ADE7953 communication problem?
I tried to play with nrf52840 and ade7953 .
At the begining, I use PC uart application to do the following test and everything works well.
Here are the testing steps:
1. Send 0x35 0x01 0x02 to ADE7953 and the application gets response value 0x8004 correctly.
2. Try the power-up procedure by writing 0xAD to Register Address 0xFE and writing 0x30 to Register Address 0x120 with commands:
0xCA 0x00 0xFE 0xAD 0x00
0xCA 0x01 0x20 0x30 0x00
3. Send 0x35 0x01 0x20 and get 0x30 0x00.
The test looked good, but when I tried to connect Nordic nrf52840 and ADE7953 by uart with the same tests,
the step 3 failed. I Send 0x35 0x01 0x20 and get 0x00. I connect nrf52840DK and ADE7953 by UART with pins 0.08(RX) and 0.06 (TX).
Can anyone help? Here are my test code
void meter_init() {
  static uint8_t dataArray[6] = {0xCA, 0x00, 0xFE, 0xAD, 0x00, 0x00};
  ret_code_t err_code;
  // Write 0xAD to Register Address 0xFE:This unlocks Register 0x120
  for (uint32_t i = 0; i < 5; i++) {
    do {
      err_code = app_uart_put(dataArray[i]);
      if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY)) {
        NRF_LOG_ERROR("Failed sync to apm. Error 0x%x. ", err_code);
    } while (err_code == NRF_ERROR_BUSY);
  nrf_delay_ms(10);
  // Write 0x30 to Register Address 0x120: This configures the optimum settings
  dataArray[0] = 0xCA;
  dataArray[1] = 0x01;
  dataArray[2] = 0x20;
  dataArray[3] = 0x30;
  dataArray[4] = 0x00;
    do {
  nrf_delay_ms(10);
  • Hi
    Are you using an nRF52840 DK or a custom board? If you're using the DK, keep in mind that P0.06 and P0.08 are routed directly to the interface MCU. The UART pins connected to the interface MCU are tri-stated when no terminal i connected to the virtual COM port on the computer. Also, what UART instance are you using for this communication? Are you sure that P0.06 and P0.08 are configured as the UART pins correctly in your project?
    Simon
  • I tried to use both nRF52840 DK and a custom board, and the situation is the same. I tried to add more delays about 1.5 seconds between commands, and it works. Maybe I did something wrong in configuring UART.
    static void uart_init(void) {
      uint32_t err_code;
        .rx_pin_no = RX_PIN_NUMBER,
        .tx_pin_no = TX_PIN_NUMBER,
        .rts_pin_no = RTS_PIN_NUMBER,
        .cts_pin_no = CTS_PIN_NUMBER,
        .use_parity = false,
    #if defined(UART_PRESENT)
        .baud_rate = NRF_UART_BAUDRATE_4800
    #else
        .baud_rate = NRF_UARTE_BAUDRATE_115200
          UART_RX_BUF_SIZE,
          UART_TX_BUF_SIZE,
          uart_event_handle,
          APP_IRQ_PRIORITY_LOWEST,
          err_code);
      // setup uart to 2 stop bits
      NRF_UARTE0->CONFIG = UART_CONFIG_STOP_Two << UART_CONFIG_STOP_Pos;
    nordicxup
  • Hi
    You can try to set both baud rates to 4800, seeing as the ADE7953 operates at a fixed baud rate, and won't handle any others very well (I'd imagine). Other than that, I don't see any issues with your UART init function. Are you able to narrow down what exact delay(s) are making or breaking the application? Do you see the same issue if you try to use the nRF devices to communicate with one another at a baud rate of 4800 for example?
     What do you mean by that the test looked good. Were you able to make the ADE7953 communicate and run this test as intended with any other devices?
    Simon
  • The default baud rates of ADE7953 is 4800. I think my UART init function of nRF52840 is correct because the ble application sends 0x35 0x01 0x02 to ADE7953 and gets response value 0x8004 correctly.
    In the ADE7953 power-up procedure, I have to unlock and set register 0x01 and 0x20 with value 0x0030. The ADE7953 datasheet indicates that there should be at least 6 ms delay between commands. So I send 2 commands sequentially with 10 ms delay. Here are the commands
    Then send 0x35 0x01 0x20 to read register. If ADE7953 correctly recognizes the commands, it should return 0x30 0x00, but I always get 0x00 0x00.
    I try to add more delay to 1.5 seconds between the commands, and then send 0x35 0x01 0x20 command, I get 0x30 0x00 correctly.
    I do not know why this happened, but it works.
    nordicxup
  • "If there was a framing error (wrong stop bit), that specific byte will NOT be stored into Data RAM, but following incoming bytes will."
    Worth enabling or placing a break at the framing error case in the handler, as such an error (for whatever reason) will give the issue you observe. In passing in any case note that setting 2 stop bits via the hardware register (as in the code you posted) bypasses any Nordic driver knowledge of the setting; better (assuming it is an option) to use app_uart_comms_param_t as you do for the other settings. In general only use low-level hardware register or Nordic drivers; never mix the two without risking invoking puzzling side effects.
