I'm using mqtt_simple example based application to send BLE tracking data through LTE on custom boards. UART is used for connection between MCUs. Power is ON constantly and the environment devices are used in has zones with no LTE coverage. Most of devices work fine and reconnect and restore functioning after errors and absence of LTE signal. But on several boards I get a strange error. Code execution sometimes does not return from data_publish() function to main() and transmission does not restore. As I found doing debugging it's actually function mqtt_client_tcp_write_msg the one that does not return.
After this error ISR handler for UART keeps being called but LTE transmission doesn't happen because program execution doesn't return to main().
So two questions:
1) How can I do workaround for described error with "not returning to main()"? We had some problems with HW (soldering problem) and maybe this issues are connected but anyway I hope some SW workaround is possible.
2) I'm thinking about doing reconnection mechanism better (in power consumption terms). Check for registration in network and (maybe) check for quality of signal (AT+CESQ) before trying to client_init() with some period ~ seconds. Does it make sence? Or maybe there is another way to do it better?
Any help highly appreciated
Here is my main() code with cleaned some debugging garbage
void main(void)
uart_init();
uart_irq_callback_set(uart1, uart_cb);
uart_irq_rx_enable(uart1);
int err;
printk("The MQTT simple sample started\n");
modem_configure();
while(1)
printk("client_init\n");
client_init(&client);
printk("mqtt_connect\n");
err = mqtt_connect(&client);
if (err != 0) {
printk("ERROR: mqtt_connect %d\n", err);
continue;
err = fds_init(&client);
if (err != 0) {
printk("ERROR: fds_init %d\n", err);
err = mqtt_disconnect(&client);
if (err) {
printk("Could not disconnect MQTT client. Error: %d\n", err);
cntr_reconnect++;
continue;
while (1) {
err = poll(&fds, 1, 1);
if (err < 0) {
printk("ERROR: poll %d\n", errno);
f_break_reason = 1;
if (mqtt_keepalive_time_left(&client) < 10)
err = mqtt_live(&client);
if ((err != 0) && (err != -EAGAIN)) {
printk("ERROR: mqtt_live %d\n", err);
f_break_reason = 2;
if ((fds.revents & POLLIN) == POLLIN) {
err = mqtt_input(&client);
if (err != 0) {
printk("ERROR: mqtt_input %d\n", err);
f_break_reason = 3;
if (fPostDataReady && connected){
formPostData (&track_data, &post_data);
packID++;
err = data_publish(&client, MQTT_QOS_0_AT_MOST_ONCE/*MQTT_QOS_2_EXACTLY_ONCEMQTT_QOS_1_AT_LEAST_ONCE*/, post_data, strlen(post_data));
if (err != 0) {
printk("ERROR: data_publish %d\n", err);
f_break_reason = 4;
fPostDataReady = 0;
if ((fds.revents & POLLERR) == POLLERR) {
printk("POLLERR\n");
f_break_reason = 5;
if ((fds.revents & POLLNVAL) == POLLNVAL) {
printk("POLLNVAL\n");
f_break_reason = 6;
if ((fds.revents & POLLHUP) == POLLHUP) {
printk("Socket error: POLLHUP\n");
f_break_reason = 7;
printk("Disconnecting MQTT client...\n");
if (err) {
cntr_reconnect++;
