The error I get is as followed:
Output/Debug/Exe/Lesson10_Part3.elf section `.nrf_balloc' will not fit in region `UNPLACED_SECTIONS'
region `UNPLACED_SECTIONS' overflowed by 20 bytes
For this error, I see several comments in this forum. Most of them can be solved by adding the nrf_queue placement to the "flash_placement" file. For me before I added nrf_queue, It shows "overflowed by 60 bytes", and it now shows "overflowed by 20 bytes" after I add the nrf_queue placement. My current "flash_placement" file is as followed. Could you please help me solve this error.
Thanks in advance for your help
<!DOCTYPE Linker_Placement_File>
<Root name="Flash Section Placement">
<MemorySegment name="$(FLASH_NAME:FLASH)">
<ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START:)" />
<ProgramSection alignment="4" load="Yes" name=".init" />
<ProgramSection alignment="4" load="Yes" name=".init_rodata" />
<ProgramSection alignment="4" load="Yes" name=".text" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".pwr_mgmt_data" inputsections="*(SORT(.pwr_mgmt_data*))" address_symbol="__start_pwr_mgmt_data" end_symbol="__stop_pwr_mgmt_data" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_queue" inputsections="*(.nrf_queue*)" address_symbol="__start_nrf_queue" end_symbol="__stop_nrf_queue" />
<ProgramSection alignment="4" load="Yes" name=".dtors" />
<ProgramSection alignment="4" load="Yes" name=".ctors" />
<ProgramSection alignment="4" load="Yes" name=".rodata" />
<ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
<ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
<ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
<ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
</MemorySegment>
<MemorySegment name="$(RAM_NAME:RAM);SRAM">
<ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START:$(SRAM_START:))" />
<ProgramSection alignment="4" load="No" name=".fast_run" />
<ProgramSection alignment="4" load="No" name=".data_run" />
<ProgramSection alignment="4" load="No" name=".bss" />
<ProgramSection alignment="4" load="No" name=".tbss" />
<ProgramSection alignment="4" load="No" name=".tdata_run" />
<ProgramSection alignment="4" load="No" name=".non_init" />
<ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
<ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack" />
<ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
</MemorySegment>
<MemorySegment name="$(FLASH2_NAME:FLASH2)">
<ProgramSection alignment="4" load="Yes" name=".text2" />
<ProgramSection alignment="4" load="Yes" name=".rodata2" />
<ProgramSection alignment="4" load="Yes" runin=".data2_run" name=".data2" />
</MemorySegment>
<MemorySegment name="$(RAM2_NAME:RAM2)">
<ProgramSection alignment="4" load="No" name=".data2_run" />
<ProgramSection alignment="4" load="No" name=".bss2" />
</MemorySegment>
</Root>
