RTC example with NRF_LOG
We tried to adapt the RTC example from the SDK to add logging via UART during interrupts and the programmed crashed or hanged.
Here follows the code we are using :
#include "nrf.h"
#include "nrf_gpio.h"
#include "nrf_drv_rtc.h"
#include "nrf_drv_clock.h"
#include "boards.h"
#include "app_error.h"
#include <stdint.h>
#include <stdbool.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define COMPARE_COUNTERTIME  (5UL)                                        /**< Get Compare event COMPARE_TIME seconds after the counter starts from 0. */
#ifdef BSP_LED_0
    #define TICK_EVENT_OUTPUT     BSP_LED_0                                 /**< Pin number for indicating tick event. */
#ifndef TICK_EVENT_OUTPUT
    #error "Please indicate output pin"
#ifdef BSP_LED_1
    #define COMPARE_EVENT_OUTPUT   BSP_LED_1                                /**< Pin number for indicating compare event. */
#ifndef COMPARE_EVENT_OUTPUT
void log_function(char * str)
 NRF_LOG_INFO("%s",NRF_LOG_PUSH(str));
 NRF_LOG_FLUSH();
void multi_print(void){
    //char mess[256];
    for(int i = 0; i< 5; i++){
        //sprintf(mess, "print : %d", i);
        //log_flipper(mess);
        log_function("x \n");
const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(0); /**< Declaring an instance of nrf_drv_rtc for RTC0. */
/** @brief: Function for handling the RTC0 interrupts.
 * Triggered on TICK and COMPARE0 match.
static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
    uint32_t err_code;
    if (int_type == NRF_DRV_RTC_INT_COMPARE0)
        nrf_gpio_pin_toggle(COMPARE_EVENT_OUTPUT);
        multi_print();
        err_code = nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME*8,true);
        nrf_drv_rtc_counter_clear(&rtc);
    else if (int_type == NRF_DRV_RTC_INT_TICK)
        nrf_gpio_pin_toggle(TICK_EVENT_OUTPUT);
/** @brief Function configuring gpio for pin toggling.
static void leds_config(void)
/** @brief Function starting the internal LFCLK XTAL oscillator.
static void lfclk_config(void)
    ret_code_t err_code = nrf_drv_clock_init();
/** @brief Function initialization and configuration of RTC driver instance.
static void rtc_config(void)
    uint32_t err_code;
    //Initialize RTC instance
    nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
    config.prescaler = 4095;
    err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
    //Enable tick event & interrupt
     nrf_drv_rtc_tick_enable(&rtc, true);
    //Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
    err_code = nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * 8,true);
    //Power on RTC instance
    nrf_drv_rtc_enable(&rtc);
 * @brief Function for application main entry.
    multi_print();
    log_function("\n\n\n\n");
    log_function("programm rtc started");
    leds_config();
    lfclk_config();
    rtc_config();
    while (true)
        __SEV();
        __WFE();
        __WFE();
The output of the program is :
<info> app: x
<info> app: x
<info> app: x
<info> app: x
<info> app: x
<info> app:
<info> app: programm rtc started
<info> app: x
Thank for any hints to debug this problem.
