Hello
I use nrf52832 and sdk v17.0.
I'm testing the firmware using custom pcb. Sometimes it stops altogether if there is an error in the firmware during the test.
The pcb has a power button but it won't work if the firmware stops completely (A circuit diagram of the power part is attached below.)
So in this case, there is a problem that I have to disconnect the battery and turn it off.
Of course, I need to make sure that I don't have an error, but can I make the system reset if there is an unexpected error while running?
(Sending a LOW signal to the 'power hold' pin will turn off the power.)
Thank you.
