Mesh DFU how to update Softdevice
We have a device with the following configuration:
  • nrf5_SDK_for_Mesh_v3.1.0
  • nRF5_SDK_15.2.0
  • s140_nrf52_6.1.0_softdevice
  • mesh_bootloader_gccarmemb_nrf52840_xxAA
 Our task:  Update a device using Mesh DFU to this configuration:
  • nrf5_SDK_for_Mesh_v4.2.0
  • nRF5_SDK_17.0.2
  • s140_nrf52_7.2.0_softdevice
 We are aware that our application only will run if we also update the softdevice.
Questions:
1/ is it possible to update the softdevice with Mesh DFU?
>> we failed when trying to update the Softdevice
  • We generated an update package this way
nrfutil dfu genpkg --softdevice s140_nrf52_7.0.1_softdevice.hex --company-id <our_own_companyID> --application-id <app_id> --application-version <appl_vers> --sd-req 0xFFFE --mesh <packageName>.zip
Our investigations showed us, that in the mesh_evt_handler() the function fw_updated_event_is_for_me() is called which returns false for a dfu_type NRF_MESH_DFU_TYPE_SOFTDEVICE.
Therefore the function nrf_mesh_dfu_relay() will be called.
  • What are we doing wrong?
  • If we run an Application DFU, nrf_mesh_dfu_request() will be called. Why not for SoftDevice DFU?
  • What is the correct way to generate a package for the softdevice?
2/ Is it possible to update the application AND the softdevice with a single update package (only 1 zip file)?
3/ is there a tutorial how (and in which sequence) to update the SW parts (Bootloader, Softdevice, Application)?
 thanks for the help
    Yes, it is possible to update the Softdevice with Mesh DFU.
    Unfortunately, you can't do this. You will need to update them seperately one by one. It's better to update the Softdevice first(assuming the old bootloader is compatible with the new one), then the application.
    I suggest you look through this, Configuring and performing DFU over Mesh.
  • Dear Mttrinh
    could you please answer my additional questions within point 1? ( the questions in magenta and the code)
    Unfortuantely your answer for the first point is not helping me any further.
    How can we get true as return value in fw_updated_event_is_for_me()? It returns always false if we run SoftDevice DFU, because of this case (taken from examples/dfu in Mesh SDK v4.2):
    case NRF_MESH_DFU_TYPE_SOFTDEVICE:
            return false
    Thomas
  • Did you go through the guide I pointed to in my previous reply? It is a step by step guide on how you can do Mesh DFU, how you can update the softdevice with Mesh DFU. Also, it shows how you can generate the DFU pacakge for the Softdevice.
  • Hi Mttrinh,
    thanks for your fast response. We did all the steps, but we think the problem is still in the fw_update_is_for_me() function on the server node (DFU receiver).
    If we perform an application or bootloader DFU, application and bootloader IDs will be checked. The function fw_update_is_for_me() will return true, if the new ID (sent by DFU) is higher than the current one on the device page (flash). This will call nrf_mesh_dfu_request() and we can see how the new DFU data is written to the flash.
    If we run the SoftDevice DFU, the function returns false and nrf_mesh_dfu_relay() is called. We can not see any new data on flash.
    Why?
    Thomas
    It seems like you have to implement it yourself. You need to modify the code and let it accept Softdevice transfers. Under the case NRF_MESH_DFU_TYPE_SOFTDEVICE, you have to check for the incoming softdevice versions(similar to the other cases) and change the return from "false" to "true". So do the checks first before returning "true".
    Best Regards,
    Martin
