NUS connection problem
 I'm using nrf52840DK as a central device (sdk16 ble-app-uart-multilink-master) and my peripheral device is bt840 chip(sdk15.2 ble_app_uart_pca10056_s140).
My peripheral after connection sleep 10s and connect again. When the first connection i can connect the nus and than disconnect. Second connection to nus its not disconnect again(also in sleep mode bt840 use 4uA, in adv 220uA and in connection 100uA but when the broke after the second connection its use 3000uA, approximitly). What can be reason ?
The RTT of Central side.
First connection
00> <info> app: Device Address in addr process : 893473D394EE
00> <info> app: ***************************************** db : -36
00> <info> app: Start scanning for device name ind01
00> <info> app: Start scanning for device name ind02
00> <info> app: Start scanning for device name ind03
00> <info> app: Start scanning for device name ind04
00> <info> app: Start scanning for device name ind05
00> <info> app: Start scanning for device name ind06
00> <info> app: Start scanning for device name ind07
00> <info> app: ATT MTU exchange completed.
00> <info> app: Ble NUS max data length set to 0xF4(244)
00> <info> app: Discovery complete.
00> <info> app: Connected to device with Nordic UART Service.
00> <warning> ble_nus_c: Connection handle invalid.
00> <info> app: Disconnected.
00> <info> app: Disconnected. conn_handle: 0x0, reason: 0x13
After sleep 2. connection
00> <info> app: ***************************************** db : -37
Peripheral Code:
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 *  (Perhipheral)
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_drv_clock.h"
#include "nrf_section_iter.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_saadc.h"
#include "sensorsim.h"
static uint8_t  battery_lvl;
static uint16_t  battery_lvl_mV;
static uint8_t  adcval;
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "ind01"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                10000                                        /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
bool flag=0;
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                  /**< Advertising module instance. */
APP_TIMER_DEF(m_single_shot_timer_id);
APP_TIMER_DEF(m_single_shot_timer_id_2);
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS   600                                     /**< Reference voltage (in milli volts) used by ADC while doing conversion. */
#define ADC_PRE_SCALING_COMPENSATION    6                                       /**< The ADC is configured to use VDD with 1/3 prescaling as input. And hence the result of conversion is to be multiplied by 3 to get the actual value of the battery voltage.*/
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS  270                                     /**< Typical forward voltage drop of the diode . */
#define ADC_RES_10BIT                   1024                                    /**< Maximum digital value for 10-bit ADC conversion. */
static nrf_saadc_value_t adc_buf[2];
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
        ((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
APP_TIMER_DEF(m_battery_timer_id);                                      /**< Battery timer. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE},
    {BLE_UUID_BATTERY_SERVICE,            BLE_UUID_TYPE_BLE}
int rssi_val=0;
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
        nrf_saadc_value_t adc_result;
        uint16_t          batt_lvl_in_milli_volts;
        uint8_t           percentage_batt_lvl;
        uint32_t          err_code;
        adc_result = p_event->data.done.p_buffer[0];
        NRF_LOG_INFO("adc result : %d",adc_result);
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
        batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
                                  DIODE_FWD_VOLT_DROP_MILLIVOLTS;
        battery_lvl_mV=batt_lvl_in_milli_volts;
        NRF_LOG_INFO("bat_lvl_mv : %d",battery_lvl_mV);
        percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
        battery_lvl=percentage_batt_lvl;
static void adc_configure(void)
    ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
    nrf_saadc_channel_config_t config =
    NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
    err_code = nrf_drv_saadc_channel_init(0, &config);
    NRF_LOG_INFO("nrf_drv_saadc_channel_init : %d",err_code);
    err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
    NRF_LOG_INFO("nrf_drv_saadc_buffer_convert : %d",err_code);
    err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], 1);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in]   p_context   Pointer used for passing some arbitrary information (context) from the
 *                          app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    ret_code_t err_code;
    err_code = nrf_drv_saadc_sample();
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
static void send_data(void)
    char temp2[3];
    NRF_LOG_INFO("BATTERY LEVEL : %d ",battery_lvl);
    for(int j=0;j<3;j++)
      temp2[j]=(battery_lvl%10)+'0';
      battery_lvl=(battery_lvl/10);
    char temp3[4];
    NRF_LOG_INFO("BATTERY LEVEL mV : %d ",battery_lvl_mV);
    for(int j=0;j<4;j++)
      temp3[j]=(battery_lvl_mV%10)+'0';
      battery_lvl_mV=(battery_lvl_mV/10);
    char temp[3];
    rssi_val = abs(rssi_val);
    for (int i = 0;i<3;i++)
      temp[i] = (rssi_val%10)+'0';
      rssi_val=rssi_val/10;
    uint32_t err_code;
    uint16_t length =20;
    NRF_LOG_INFO("Start");
    uint8_t array[20];
    array[0] = 'i';
    array[1] = 'n';
    array[2] = 'd';
    array[3] = '0';
    array[4] = '2';
    array[5] = temp[2];
    array[6] = temp[1];
    array[7] = temp[0];
    array[8] = 'D';
    array[9] = 'b';
    array[10] = ' ';
    array[11] = temp2[2];
    array[12] = temp2[1];
    array[13] = temp2[0];
    array[14] = ' ';
    array[15] = temp3[3];
    array[16] = temp3[2];
    array[17] = temp3[1];
    array[18] = temp3[0];
    array[19] = '\n';
    NRF_LOG_INFO ("rssi %x", rssi_val);
    err_code = ble_nus_data_send(&m_nus, array, &length, m_conn_handle);
    NRF_LOG_INFO ("ble_nus_data_send returned 0x%x", err_code)
    if (err_code == 0x0){
    flag = 1;
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
    if (p_evt->type == BLE_NUS_EVT_COMM_STARTED){
      send_data();
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    ble_nus_init_t     nus_init;
    uint32_t err_code;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
NRF_LOG_INFO("1");
    nrf_drv_saadc_uninit();
    NRF_SAADC->INTENCLR = (SAADC_INTENCLR_END_Clear << SAADC_INTENCLR_END_Pos);
    NVIC_ClearPendingIRQ(SAADC_IRQn);
NRF_LOG_INFO("2");
    uint32_t err_code;
NRF_LOG_INFO("3");
    // Prepare wakeup buttons.
NRF_LOG_INFO("4");
NRF_LOG_INFO("5");
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            NRF_LOG_INFO("sleep2");
            sd_ble_gap_adv_stop(m_advertising.adv_handle);
            //m_conn_handle = BLE_CONN_HANDLE_INVALID;
            sd_ble_gap_rssi_stop(m_advertising.adv_handle);
            app_uart_close();
            *(volatile uint32_t *)0x40002FFC = 0;
            *(volatile uint32_t *)0x40002FFC;
            *(volatile uint32_t *)0x40002FFC = 1;
            err_code = app_timer_start(m_single_shot_timer_id, APP_TIMER_TICKS(10000), NULL);//sleep time(baglanamazsa)
           //sleep_mode_enter();
 void getDB()
uint32_t sd_ble_gap_rssi_start(  uint16_t 	conn_handle,
                                 uint8_t 	threshold_dbm,
                                 uint8_t 	skip_count );
uint32_t sd_ble_gap_rssi_get( uint16_t conn_handle,
                              int8_t *p_rssi,
                              uint8_t *p_ch_index);
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            sd_ble_gap_rssi_start( p_ble_evt->evt.gap_evt.conn_handle,10,0);
            int8_t rssi = 0;
            battery_level_meas_timeout_handler(p_context);
         case BLE_GAP_EVT_RSSI_CHANGED:
            rssi_val = p_ble_evt->evt.gap_evt.params.rssi_changed.rssi;
              //NRF_LOG_INFO("RSSI: %d",avr_db);
           /* c_avr_db++;
            avr_db = p_ble_evt->evt.gap_evt.params.rssi_changed.rssi;
            if(c_avr_db==3)
               NRF_LOG_INFO("RSSI: %d", (avr_db/5) );
               c_avr_db=0;
            sd_ble_gap_rssi_stop(p_ble_evt->evt.gap_evt.conn_handle);
            NRF_LOG_INFO("Disconnected");
            app_uart_close();
            err_code = app_timer_start(m_single_shot_timer_id_2, APP_TIMER_TICKS(10000), NULL);//baglanırsa adv aralıkları
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_TX_EMPTY:
            if(flag == 1){
           // sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            flag =0;
            APP_ERROR_HANDLER(p_event->data.error_communication);//uzunda yorum
        case APP_UART_FIFO_ERROR:
            APP_ERROR_HANDLER(p_event->data.error_code);//uzunda yorum
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    ble_gap_adv_params_t adv_params;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;//kısada general
    //advdata-srdata
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.config.ble_adv_primary_phy       = BLE_GAP_PHY_CODED;
    init.config.ble_adv_secondary_phy     = BLE_GAP_PHY_CODED;
    init.config.ble_adv_extended_enabled  = true;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
    UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    nrf_pwr_mgmt_run();
    //sd_app_evt_wait();
   /* err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, 8);
    APP_ERROR_CHECK(err_code);*/
static void single_shot_timer_handler(void * p_context)
    advertising_start();
    uart_init();*/
static void single_shot_timer_handler2(void * p_context)
    uart_init();*/
static void create_timers()
    // Create timers
    err_code = app_timer_create(&m_single_shot_timer_id,
                                APP_TIMER_MODE_SINGLE_SHOT,
                                single_shot_timer_handler);
    err_code = app_timer_create(&m_single_shot_timer_id_2,
                                single_shot_timer_handler2);
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    adc_configure();
    // Start execution.
    send_data();
    create_timers();
    // Enter main loop.
    for (;;)
        idle_state_handle();
Central Code:
 * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
 * (Central)
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "app_error.h"
#include "ble_db_discovery.h"
#include "app_util.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_nus_c.h"
#include "ble_conn_state.h"
#include "nrf_ble_scan.h"
//#include "addr_process.h"
#define APP_BLE_CONN_CFG_TAG    1                                       /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO   3                                       /**< BLE observer priority of the application. There is no need to modify this value. */
//#define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN            /**< UUID type for the Nordic UART Service (vendor specific). */
#define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
#define boyut 6
uint16_t addresArray[boyut];
 static int avr_db;
BLE_NUS_C_ARRAY_DEF(m_ble_nus_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);       /**< BLE Nordic UART Service (NUS) client instances. */
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_CENTRAL_LINK_COUNT);
//BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                        /**< BLE GATT Queue instance. */
               NRF_SDH_BLE_CENTRAL_LINK_COUNT,
               NRF_BLE_GQ_QUEUE_SIZE);
static char const m_target_periph1_name[] = "ind01";
static char const m_target_periph2_name[] = "ind02";
static char const m_target_periph3_name[] = "ind03";
static char const m_target_periph4_name[] = "ind04";
static char const m_target_periph5_name[] = "ind05";
static char const m_target_periph6_name[] = "ind06";
static char const m_target_periph7_name[] = "ind07";
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief NUS UUID.
static ble_uuid_t const m_nus_uuid =
    .uuid = BLE_UUID_NUS_SERVICE,
    .type = NUS_SERVICE_UUID_TYPE
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is only an example and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the Nordic UART Service Client errors.
static void nus_error_handler(uint32_t nrf_error)
/**@brief Function to start scanning. */
static void scan_start(void)
    ret_code_t ret;
    NRF_LOG_INFO("Start scanning for device name %s ", (uint32_t)m_target_periph1_name);
    NRF_LOG_INFO("Start scanning for device name %s ", (uint32_t)m_target_periph2_name);
    NRF_LOG_INFO("Start scanning for device name %s ", (uint32_t)m_target_periph3_name);
    NRF_LOG_INFO("Start scanning for device name %s ", (uint32_t)m_target_periph4_name);
    NRF_LOG_INFO("Start scanning for device name %s ", (uint32_t)m_target_periph5_name);
    NRF_LOG_INFO("Start scanning for device name %s ", (uint32_t)m_target_periph6_name);
    NRF_LOG_INFO("Start scanning for device name %s ", (uint32_t)m_target_periph7_name);
    ret = nrf_ble_scan_start(&m_scan);
    APP_ERROR_CHECK(ret);
    ret = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    switch(p_scan_evt->scan_evt_id)
         case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
              err_code = p_scan_evt->params.connecting_err.err_code;
         } break;
         case NRF_BLE_SCAN_EVT_CONNECTED:
              ble_gap_evt_connected_t const * p_connected =
                               p_scan_evt->params.connected.p_connected;
             addresArray[0] = p_connected->peer_addr.addr[0];
             addresArray[1] = p_connected->peer_addr.addr[1];
             addresArray[2] = p_connected->peer_addr.addr[2];
             addresArray[3] = p_connected->peer_addr.addr[3];
             addresArray[4] = p_connected->peer_addr.addr[4];
             addresArray[5] = p_connected->peer_addr.addr[5];
            // NRF_LOG_INFO("GET ADDR");
           //  NRF_LOG_INFO(sd_ble_gap_addr_get(&device_addr));
           /* NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                      p_connected->peer_addr.addr[0],
                      p_connected->peer_addr.addr[1],
                      p_connected->peer_addr.addr[2],
                      p_connected->peer_addr.addr[3],
                      p_connected->peer_addr.addr[4],
                addres_print(addresArray,boyut);
                NRF_LOG_INFO("***************************************** db : %d",avr_db);
         } break;
         case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
             NRF_LOG_INFO("Scan timed out.");
             scan_start();
         } break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER,m_target_periph1_name );
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER,m_target_periph2_name );
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER,m_target_periph3_name );
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER,m_target_periph4_name );
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER,m_target_periph5_name );
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER,m_target_periph6_name );
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER,m_target_periph7_name );
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c[p_evt->conn_handle], p_evt);
void getDB()
                              int8_t *p_rssi,
/**@brief Function for handling characters received by the Nordic UART Service (NUS).
 * @details This function takes a list of characters of length data_len and prints the characters out on UART.
 *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
        do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
    if (ECHOBACK_BLE_UART_DATA)
        for(int c = 0; c < NRF_SDH_BLE_CENTRAL_LINK_COUNT; c++)
            // Send data back to the peripheral.
            do
                ret_val = ble_nus_c_string_send(&m_ble_nus_c[c], p_data, data_len);
                if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY) && (ret_val != NRF_ERROR_INVALID_STATE))
                    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
 * @details This function receives a single character from the app_uart module and appends it to
 *          a string. The string is sent over BLE when the last character received is a
 *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
        /**@snippet [Handling data from UART] */
            index++;
                (index >= (m_ble_nus_max_data_len)))
                    do
                        ret_val = ble_nus_c_string_send(&m_ble_nus_c[c], data_array, index);
                        if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                    } while (ret_val == NRF_ERROR_RESOURCES);
                index = 0;
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling Nordic UART Service (NUS) client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
 * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
        case BLE_NUS_C_EVT_DISCONNECTED:
           // AddressDetect();
            NRF_LOG_INFO("Disconnected.");
            scan_start();
 * @brief Function for handling shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    int c_avr_db=0;
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c[p_ble_evt->evt.gap_evt.conn_handle], p_ble_evt->evt.gap_evt.conn_handle, NULL);
            // start discovery of services. The NUS Client waits for a discovery result
            err_code = ble_db_discovery_start(&m_db_disc[p_ble_evt->evt.gap_evt.conn_handle], p_ble_evt->evt.gap_evt.conn_handle);
            if (ble_conn_state_central_conn_count() < NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                // Resume scanning.
                scan_start();
           /* c_avr_db++;
            if(c_avr_db==3)
               c_avr_db=0;
            NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                         p_gap_evt->conn_handle,
                         p_gap_evt->params.disconnected.reason);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
            // Pairing not supported.
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    switch (event)
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
                err_code = sd_ble_gap_disconnect(m_ble_nus_c[c].conn_handle,
/**@brief Function for initializing the UART. */
        .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       err_code);
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler   = ble_nus_c_evt_handler;
    init.error_handler = nus_error_handler;
    init.p_gatt_queue  = &m_ble_gatt_queue;
        err_code = ble_nus_c_init(&m_ble_nus_c[c], &init);
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
    err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
/** @brief Function for initializing the database discovery module. */
static void db_discovery_init(void)
    ble_db_discovery_init_t db_init;
    memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
    db_init.evt_handler  = db_disc_handler;
    db_init.p_gatt_queue = &m_ble_gatt_queue;
    ret_code_t err_code = ble_db_discovery_init(&db_init);
 * @details Handles any pending log operations, then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
    // Initialize.
    log_init();
    timer_init();
    uart_init();
    buttons_leds_init();
    db_discovery_init();
    ble_stack_init();
    gatt_init();
    nus_c_init();
    ble_conn_state_init();
    scan_init();
    // Start execution.
    printf("BLE UART central example started.\r\n");
    NRF_LOG_INFO("BLE UART central example started.");
    scan_start();
    // Enter main loop.
    for (;;)
I suspect i miss something in peripheral side (case of BLE_ADV_EVT_IDLE or case of BLE_GAP_EVT_DISCONNECTED ).
    As the error message describes it, the central is calling ble_nus_c_string_send() with an invalid connection handle. Set a breakpoint where you call ble_nus_c_string_send() and check what the connection handle is.
    regards
    Jared
  • 00> <error> app: Failed sending NUS message. Error 0x9.
    00> <error> app: ERROR 9 [NRF_ERROR_INVALID_LENGTH]
    Is it cause of sending data length?
    connection handle is:
    00> <info> app: Disconnected. conn_handle: 0x0, reason: 0x8
     NRF_ERROR_INVALID_LENGTH is usually returned when you provide incorrect length of a parameter such as a buffer.
     You need to debug your code more thoroughly. I can tell based on the error log from your original problem statement that connection handle is invalid when you call ble_nus_c_string_send(). I can also see that you call this function two places in your code. I suggest that you actually check what the connection handle is, and if it has been properly assigned before you call ble_nus_c_string_send().
    regards
    Jared
