nRF52832 and LIS3DH accelerometer
I am trying to read LIS3DH accelerometer with my nRF52832. I am using a custom board. Is there any tutorial or example that can help me? After some changes in the code, I tried "twi_sensor" example.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define LSM6_ADD      (0XD6U >> 1)
#define G_EARTH 9.80665
#define GAUSS_TO_TESLAS 100
#define TWI_INSTANCE_ID     0
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
static volatile bool m_xfer_done = false;
typedef union
    int16_t data[3];
    int8_t buff[6];
} data_int_convert_t;
typedef struct
    float x;
    float y;
    float z;
    float gain;
} axis_data_t;
axis_data_t axis_data_lsm6_a;
axis_data_t axis_data_lsm6_g;
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
            m_xfer_done = true;
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_vnet_config = {
       .scl                = 14,
       .sda                = 15,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_vnet_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
void twi_reg_write(uint8_t addr, uint8_t *reg, uint16_t length)
    uint32_t err_code;
    err_code = nrf_drv_twi_tx(&m_twi, addr, reg, 2, false);
    while (m_xfer_done == false){
void twi_reg_read_t(uint8_t const addr, uint8_t reg, uint8_t *value, uint16_t length, uint32_t delay)
    uint32_t err_code;
    uint8_t buff[2];
    err_code = nrf_drv_twi_tx(&m_twi, addr, &reg, sizeof(reg), false);
    nrf_delay_us(delay);
    err_code = nrf_drv_twi_rx(&m_twi, addr, value, length);
void LSM6_CFG(void)
    uint8_t reg[2] = {0x10, 0x80};
    uint32_t err_code;
    twi_reg_write(LSM6_ADD, reg, 2);
                 printf("LSM6 CFG");
    reg[0] = 0x11; reg[1] = 0x80;
    reg[0] = 0x12; reg[1] = 0x04;
    /* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
    //uint8_t reg[2] = {LM75B_REG_CONF, NORMAL_MODE};
    //err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, sizeof(reg), false);
    //APP_ERROR_CHECK(err_code);
    //while (m_xfer_done == false);
    /* Writing to pointer byte. */
    //reg[0] = LM75B_REG_TEMP;
    //m_xfer_done = false;
    //err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, 1, false);
static void LSM6_Read(void)
    uint8_t i = 0;
    data_int_convert_t data_cnv_lsm6_a;
    data_int_convert_t data_cnv_lsm6_g;
    uint8_t reg[2] = {0x28, 0x22};
    twi_reg_read_t(LSM6_ADD, reg[0], data_cnv_lsm6_a.buff, 6, 1300);
    nrf_delay_us(1000);
    //twi_reg_read_t(LSM6_ADD, reg[1], data_cnv_lsm6_g.buff, 6, 1300);
    axis_data_lsm6_a.gain = 0.061 / 1000.0;
    axis_data_lsm6_a.x = (float)data_cnv_lsm6_a.data[0] * axis_data_lsm6_a.gain * G_EARTH;
    axis_data_lsm6_a.y = (float)data_cnv_lsm6_a.data[1] * axis_data_lsm6_a.gain * G_EARTH;
    axis_data_lsm6_a.z = (float)data_cnv_lsm6_a.data[2] * axis_data_lsm6_a.gain * G_EARTH;
    axis_data_lsm6_g.gain = 8.75 / 1000.0;
    axis_data_lsm6_g.x = (float)data_cnv_lsm6_g.data[0] * axis_data_lsm6_g.gain;
    axis_data_lsm6_g.y = (float)data_cnv_lsm6_g.data[1] * axis_data_lsm6_g.gain;
    axis_data_lsm6_g.z = (float)data_cnv_lsm6_g.data[2] * axis_data_lsm6_g.gain;
     NRF_LOG_INFO("\r\nTWI leitura do sensor feita.");
    NRF_LOG_INFO("\r\nTWI sensor example started.");
    NRF_LOG_FLUSH();
    twi_init();
    LSM6_CFG();
     printf("leitura do sensor feita");
    while (true)
        NRF_LOG_FLUSH();
        LSM6_Read();
        nrf_delay_ms(1000);
But, in line 79, "m_xfer_done" is always false and I can't get any measure.
Thanks in advance,
Gabriel
