I am building a custom boot loader to work with out application on a custom board based on the UBLOX NINA-302 module. The boot loader will use USB as the only connection and that will use a USB driver we already developed for the application. The idea is to use a simple boot loader without a soft device or MBR that will interface directly to our host application over USB. The boot loader will start at 0x0 (FLASH_START=0x0) and a length of 0x10000 (FLASH_SIZE=0x10000). The application is built in SES with FLASH_START set to offset address (0x10000) and FLASH_SIZE set to 0x20000. The application was loaded into flash using J-Link before starting up the boot loader solution.
I am launching the application using the same funcitons that the Nordic boot loader wit some modifications specific to the implementation (files included below). I have tried this with the standard "start_app' with optimization and also by replacing the function with an updated version I found on the developer blog. The application seems to be starting up since I can track it using breakpoints up to "start_app" and then single set through the application code after the jump to the new reset handler. I can single step through code but hit a hard fault whenever I let it free run. The application has been stripped down to just blinky code with no interrupt service. I even stripped the boot loader down to just the launch code but the application still crashes. Any ideas?
* Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdint.h>
#include "nrf.h"
#include "nrf_bootloader_app_start.h"
//#include "nrf_bootloader_info.h"
#include "nrf_log.h"
//#include "nrf_dfu_mbr.h"
#include "nrf_log_ctrl.h"
#include "g4_global_defs.h"
// Do the final stages of app_start. Protect flash and run app. See nrf_bootloader_app_start_final.c
void nrf_bootloader_app_start_final(uint32_t start_addr);
void nrf_bootloader_app_start(void)
// uint32_t start_addr = MBR_SIZE; // Always boot from end of MBR. If a SoftDevice is present, it will boot the app.
uint32_t start_addr = (uint32_t)FLASH_START_APP;
NRF_LOG_DEBUG("Running nrf_bootloader_app_start with address: 0x%08x", start_addr);
uint32_t err_code;
// Disable and clear interrupts
// Notice that this disables only 'external' interrupts (positive IRQn).
NRF_LOG_DEBUG("Disabling interrupts. NVIC->ICER[0]: 0x%x", NVIC->ICER[0]);
NVIC->ICER[0]=0xFFFFFFFF;
NVIC->ICPR[0]=0xFFFFFFFF;
#if defined(__NRF_NVIC_ISER_COUNT) && __NRF_NVIC_ISER_COUNT == 2
NVIC->ICER[1]=0xFFFFFFFF;
NVIC->ICPR[1]=0xFFFFFFFF;
/* not using DFU for G4
err_code = nrf_dfu_mbr_irq_forward_address_set();
if (err_code != NRF_SUCCESS)
NRF_LOG_ERROR("Failed running nrf_dfu_mbr_irq_forward_address_set()");
NRF_LOG_FLUSH();
nrf_bootloader_app_start_final(start_addr);
#include "sdk_config.h"
#include <stdint.h>
#include "nrf.h"
#include "nrf_peripherals.h"
//#include "nrf_dfu_types.h"
//#include "nrf_dfu_utils.h"
//#include "nrf_dfu_settings.h"
#include "nrf_assert.h"
// Enabling the NRF_BOOTLOADER_READ_PROTECT define is untested.
// Read-protecting the bootloader requires certain functions to run from RAM.
// In GCC and SES this is done automatically when the define is enabled. You will
// get warnings which can be ignored.
// In Keil you must change project settings to run the entire file from RAM.
#ifndef NRF_BOOTLOADER_READ_PROTECT
#define NRF_BOOTLOADER_READ_PROTECT 0
#define HANDLER_MODE_EXIT 0xFFFFFFF9 // When this is jumped to, the CPU will exit interrupt context
// (handler mode), and pop values from the stack into registers.
// See ARM's documentation for "Exception entry and return".
#define EXCEPTION_STACK_WORD_COUNT 8 // The number of words popped from the stack when
// HANDLER_MODE_EXIT is branched to.
/**@brief Function that sets the stack pointer and link register, and starts executing a particular address.
* @param[in] new_msp The new value to set in the main stack pointer.
* @param[in] new_lr The new value to set in the link register.
* @param[in] addr The address to execute.
#if defined ( __CC_ARM )
__ASM __STATIC_INLINE void jump_to_addr(uint32_t new_msp, uint32_t new_lr, uint32_t addr)
MSR MSP, R0;
MOV LR, R1;
BX R2;
#else
__ASM volatile ("MSR MSP, %[arg]" : : [arg] "r" (new_msp));
__ASM volatile ("MOV LR, %[arg]" : : [arg] "r" (new_lr) : "lr");
__ASM volatile ("BX %[arg]" : : [arg] "r" (addr));
//replacement to avoid optimization bug with above version
__set_MSP(new_msp);
((void (*)(void))addr)();
/**@brief Function for booting an app as if the chip was reset.
* @param[in] vector_table_addr The address of the app's vector table.
__STATIC_INLINE void app_start(uint32_t vector_table_addr)
const uint32_t current_isr_num = (__get_IPSR() & IPSR_ISR_Msk);
const uint32_t new_msp = *((uint32_t *)(vector_table_addr)); // The app's Stack Pointer is found as the first word of the vector table.
const uint32_t reset_handler = *((uint32_t *)(vector_table_addr + sizeof(uint32_t))); // The app's Reset Handler is found as the second word of the vector table.
const uint32_t new_lr = 0xFFFFFFFF;
__set_CONTROL(0x00000000); // Set CONTROL to its reset value 0.
__set_PRIMASK(0x00000000); // Set PRIMASK to its reset value 0.
__set_BASEPRI(0x00000000); // Set BASEPRI to its reset value 0.
__set_FAULTMASK(0x00000000); // Set FAULTMASK to its reset value 0.
ASSERT(current_isr_num == 0); // If this is triggered, the CPU is currently in an interrupt.
// The CPU is in Thread mode (main context).
jump_to_addr(new_msp, new_lr, reset_handler); // Jump directly to the App's Reset Handler.
#if NRF_BOOTLOADER_READ_PROTECT
#ifdef __ICCARM__
__ramfunc
#elif defined ( __GNUC__ ) || defined ( __SES_ARM )
__attribute__((noinline, long_call, section(".data")))
#elif defined ( __CC_ARM )
#warning "Keil requires changes to project settings to run this file from RAM. Ignore this warning if configuration has been made."
ret_code_t nrf_bootloader_flash_protect(uint32_t address, uint32_t size, bool read_protect)
if ((size & (CODE_PAGE_SIZE - 1)) || (address > BOOTLOADER_SETTINGS_ADDRESS))
return NRF_ERROR_INVALID_PARAM;
#if defined(ACL_PRESENT)
// Protect using ACL.
static uint32_t acl_instance = 0;
uint32_t const wmask = (ACL_ACL_PERM_WRITE_Disable << ACL_ACL_PERM_WRITE_Pos);
uint32_t const rwmask = wmask | (ACL_ACL_PERM_READ_Disable << ACL_ACL_PERM_READ_Pos);
uint32_t const mask = read_protect ? rwmask: wmask;
do
if (acl_instance >= ACL_REGIONS_COUNT)
return NRF_ERROR_NO_MEM;
NRF_ACL->ACL[acl_instance].ADDR = address;
NRF_ACL->ACL[acl_instance].SIZE = size;
NRF_ACL->ACL[acl_instance].PERM = mask;
acl_instance++;
} while (NRF_ACL->ACL[acl_instance - 1].ADDR != address
|| NRF_ACL->ACL[acl_instance - 1].SIZE != size
|| NRF_ACL->ACL[acl_instance - 1].PERM != mask); // Check whether the acl_instance has been used before.
#elif defined (BPROT_PRESENT)
// Protect using BPROT. BPROT does not support read protection.
uint32_t pagenum_start = address / CODE_PAGE_SIZE;
uint32_t pagenum_end = pagenum_start + ((size - 1) / CODE_PAGE_SIZE);
for (uint32_t i = pagenum_start; i <= pagenum_end; i++)
uint32_t config_index = i / 32;
uint32_t mask = (1 << (i - config_index * 32));
switch (config_index)
case 0:
NRF_BPROT->CONFIG0 = mask;
case 1:
NRF_BPROT->CONFIG1 = mask;
#if BPROT_REGIONS_NUM > 64
case 2:
NRF_BPROT->CONFIG2 = mask;
case 3:
NRF_BPROT->CONFIG3 = mask;
return NRF_SUCCESS;
#ifdef __ICCARM__
__ramfunc
void nrf_bootloader_app_start_final(uint32_t vector_table_addr)
ret_code_t ret_val;
// Protect MBR & bootloader code and params pages.
if (NRF_BOOTLOADER_READ_PROTECT)
ret_val = nrf_bootloader_flash_protect(0, MBR_SIZE, NRF_BOOTLOADER_READ_PROTECT);
// Size of the flash area to protect.
uint32_t area_size;
area_size = BOOTLOADER_SIZE + NRF_MBR_PARAMS_PAGE_SIZE;
if (!NRF_BL_DFU_ALLOW_UPDATE_FROM_APP && !NRF_BL_DFU_ENTER_METHOD_BUTTONLESS && !NRF_DFU_TRANSPORT_BLE)
area_size += BOOTLOADER_SETTINGS_PAGE_SIZE;
ret_val = nrf_bootloader_flash_protect(BOOTLOADER_START_ADDR,
area_size,
if (!NRF_BOOTLOADER_READ_PROTECT && (ret_val != NRF_SUCCESS))
NRF_LOG_ERROR("Could not protect bootloader and settings pages, 0x%x.", ret_val);
APP_ERROR_CHECK(ret_val);
nrf_dfu_bank0_start_addr() + ALIGN_TO_PAGE(s_dfu_settings.bank_0.image_size),
false);
NRF_LOG_ERROR("Could not protect SoftDevice and application, 0x%x.", ret_val);
// Run application
app_start(vector_table_addr);
