GATT_CONN_TERMINATE_LOCAL_HOST after 28-30s
Good morning,
I have designed a prototype based on nRF52840 and an application based on S140 v.6.1.0.
We have already assembled several prototypes and all of them have been working fine for weeks: we have created our own Android app and we have tested it with several Smartphones.
One of this equipments is the one I'm using for development, together with a defined Smartphone.
Up to yesterday, everythink was working fine but now, when I'm connecting the Smartphone with my development prototype, it perfectly connects but it always disconnects after 28-30seconds.
I have also tested with nRF Connect app: the same happens and in log register the message GATT_CONN_TERMINATE_LOCAL_HOST appears after 28-30s.
From this point, I have done some testing:
- With my Smartphone:
- I have tried to connect to a different prototype and it is connecting fine without any disconnection
- I have forgotten my prototype in order to enter passkey again --> This has not solved the problem with my prototype
- I have switched off and on back again bluetooth --> Same problem
- I have erased bluetooth cache in my smartphone --> Same problem
- With my prototype (nRF52840 based):
-I have tested same prototype with another Smartphone, and it is perfectly working.
- I have fully erased it with JFlash and I have flashed it again (bootloader, sd, boot_setting,app). Even, I have done this with different versions that were previously working without problems.
My smartphone is a Xiaomi Mi6, and I have been using it during my development stage.
Do you know which can be the reason of such behaviour?
Dani
  • Hi Dani,
    Could you provide the debug log with the disconnect reason?
    In ble_evt_handler, you could do something like this:
                NRF_LOG_INFO("Disconnected reason: %d.",p_ble_evt->evt.gap_evt.params.disconnected.reason);
    A sniffer trace could be helpful(see this page).
    -Amanda H.
  • Hi Amanda,
    I've sniffer already working, but what information do you need to be catched?
    As I'm using a 8-digit passkey, I have entered this passkey into Wireshark passkey field. This is right?
    I'm deeping a bit more into this application, but meanwhile, if you can detail the information that is useful for you, it will be great!!!
    All the best,
    Dani.
  • This is what I'm seeing when disconnection occurs (please, look at the following image)
    Please, find also enclose trace file.
    Android_disconnection_25_11_20.pcapng
  • Hi Daniel,
    The disconnect reason is what is shown as "Error Code" in your figure - remote user terminated connection (0x13). This does not indicate an error in itself, it just states that the phone side decided to disconnect (for some reason). A 30 seconds match for instance a GATT timeout, but I could not say anything without the sniffer trace. In that case, you should get disconnect reason 0x08 (timeout). Could it be that the software running on the phone devices decide to disconnect for some reason? Could you check or provide the debug log and the disconnect reason on the nRF52840 side? I suggest to compare with one of the working SDK examples.
     -Amanda H.
  • Hi Amanda,
    I have been playing with connection intervals definition, and in some scenarios it works.
    Could you recommend us best scenario, or the rules to follow?
    Now, I have set:
    MIN_CONN_INTERVAL to 10
    MAX_CONN_INTERVAL to 100
    In my application, if I sent application data once every 62.5ms, then the GATT_CONN_TERMINATE_LOCAL_HOST appears. What I do not understand (looking at nRF Connect app in my smartphone) is why notifications are received every 1 second (I send them every 62.5ms). Please, look at log1.txt file saved with nRF Connect.
    nRF Connect, 2020-11-25
    A-SMART 2 (F9:4F:3C:FA:8E:43)
    I	11:40:31.927	[Server] Server started
    V	11:40:31.936	Heart Rate (0x180D)
    - Heart Rate Measurement [N] (0x2A37)
       Client Characteristic Configuration (0x2902)
    - Body Sensor Location [R] (0x2A38)
    - Heart Rate Control Point [W] (0x2A39)
    Unknown Service (0000aaa0-0000-1000-8000-aabbccddeeff)
    - Unknown Characteristic [N R] (0000aaa1-0000-1000-8000-aabbccddeeff)
       Unknown Descriptor (0000aab0-0000-1000-8000-aabbccddeeff)
       Characteristic User Description (0x2901)
       Characteristic Presentation Format (0x2904)
    - Unknown Characteristic [I W WNR] (0000aaa2-0000-1000-8000-aabbccddeeff)
    User Data (0x181C)
    - First Name [R W] (0x2A8A)
    - Last Name [R W] (0x2A90)
    - Gender [R W] (0x2A8C)
    V	11:40:32.167	Connecting to F9:4F:3C:FA:8E:43...
    D	11:40:32.168	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	11:40:32.368	[Server callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	11:40:32.368	[Server] Device with address F9:4F:3C:FA:8E:43 connected
    D	11:40:32.374	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	11:40:32.374	Connected to F9:4F:3C:FA:8E:43
    D	11:40:32.401	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    D	11:40:32.407	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
    D	11:40:32.408	[Broadcast] Action received: android.bluetooth.device.action.PAIRING_REQUEST, pairing variant: PAIRING_VARIANT_CONSENT (3)
    I	11:40:32.447	[Server] MTU changed to 247
    I	11:40:33.212	PHY updated (TX: LE 2M, RX: LE 2M)
    I	11:40:33.213	[Server] PHY updated (TX: LE 2M, RX: LE 2M)
    I	11:40:33.662	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D	11:40:34.153	[Broadcast] Action received: android.bluetooth.device.action.PAIRING_REQUEST, pairing variant: PAIRING_VARIANT_PIN (0)
    I	11:40:34.202	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
    I	11:40:34.652	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D	11:40:38.366	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDED (12)
    I	11:40:38.366	Device bonded
    D	11:40:38.369	wait(1600ms)
    I	11:40:39.144	Connection parameters updated (interval: 97.5ms, latency: 0, timeout: 4000ms)
    V	11:40:39.972	Discovering services...
    D	11:40:39.972	gatt.discoverServices()
    D	11:40:39.988	[Callback] Services discovered with status: 0
    I	11:40:39.988	Services discovered
    V	11:40:40.018	Generic Access (0x1800)
    - Device Name [R W] (0x2A00)
    - Appearance [R] (0x2A01)
    - Peripheral Preferred Connection Parameters [R] (0x2A04)
    - Central Address Resolution [R] (0x2AA6)
    Generic Attribute (0x1801)
    - Service Changed [I] (0x2A05)
    Unknown Service (00001000-0000-1000-8000-00805f9b34fb)
    - Unknown Characteristic [R W] (00001001-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [N R] (00001002-1212-efde-1523-785feabcd123)
    Unknown Service (00002000-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [R W] (00002001-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [N R] (00002002-1212-efde-1523-785feabcd123)
    Unknown Service (00003000-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [R W] (00003001-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [N R] (00003002-1212-efde-1523-785feabcd123)
    Unknown Service (00004000-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [R W] (00004001-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [N R] (00004002-1212-efde-1523-785feabcd123)
    Unknown Service (00005000-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [R W] (00005001-1212-efde-1523-785feabcd123)
    Unknown Service (00006000-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [N R] (00006002-1212-efde-1523-785feabcd123)
    Secure DFU Service (0xFE59)
    - Secure Buttonless DFU [I W] (8ec90004-f315-4f60-9fb8-838830daea50)
    D	11:40:40.018	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D	11:40:40.021	gatt.setCharacteristicNotification(00001002-1212-efde-1523-785feabcd123, true)
    D	11:40:40.022	gatt.setCharacteristicNotification(00002002-1212-efde-1523-785feabcd123, true)
    D	11:40:40.023	gatt.setCharacteristicNotification(00003002-1212-efde-1523-785feabcd123, true)
    D	11:40:40.023	gatt.setCharacteristicNotification(00004002-1212-efde-1523-785feabcd123, true)
    D	11:40:40.026	gatt.setCharacteristicNotification(00006002-1212-efde-1523-785feabcd123, true)
    I	11:40:40.320	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-16-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:40.320	"(0x) 0F-01-00-00-00-14-0D-D3-16-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:41.420	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-17-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:41.420	"(0x) 0F-01-00-00-00-14-0D-D3-17-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:42.362	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-18-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:42.362	"(0x) 0F-01-00-00-00-14-0D-D3-18-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:43.333	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-19-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:43.333	"(0x) 0F-01-00-00-00-14-0D-D3-19-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:44.322	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-1A-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:44.322	"(0x) 0F-01-00-00-00-14-0D-D3-1A-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:45.389	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-1B-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:45.389	"(0x) 0F-01-00-00-00-14-0D-D3-1B-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:46.356	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-1C-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:46.356	"(0x) 0F-01-00-00-00-14-0D-D3-1C-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:47.429	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-1D-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:47.429	"(0x) 0F-01-00-00-00-14-0D-D3-1D-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:48.318	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-1E-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:48.318	"(0x) 0F-01-00-00-00-14-0D-D3-1E-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:49.383	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-1F-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:49.383	"(0x) 0F-01-00-00-00-14-0D-D3-1F-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:50.356	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-0E-0D-D3-20-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:50.356	"(0x) 0F-01-00-00-00-0E-0D-D3-20-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:51.533	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-0E-0D-D3-21-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:51.533	"(0x) 0F-01-00-00-00-0E-0D-D3-21-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:52.307	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-0E-0D-D3-22-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:52.307	"(0x) 0F-01-00-00-00-0E-0D-D3-22-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:53.390	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-0E-0D-D3-23-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:53.390	"(0x) 0F-01-00-00-00-0E-0D-D3-23-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:54.351	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-0E-0D-D3-24-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:54.351	"(0x) 0F-01-00-00-00-0E-0D-D3-24-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:55.338	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-0E-0D-D3-25-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:55.339	"(0x) 0F-01-00-00-00-0E-0D-D3-25-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:56.400	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-0E-0D-D3-26-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:56.400	"(0x) 0F-01-00-00-00-0E-0D-D3-26-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:57.374	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-0E-0D-D3-27-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:57.374	"(0x) 0F-01-00-00-00-0E-0D-D3-27-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:58.352	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-0E-0D-D3-28-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:58.352	"(0x) 0F-01-00-00-00-0E-0D-D3-28-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:40:59.520	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-0E-0D-D3-29-00-00-01-01-00-05-00-00-00-00-00
    A	11:40:59.520	"(0x) 0F-01-00-00-00-0E-0D-D3-29-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:41:00.405	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-2A-00-00-01-01-00-05-00-00-00-00-00
    A	11:41:00.405	"(0x) 0F-01-00-00-00-14-0D-D3-2A-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:41:01.383	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-2B-00-00-01-01-00-05-00-00-00-00-00
    A	11:41:01.383	"(0x) 0F-01-00-00-00-14-0D-D3-2B-00-00-01-01-00-05-00-00-00-00-00" received
    I	11:41:02.346	Notification received from 00006002-1212-efde-1523-785feabcd123, value: (0x) 0F-01-00-00-00-14-0D-D3-2C-00-00-01-01-00-05-00-00-00-00-00
    A	11:41:02.346	"(0x) 0F-01-00-00-00-14-0D-D3-2C-00-00-01-01-00-05-00-00-00-00-00" received
    D	11:41:02.361	[Callback] Connection state changed with status: 22 and new state: DISCONNECTED (0)
    E	11:41:02.361	Error 22 (0x16): GATT CONN TERMINATE LOCAL HOST
    I	11:41:02.361	Disconnected
    D	11:41:02.361	[Server callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
    I	11:41:02.361	[Server] Device disconnected
    D	11:41:02.447	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    Do you have any explanation for this?
    Dani
