ZCL compliant thermostat typedef structs. nrfxlib commitment help needed.
I want to contribute to your nrfxlib development with the implementation of ZCL compliment typedefs for the thermostat cluster.
Can you give me some directions? Below I'm attaching a draft implementation based on ZCL specification.
On the other hand, can you explain please whats the purpose of 'void zb_zcl_thermostat_init(void);', `zb_zcl_thermostat_init_server` and `zb_zcl_thermostat_init_client`.
Another thing is the process of the contribution itself. Can you provide some guidance on how to prepare a merge request for your github repo? any specific requirements?
  • diff --git a/zboss/include/addons/zboss_api_zcl_addons.h b/zboss/include/addons/zboss_api_zcl_addons.h
    index b90d8f5..ef3265a 100644
    --- a/zboss/include/addons/zboss_api_zcl_addons.h
    +++ b/zboss/include/addons/zboss_api_zcl_addons.h
    @@ -18,5 +18,6 @@
     #include "zcl/zb_zcl_scenes_addons.h"
     #include "zcl/zb_zcl_on_off_addons.h"
     #include "zcl/zb_zcl_temp_measurement_addons.h"
    +#include "zcl/zb_zcl_thermostat_addons.h"
     #endif /* ZBOSS_API_ZCL_ADDONS_H__ */
    diff --git a/zboss/include/addons/zcl/zb_zcl_thermostat_addons.h b/zboss/include/addons/zcl/zb_zcl_thermostat_addons.h
    new file mode 100644
    index 0000000..96ec9b1
    --- /dev/null
    +++ b/zboss/include/addons/zcl/zb_zcl_thermostat_addons.h
    @@ -0,0 +1,66 @@
    + * Copyright (c) 2020 Nordic Semiconductor ASA
    + * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
    +#ifndef ZB_ZCL_THERMOSTAT_ADDONS_H__
    +#define ZB_ZCL_THERMOSTAT_ADDONS_H__
    +#include "zboss_api.h"
    +/*! \addtogroup zb_zcl_thermostat_addons */
    +/**@brief Thermostat Information cluster attributes according to ZCL Spec 6.3.2.2.1. */
    +typedef struct {
    +    zb_int16_t local_temperature;
    +    zb_int16_t outdoor_temperature;
    +    zb_uint8_t occupancy;
    +    zb_int16_t abs_min_heat_setpoint_imit;
    +    zb_int16_t abs_max_heat_setpoint_limit;
    +    zb_int16_t abs_min_cool_setpoint_limit;
    +    zb_int16_t abs_max_cool_setpoint_limit;
    +    zb_int16_t PI_cooling_demand;
    +    zb_int16_t PI_heating_demand;
    +    zb_uint8_t HVAC_system_type_configuration;
    +} zb_zcl_thermostat_info_attrs_t;
    +/**@brief Thermostat Settings cluster attributes according to ZCL Spec 6.3.2.2.2. */
    +typedef struct {
    +    zb_int8_t local_temperature_calibration;
    +    zb_int16_t occupied_cooling_setpoint;
    +    zb_int16_t occupied_heating_setpoint;
    +    zb_int16_t unoccupied_cooling_setpoint;
    +    zb_int16_t unoccupied_heating_setpoint;
    +    zb_int16_t min_heat_setpoint_limit;
    +    zb_int16_t max_heat_setpoint_limit;
    +    zb_int16_t min_cool_setpoint_limit;
    +    zb_int16_t max_cool_setpoint_limit;
    +    zb_int8_t min_setpoint_dead_band;
    +    zb_uint8_t remote_sensing;
    +    zb_uint8_t control_sequence_of_operation;
    +    zb_uint8_t system_mode;
    +    zb_uint8_t alarm_mask;
    +    zb_uint8_t thermostat_running_mode;
    +} zb_zcl_thermostat_settings_attrs_t;
    +/**@brief Thermostat Thermostat Schedule & HVAC Relay
    +   cluster attributes according to ZCL Spec 6.3.2.2.2. */
    +typedef struct {
    +    zb_uint8_t start_of_week;
    +    zb_uint8_t number_of_weekly_transitions;
    +    zb_uint8_t number_of_daily_transitions;
    +    zb_uint8_t temperature_setpoint_hold;
    +    zb_uint16_t temperature_setpoint_hold_ouration;
    +    zb_uint8_t thermostat_programming_operation_mode;
    +    zb_int16_t thermostat_running_state;
    +} zb_zcl_thermostat_schedule_and_HVAC_attrs_t;
    +#endif /* ZB_ZCL_THERMOSTAT_ADDONS_H__ */
    Thank you for providing this. I will forward it to our SDK team.
    Edvin
  • Ok, Zephyr automatic checks during merge request are so comprehensive, that all of my questions are outdated.
