OTA DFU in background with no notification?
Hi, I have implemented OTA DFU on Android with your official DFU library. We want the DFU to happen in background at a certain trigger (car driving, triggered from device = user will stay near device) and without bothering the user that this is happening. My implementation was all good and working fine when the app was in the foreground while this was happening, but since we don't expect the user to be staring at his phone while driving - this needs to happen in the background of course. Problem is, when I tested this the following happend:
SDK 15.3 softdevice s132.
starter created
controller initiated
listener registred
onDfuProcessStarting FA:11:1B:B1:D7:C4
onEnablingDfuMode
onDeviceConnecting
DfuBaseService: Connection state change error: 133 newState: 0
DfuBaseService: Device not reachable. Check if the device with address FA:11:1B:B1:D7:C4 is in range, is advertising and is connectable
onError 133 type 1 message GATT ERROR
It is implemented in the following way.
a Presenter class contains the function scheduleDFU
private fun scheduleDFU() {
        val fwFile = File(context.getExternalFilesDir(null).toString() + File.separator.toString() + "fw.zip")
        Log.d("DFUTEST","scheduleDFU with " + fwFile.absolutePath + " " + fwFile.absolutePath)
        val starter = deviceComm.getConnectedDevice()?.address?.let {
            DfuServiceInitiator(it)
                .setDeviceName(deviceComm.getConnectedDevice()?.name)
                .setKeepBond(true) // keep bond after dfu
                .setForceDfu(true)
                .setPacketsReceiptNotificationsEnabled(false)
                .setDisableNotification(true) // no foreground notification
                .setForeground(false)
                .setPrepareDataObjectDelay(400L)
        starter!!.setZip(fwFile.toUri(), fwFile.absolutePath)
        Log.d("DFUTEST","starter created")
        dfuServiceController = starter!!.start(context, DfuService::class.java)
        Log.d("DFUTEST","controller initiated")
        DfuServiceListenerHelper.registerProgressListener(context, dfuProgressListener)
        Log.d("DFUTEST","listener registred")
I didn't want any notifications, and disabled that as you can see above and so the implementation of DfuBaseService (as pr your examples) is very bare bones:
class DfuService : DfuBaseService() {
    @Override
    protected override fun getNotificationTarget(): Class<out Activity> {
        Log.d("DFUTEST","getNotificationTarget")
        return NotificationActivity::class.java
    @Override
    protected override fun isDebug(): Boolean {
        return super.isDebug()
    @Override
    protected override fun updateForegroundNotification(builder: NotificationCompat.Builder) {
        Log.d("DFUTEST","updateForegroundNot")
        super.updateForegroundNotification(builder)
The progress listener is also pretty simple, all it does is log and unsubscribe itself
private val dfuProgressListener: DfuProgressListener = object : DfuProgressListenerAdapter() {
        override fun onDeviceConnecting(deviceAddress: String) {
            Log.d("DFUTEST","onDeviceConnecting")
        override fun onDfuProcessStarting(deviceAddress: String) {
            App.dfuInProgress = true
            Log.d("DFUTEST","onDfuProcessStarting " + deviceAddress )
        override fun onEnablingDfuMode(deviceAddress: String) {
            Log.d("DFUTEST","onEnablingDfuMode")
        override fun onFirmwareValidating(deviceAddress: String) {
            Log.d("DFUTEST","onFirmwareValidating")
        override fun onDeviceDisconnecting(deviceAddress: String) {
            Log.d("DFUTEST","onDeviceDisconnecting " + deviceAddress)
            //DfuServiceListenerHelper.unregisterProgressListener(context, this)
        override fun onDfuCompleted(deviceAddress: String) {
            Log.d("DFUTEST","onDfuCompleted")
            App.dfuInProgress = false
        override fun onDfuAborted(deviceAddress: String) {
            Log.d("DFUTEST","onDfuAborted")
        override fun onProgressChanged(
            deviceAddress: String,
            percent: Int,
            speed: Float,
            avgSpeed: Float,
            currentPart: Int,
            partsTotal: Int
            Log.d("DFUTEST","onProgressChanged / " + percent)
        override fun onError(deviceAddress: String, error: Int, errorType: Int, message: String) {
            Log.d("DFUTEST","onError " + error + " type " + errorType + " message " + message)
So my question:
I assume this has to do with me disabling the foreground notification when setting up the DfuServiceInitiator, but I was under the impression that it was possible to do this without a notification?
Best
Søren
  • So, fixed the bad notification channel by calling createDfuNotification, but now I'm back to square one:
     E/DfuBaseService: Connection state change error: 133 newState: 0
     E/DfuBaseService: Device not reachable. Check if the device with address D6:DB:22:57:34:07 is in range, is advertising and is connectable
  • Seems like an android limitation from what I read from the documentation, if the screen is turned off your scanning will not return scan results irrespective of the service type.
    Once the connection is established it doesn't matter if the screen is or not and as long as the service is on the foreground android will not try to kill it.
    Yours is a very specific case which needs some research. There is one more issue you might face in your approach of background DFU upload is that, user needs to grant location permission for scanning, with the new permission scheme, a user might select grant location permission "while app in use" option. I'm not entirely sure how it will behave in this scenario and you will definitely need background location permission. Oh and btw have you granted background location permission ? Could you just try with that and see if that gives you any scan result? After all that could be a reason. I assumed if this is in place already. You may refer this.
  • Thanks for your support Roshan, it's very kind of you.
    Again, I don't understand however, how this should affect our app since we do not use unfiltered scans. We are filtering all scans with the name of our device, always. So this doesn't really apply to our case. It should still receive scan results in screen-off mode.
    Regarding the permission, this has been granted by the user during onboarding (and also on the phones that I'm testing on here at the office) but I don't think this is relevant since we are running a foreground service for the app (with a notification). All scanning is handled in this service.
  • Ok I see your point now, let me get back to you.
    EDIT: So i did some digging. you are 100% correct about the scan filter. There seems to be an issue on our end where we don't include a scan filter (this is to ensure backward compatibility with some older devices) while scanning after the device jumps in to the bootloader mode but I managed to get it working on the background. For now I would suggest you to clone the Android-DFU-Library project and include it manually in your project and add your device name as the scan filter and pass it in to the startScan method here. For this to work I had to include
    "android.permission.ACCESS_BACKGROUND_LOCATION"
    in the manifest file and ensure its granted from the app settings as "Allow all the time". The way I tested this was by adding a 10 second delayed runnable and locking the screen off. Here's the exact snippet.
    new Handler().postDelayed(() -> starter.start(context, DfuService.class), 10000);
    Give it a go and let me know how it works out for you.
  • Yes, there we go. This seems to have solved the problem. Thank you Roshan!
  • That's great sorry it took a bit longer than I expected but I guess we got to it in the end. I have also just released a version 1.11.1  to bintray. Give it a shot it should work out of the box as I have set the ScanFilter based on the address. Let me know how that goes so you can stick to the original dependency.
