Copying the PCA10028 antenna design
Is it possible for me to completely copy the antenna design from PCA10028 unto my custom board? I don't need a very long range, but I need to make a design fairly quickly.
My problem is that I'm not going to add SWF connector so I don't know how to connect the antenna feed to the actual antenna.
My design:
My Design
Your design:
Your Design
I've copied the component placement from your design, and I'm making sure to make a strong ground.
I'm assuming that I need to use 1.6mm PCB as well.
EDIT:
I connected the antenna to the antenna feed, and added the ground-plane (on both sides) Do you think this will suffice?
Updated Design
I wasn't sure whether I should completely connect the antenna or only slightly, so I did something in between (is that good?).
