I am searching for a clean way to handle a timeout (because I2c device does not respond or there is a hw issue with the I2c bus).
On startup I probe different I2c sensors. I am using the nrfx_twi driver. When I use the nrfx_twi_tx function in blocking mode, I get NRFX_ERROR_INTERNAL, because a timeout has occurred within the twi_tx_start_transfer() function. And the busy-flag contained in the twi_control_block gets cleared on exit of the nrfx_twi_xfer() function, so next time I call the nrfx_twi_tx function to probe the next sensor, all is well. But If I want to use the driver in non-blocking mode, I get a problem. There is no timeout in this case, and I have to provide that by myself. But I don't see a good, clean way to stop the ongoing transmission after my code detects a timeout. First I tried to call nrfx_twi_disable() and nrfx_twi_enable() again, which seems to stop the transmission, but the problem is, that the busy flag does not get cleared. So the next call to nrfx_twi_tx() fails with NRFX_ERROR_BUSY. The only way around this seems to be to call nrfx_twi_uninit() and nrfx_twi_init(), which includes de-initialization and initialization of the gpio pins, which I don't want here.
My question is, if there is a better way to abort a transfer when using non-blocking mode?
Regards
Dirk
