nrf9160 : Writing to flash at a specified location using nrfjprog command line utility
We have a requirement where we need to store some application parameters (Eg. APN name ) in the nrf9160 flash. This parameters will be storing during production time by using the nrfjprog command line utility.
Our requirement is we need to write a binary file at a specified flash location( 0xFA000 ) in nrf and application code should able to read this.
We are able to use the 'memwr' option.
Eg: nrfjprog -f UNKNOWN --memwr 1024000 --val 0x00000105
However this can only be used to write 4 byte at a time. Can we able to write a file as a whole ( 4096 bytes file in form of .bin or .hex)?
Or is there any option to specify the offset where we write using the '--program <hex-file>' option in nrfjprog?
Thanks and regards,
Aswin
