Cloning a git repository to build for nrf9160
HI
i want to build the examples in git repository "https://github.com/Rallare/fw-nrfconnect-nrf/tree/nrf9160_samples/samples/nrf9160" for my nrf9160 using segger embedded studio.
i downloaded the repository and unzip it to the "C:\gnuarmemb\v1.3.2\nrf\boards\arm" the project is shown under other nordic projects but when i try to build it failed. am i mistaking in cloning the repository or any other issue is there.
Kindly help me out by providing the steps to follow for using a repository from git to segger embedded studio. at what locations i need to do some modification for a new repository or a new code modified.
  • Creating solution adc.emProject
    C:/gnuarmemb/v1.4.0/toolchain/opt/bin/cmake.exe -GNinja -DBOARD=nrf9160dk_nrf9160ns -DBOARD_DIR=C:\gnuarmemb\v1.3.2\zephyr\boards\arm\nrf9160dk_nrf9160 -BC:\Users\Win8\fw-nrfconnect-nrf\fw-nrfconnect-nrf\samples\nrf9160\adc\build_nrf9160dk_nrf9160ns -SC:\Users\Win8\fw-nrfconnect-nrf\fw-nrfconnect-nrf\samples\nrf9160\adc -DNCS_TOOLCHAIN_VERSION=1.4.0 -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:\gnuarmemb\EmbeddedStudio_ARM_Nordic_v510d_win_x64\arm_segger_embedded_studio_v510d_win_x64_nordic/html/configure_nordic_project_menuconfig.py
    -- Application: C:/Users/Win8/fw-nrfconnect-nrf/fw-nrfconnect-nrf/samples/nrf9160/adc
    -- Zephyr version: 2.3.0-rc1 (C:/gnuarmemb/v1.3.2/zephyr)
    -- Found Python3: C:/gnuarmemb/v1.4.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Board: nrf9160dk_nrf9160ns
    -- Found west: C:/gnuarmemb/v1.4.0/toolchain/opt/bin/Scripts/west.exe (found suitable version "0.7.2", minimum required is "0.7.1")
    -- Found dtc: C:/gnuarmemb/v1.4.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (C:/gnuarmemb/v1.4.0/toolchain/opt)
    -- Found BOARD.dts: C:/gnuarmemb/v1.3.2/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts
    -- Generated zephyr.dts: C:/Users/Win8/fw-nrfconnect-nrf/fw-nrfconnect-nrf/samples/nrf9160/adc/build_nrf9160dk_nrf9160ns/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Users/Win8/fw-nrfconnect-nrf/fw-nrfconnect-nrf/samples/nrf9160/adc/build_nrf9160dk_nrf9160ns/zephyr/include/generated/devicetree_unfixed.h
    Parsing C:/gnuarmemb/v1.3.2/zephyr/Kconfig
    Loaded configuration 'C:/gnuarmemb/v1.3.2/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig'
    Merged configuration 'C:/Users/Win8/fw-nrfconnect-nrf/fw-nrfconnect-nrf/samples/nrf9160/adc/prj.conf'
    -- Using NCS Toolchain 1.4.0 for building. (C:/gnuarmemb/v1.4.0/toolchain/cmake)
    error: NET_RAW_MODE (defined at subsys/net/ip/Kconfig:52) is assigned in a configuration file, but
    is not directly user-configurable (has no prompt). It gets its value indirectly from other symbols.
    See docs.zephyrproject.org/.../CONFIG_NET_RAW_MODE.html and/or look up
    NET_RAW_MODE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    CMake Error at C:/gnuarmemb/v1.3.2/zephyr/cmake/kconfig.cmake:217 (message):
    command failed with return code: 1
    C:/gnuarmemb/v1.3.2/zephyr/cmake/app/boilerplate.cmake:506 (include)
    CMakeLists.txt:9 (include)
    error: cmake failed
    create_nordic_project.py failed (1)
    clone the library but when try to build this error came in.
    The samples in the git repository https://github.com/Rallare/fw-nrfconnect-nrf/tree/nrf9160_samples/samples/nrf9160 are quite old and there is no guarantee they will work with the newest verson of NCS.
    I recommend you use the samples provided in the latest version of NCS instead. If you need help getting started with NCS please visit our tutorial blog for Getting Started with NCS: https://devzone.nordicsemi.com/nordic/nrf-connect-sdk-guides/b/getting-started/posts/nrf-connect-sdk-tutorial
    Marjeris
