoints). */
ZB_AF_REGISTER_DEVICE_CTX(&cli_agent_ctx);
/* Set the endpoint receive hook */
ZB_AF_SET_ENDPOINT_HANDLER(ZIGBEE_CLI_ENDPOINT, cli_agent_ep_handler);
/* Start Zigbee CLI subsystem. */
zb_cli_start();
Can I use zigbee and UART at the same time?
If so, I would appreciate it if you could tell me how.
And can the Coordinator receive a message like "Hello Nordic zigbee" from the End Device without zb_light as shown in the figure above?
Thank you for reading the long article.
