The best way to handle time-consuming processes
I want to know the best way to handle time-consuming processes.
I am using an external module used for AT commands via UART. It is necessary to judge the success or failure of each command based on the response received from the UART. (Depending on the command, the content of the response that can be judged as successful differs.) It is necessary to send multiple commands to execute a specific function, but depending on the command, it may take some time for the response to be received ( Up to 10 sec). The code below is simple, but I think it will be a busy loop and a bad implementation.
bool connectMqttServer() {
    // send AT Command
    sendCommand("AT+ACTIVATE=1");
    // The process below waits for UART reception in a busy loop
    if (!readAndCheckResponse("OK", 300)) {
        return false;
    sendCommand("AT+CONNECT=mqttSever.io,1883");
    // It may take up to 10 seconds to receive the response of this command
    if (!readAndCheckResponse("OK", 10000)) {
        return false;
    sendCommand("AT+READ=0,100");
        return false;
    return true;
void readAndCheckResponse(const char* successRes, uint32_t timeout) {
I wanted to resolve the success or failure of the command with an interrupt triggered by a UART reception event so that it would not become a busy loop. However, in this case, the implementation becomes very complicated.
I think this problem is caused by the inability to use threads and asynchronous processing rather than the SDK, but I would be grateful if you could give me some advice.
    I understand the issue, and as I see it there are a few approaches to this.
    I don't know how your current readAndCheckResponse() is implemented, but I guess you have some sort of timeout inside this call, but you want to do this without blocking the rest of the application, right?
    I believe you need to split the timeout functionality from the UART RX part. The timeout can be handled using the app_timer.
    For an example of how to use the app_timer, you can check how the ble_app_hrs example uses the app_timer to trigger (simulated) battery level measurements.
    Let us take this command as an example:
            return false;
    After the call to sendCommand("..."); you can start an app timer with a 10 second timeout. If this timer times out before you receive the OK, that would be the same as this returning false.
    Then you would need some way to check the incoming UART response. I don't know if you have an interrupt based way of doing so at this point? I suggest you look into the way that the ble_app_uart example handles UART interrupts, and saves up the received bytes until it either receives a linefeed or the buffer is full before it sends the data over BLE. Perhaps you can use some of the same logic to check for "OK".
    Remember that if you receive an "OK" before the timeout, you can stop the app timer, and restart it with new timeout value. It is also possible to pass a custom pointer into your app_timer_start() call that you can use to maintain some sort of state machine.
    If you are interrested, and you may find it useful, please check the attached main.c file that is a modified ble_app_uart main.c file from SDK17.0.0. If you run it and press button 4, you should see some log information from a couple of timeout events wich has passed the &my_context parameter, which is used as a state machine. The timer is started in the BSP_EVENT_KEY_3 event in the bsp_event_handler().
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    volatile uint32_t m_test_counter = 0;
    volatile uint32_t m_parity = 0;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    APP_TIMER_DEF(m_test_timer_id);
    APP_TIMER_DEF(m_test_context_timer_id);
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    enum CONTEXT_TYPE
        EVENT_TYPE_0 = 0,
        EVENT_TYPE_1,
        EVENT_TYPE_2,
        EVENT_TYPE_3,
        EVENT_TYPE_4,
        EVENT_TYPE_5,
        EVENT_TYPE_6
    typedef struct
        uint8_t context_header;           /**< Event header. */
        uint8_t some_other_variable;
    } m_context_t;
    m_context_t my_context;
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    static void my_adv_stop(void)
        NRF_LOG_INFO("stop advertising");
        //uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        ret_code_t err_code;
        uint8_t my_adv_handle = m_advertising.adv_handle;
        err_code = sd_ble_gap_adv_stop(my_adv_handle);
    static void my_adv_start(void)
        NRF_LOG_INFO("start advertising");
    static void my_timeout_handler(void * p_context)
        m_test_counter++;
        NRF_LOG_INFO("Timer timeout number %d", m_test_counter);
        if (m_test_counter%10 == 0)
            if ((m_test_counter/10)%2 == 1)
                my_adv_stop();
                my_adv_start();
    static void my_context_timer_timeout(void * p_context)
        NRF_LOG_INFO("p_context: 0x%08x", p_context);
        m_context_t * local_pointer = (m_context_t*)p_context;
        switch(local_pointer->context_header)
            case EVENT_TYPE_0:
                NRF_LOG_INFO("event type EVENT_TYPE_0");
                NRF_LOG_INFO("some additional information: %d", local_pointer->some_other_variable);
                // Start next timer:
                local_pointer->context_header = EVENT_TYPE_1;
                local_pointer->some_other_variable = 12;
                err_code = app_timer_start(m_test_context_timer_id, APP_TIMER_TICKS(2000), local_pointer);
            case EVENT_TYPE_1:
                NRF_LOG_INFO("event type EVENT_TYPE_1");
                NRF_LOG_INFO("undefined event type");
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
        err_code = app_timer_create(&m_test_timer_id, APP_TIMER_MODE_REPEATED, my_timeout_handler);
        //err_code = app_timer_start(m_test_timer_id, APP_TIMER_TICKS(1000), NULL);
        //APP_ERROR_CHECK(err_code);
        err_code = app_timer_create(&m_test_context_timer_id, APP_TIMER_MODE_SINGLE_SHOT, my_context_timer_timeout);
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            //NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on UART.");
            //NRF_LOG_HEXDUMP_DEBUG(p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
            uint8_t * rcv_data = (uint8_t *)p_evt->params.rx_data.p_data;
            uint16_t rcv_len = (uint16_t)p_evt->params.rx_data.length;
            err_code = ble_nus_data_send(&m_nus, rcv_data, &rcv_len, p_evt->conn_handle);
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected, reason 0x%02x", p_ble_evt->evt.gap_evt.params.disconnected.reason);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
            case BSP_EVENT_KEY_2:
                NRF_LOG_INFO("Disconnecting...");
            case BSP_EVENT_KEY_3:
                NRF_LOG_INFO("button 4 pressed");
                my_context.context_header = EVENT_TYPE_0;
                my_context.some_other_variable = 4;
                err_code = app_timer_start(m_test_context_timer_id, APP_TIMER_TICKS(1000), &my_context);
                NRF_LOG_INFO("default button %d", event);
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
        err_code = bsp_event_to_button_action_assign(2, BSP_BUTTON_ACTION_RELEASE, BSP_EVENT_KEY_2);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    static void custom_pin_test(void)
        NRF_LOG_INFO("customm_pin_test");
        NRF_GPIO->PIN_CNF[15] = (GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos);
        NRF_GPIO->PIN_CNF[17] = (GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos);
        NRF_GPIO->OUTSET = (1 << 15) | (1 << 17);
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        NRF_LOG_INFO("buttons_leds_init, erase_bonds = %d", erase_bonds);
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        //custom_pin_test();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Edvin
