Radio interrupt stays activated in Rx mode (without Softdevice)
Hi !
I am working with a NRF52832 and with SDK 15.2.
For my application, I need sometimes to deactivate the Softdevice to begin some radio tests.
So I have programmed it, using the Radio Test and the Radio Emetter examples.  have mainly used the radio_test library.
The part of my program handling the Rx mode is the following :
            printf("radio_test_handler: RX\n");
            err_code = radio_test_init();
            //Clear the rx radio buffer
            memset(g_rx_packet, 0, sizeof(g_rx_packet));
            //Clear the frame counter
            radio_frame_rx_counter = 0;
            //start a process to manage notifs when we receive data
            //activate Interruption when END event
            NRF_RADIO->INTENSET |= RADIO_INTENSET_END_Msk;
            //Enable Radio interruptions
            NVIC_ClearPendingIRQ(RADIO_IRQn);
            //NVIC_SetPriority(RADIO_IRQn, RADIO_IRQ_PRIORITY);
            NVIC_EnableIRQ(RADIO_IRQn);
            radio_rx_enabled = true;
            g_pattern = (transmit_pattern_t) uart_rx_data->p_data[TRANSMISSION_PATTERN_ID];
            radio_rx( uart_rx_data->p_data[DATA_RATE_ID], uart_rx_data->p_data[CHANNEL_ID]);
The radio_test_init function is the following :
static ret_code_t radio_test_init(void)
    ret_code_t ret;
    //disable softdevice
    ret = ble_stack_stop();
    while(nrf_sdh_is_enabled()){};
    //check for nrf_sdh_is_enabled false => need to be in non-blocking mode
    /* All the following part is from the radio_test example, need to be updated */
    //init the clock
    if(!nrf_drv_clock_init_check())
        ret = nrf_drv_clock_init();
        if(ret != NRF_SUCCESS) printf("Radio test: clock driver init error code %d\n", ret);
    // Request Low frequency clock to re-enable the clock after the softdevice stops it.
    if(!nrf_drv_clock_lfclk_is_running())
    ret = app_timer_init();
    if(ret != NRF_SUCCESS) printf("Radio test: app_timer_init error code %d\n", ret);
    //APP_ERROR_CHECK(err_code);
    //configuration of all peripherals used here
    NRF_RNG->TASKS_START = 1;
#ifndef NRF52810_XXAA
    NRF_NVMC->ICACHECNF  = NVMC_ICACHECNF_CACHEEN_Enabled << NVMC_ICACHECNF_CACHEEN_Pos;
#endif // NRF52810_XXAA
    // Start 64 MHz crystal oscillator.
    NRF_CLOCK->TASKS_HFCLKSTART    = 1;
    // Wait for the external oscillator to start up.
    while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0) //need to be in non blocking mode
        // Do nothing.
    NVIC_EnableIRQ(TIMER0_IRQn);
    __enable_irq();
    return ret;
And the radio_handler is the following :
/*Handler called when there is a Radio event */
void RADIO_IRQHandler(void)
    if(radio_rx_enabled)
        //we enter if the radio event is the END event
        if(NRF_RADIO->EVENTS_END !=0U)
            size_t size_data_received;
            size_data_received = sizeof(g_rx_packet);
            uint8_t data_buffer[size_data_received];
            //Prepare the data to send to the host
            for (uint32_t i = 0; i < size_data_received; i++)
                printf("Data received through RX : %d\r\n", g_rx_packet[i]);
            uart_tx_request_set(uint8_t * p_tx_data, uint8_t p_len);
            ret_code_t err_code;
            /*payload to send */
            uint8_t p_tx_data[RADIO_NOTIF_LEN];
            // set response SOF
            p_tx_data[0] = SOF_VALUE;
            // set response type
            p_tx_data[1] = ID_BLE_TEST_MODE_NOTIF;
            // set payload length
            p_tx_data[2] = 4;
            //set Production test ID
            p_tx_data[3] = RADIO_TEST_NOTIFICATION;
            //set Radio Test ID
            p_tx_data[4] = RX;
            //set RX status
            p_tx_data[5] = 1; // A new frame have been received
            //set Radio frame counter
            if(radio_frame_rx_counter >= BYTE_MAX_VALUE) radio_frame_rx_counter = 0;
            else radio_frame_rx_counter++;
            p_tx_data[6] = radio_frame_rx_counter;
            // compute CRC
            uint8_t crc_sent = crc8_u8CalcComplete(0x00, p_tx_data + UART_HOST_SOF, RADIO_NOTIF_LEN - 1 - UART_HOST_SOF);
            p_tx_data[RADIO_NOTIF_LEN-1] = crc_sent;
            err_code = uart_tx_request_set(p_tx_data, RADIO_NOTIF_LEN);
            if(err_code != NRF_SUCCESS) printf("RADIO_IRQHandler : Unable to send request to the host, error code : %d\n", err_code);
            NRF_RADIO->EVENTS_END ==0U;
After being entered in the Rx mode state, and began a modulated carrier transmission with another board with the Radio Test example, I receive the data and enters in the radio handler but I enter in it continuously even after deactivation of the transmitter. I don't know why, do you have ideas ?
