Hello,May I ask you a question?
Hardware model:NRF51822 SDK version:SDKv9.0.0 SoftDevice:s110.
I used the interface in the pstorage.c file to realize the storage of private data. The pstorage_clear and pstorage_store function made an error after execution, and the private data was not stored.Why is data not allowed to be stored?
I'm looking forward to your reply.
for example:
static void pstorage_callback_handler(pstorage_handle_t * handle, uint8_t op_code, uint32_t result, uint8_t * p_data, uint32_t data_len)
switch(op_code)
case PSTORAGE_CLEAR_OP_CODE:
if (result == NRF_SUCCESS)
simple_uart_putstring((const uint8_t *)"PSTORAGE_CLEAR_OP_CODE NRF_SUCCESS!\n\r");
simple_uart_putstring((const uint8_t *)"PSTORAGE_CLEAR_OP_CODE error!\n\r");
case PSTORAGE_STORE_OP_CODE:
simple_uart_putstring((const uint8_t *)"PSTORAGE_STORE_OP_CODE NRF_SUCCESS!\n\r");
simple_uart_putstring((const uint8_t *)"PSTORAGE_STORE_OP_CODE error!\n\r");
case PSTORAGE_LOAD_OP_CODE:
simple_uart_putstring((const uint8_t *)"PSTORAGE_LOAD_OP_CODE NRF_SUCCESS!\n\r");
simple_uart_putstring((const uint8_t *)"PSTORAGE_LOAD_OP_CODE error!\n\r");
case PSTORAGE_UPDATE_OP_CODE:
simple_uart_putstring((const uint8_t *)"PSTORAGE_UPDATE_OP_CODE NRF_SUCCESS!\n\r");
simple_uart_putstring((const uint8_t *)"PSTORAGE_UPDATE_OP_CODE error!\n\r");
simple_uart_putstring((const uint8_t *)"pstorage_callback_handler fail!\n\r");
void set_name(uint8_t *tmpname)
uint32_t err_code = NRF_SUCCESS;
pstorage_module_param_t storage_params;
storage_params.cb = pstorage_callback_handler;
storage_params.block_size = sizeof(bootloader_settings_t);; //ÉêÇë¿ØÖÆ64¸ö×Ö½Ú
storage_params.block_count = 1; //ÉêÇëÒ»¸öblock
#if 0
err_code = pstorage_init();
if (err_code != NRF_SUCCESS)
simple_uart_putstring((const uint8_t *)"pstorage_init fail!\n\r");
return ;
err_code = pstorage_register(&storage_params, &m_bootsettings_handle);
simple_uart_putstring((const uint8_t *)"pstorage_register fail!\n\r");
return ;
err_code = pstorage_block_identifier_get(&m_bootsettings_handle ,0,&m_settings_handle);
simple_uart_putstring((const uint8_t *)"pstorage_block_identifier_get fail!\n\r");
return ;
uint8_t tmp[64]= {0};
memcpy(tmp,tmpname,sizeof(tmp));
err_code = pstorage_update(&m_settings_handle, tmp, sizeof(tmp), 0);
simple_uart_putstring((const uint8_t *)"pstorage_update fail!\n\r");
return ;
#if 0
err_code = pstorage_clear(&m_settings_handle, sizeof(bootloader_settings_t));
simple_uart_putstring((const uint8_t *)"pstorage_clear fail!\n\r");
return ;
err_code = pstorage_store(&m_settings_handle, tmp, sizeof(bootloader_settings_t), 0);
simple_uart_putstring((const uint8_t *)"pstorage_store fail!\n\r");
return ;
void Get_name(uint8_t *tmpname)
uint8_t dest_data[64] = {0};
uint32_t retval;
// Request to read 4 bytes from block at an offset of 12 bytes.
retval = pstorage_load(dest_data, &m_settings_handle, sizeof(bootloader_settings_t), 0);
if (retval == NRF_SUCCESS)
simple_uart_putstring((const uint8_t *)"pstorage_load success!\n\r");
// Failed to load, take corrective action.
simple_uart_putstring((const uint8_t *)"pstorage_load error!\n\r");
memcpy(tmpname,dest_data,sizeof(dest_data));
uint8_t len;
uart_init();
leds_init();
timers_init();
buttons_init();
cash_box_init();
Timer_1_init();
setting_init();
led_on(3);
nrf_gpio_cfg_sense_input(5,
BUTTON_PULL,
NRF_GPIO_PIN_SENSE_LOW);
simple_uart_putstring((const uint8_t *)START_STRING);
ble_stack_init();
gap_params_init();
services_init();
advertising_init();
conn_params_init();
sec_params_init();
advertising_start();
uint8_t tmp[64] = {0};
simple_uart_putstring((const uint8_t *) "get 1:\n\r");
Get_name(tmp);
for (int i = 0; i < 64; i++)
simple_uart_put(tmp[i]);
simple_uart_putstring((const uint8_t *) "\n\r");
memset(tmp,0,sizeof(tmp));
memcpy(tmp,"wtdtest",8);
simple_uart_putstring((const uint8_t *) "set 1:\n\r");
set_name(tmp);
Get_name(tmp);
simple_uart_putstring((const uint8_t *) "get 2:\n\r");
for (;;)
power_manage();
