nRF Connect won't display anything
After installing nRF Command Line Tools I am getting a gray screen when opening nRF Connect.
I have tried to remove nRF Command Line Tools and reinstall nRF Connect but it did not resolve it.
It looks like this:
I opened the dev console and it showed this error
C:\Users\capnodin\AppData\Local\Programs\nrfconnect\resources\app.asar\node_modules\bindings\bindings.js:121 Uncaught Error: \\?\C:\Users\capnodin\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\pc-nrfjprog-js\build\Release\pc-nrfjprog-js.node is not a valid Win32 application.
    at process.func (electron/js2c/asar.js:140)
    at process.func [as dlopen] (electron/js2c/asar.js:140)
    at Object.Module._extensions..node (internal/modules/cjs/loader.js:1016)
    at Object.func (electron/js2c/asar.js:140)
    at Object.func [as .node] (electron/js2c/asar.js:149)
    at Module.load (internal/modules/cjs/loader.js:816)
    at Module._load (internal/modules/cjs/loader.js:728)
    at Module._load (electron/js2c/asar.js:717)
    at Function.Module._load (electron/js2c/asar.js:717)
    at Module.require (internal/modules/cjs/loader.js:853)
it was thrown in this function
function bindings(opts) {
  // Argument surgery
  if (typeof opts == 'string') {
    opts = { bindings: opts };
  } else if (!opts) {
    opts = {};
  // maps `defaults` onto `opts` object
  Object.keys(defaults).map(function(i) {
    if (!(i in opts)) opts[i] = defaults[i];
  // Get the module root
  if (!opts.module_root) {
    opts.module_root = exports.getRoot(exports.getFileName());
  // Ensure the given bindings name ends with .node
  if (path.extname(opts.bindings) != '.node') {
    opts.bindings += '.node';
  // github.com/.../4175
  var requireFunc =
    typeof __webpack_require__ === 'function'
      ? __non_webpack_require__
      : require;
  var tries = [],
    i = 0,
    l = opts.try.length,
    n,
    b,
    err;
  for (; i < l; i++) {
    n = join.apply(
      null,
      opts.try[i].map(function(p) {
        return opts[p] || p;
    tries.push(n);
    try {
      b = opts.path ? requireFunc.resolve(n) : requireFunc(n);
      if (!opts.path) {
        b.path = n;
      return b;
    } catch (e) {
      if (e.code !== 'MODULE_NOT_FOUND' &&
          e.code !== 'QUALIFIED_PATH_RESOLUTION_FAILED' &&
          !/not find/i.test(e.message)) {
        throw e;  <------------------------------------------------------------------------
  err = new Error(
    'Could not locate the bindings file. Tried:\n' +
      tries
        .map(function(a) {
          return opts.arrow + a;
        .join('\n')
  err.tries = tries;
  throw err;
Will I have to build pc-nrfjprog-js.node myself?
