Dear Members,
For scanning GSC10 sensor,
can this example be used ?
https://infocenter.nordicsemi.com/topic/sdk_nrf5_v17.0.2/ant_examples_scanning.html
Thanks
Dear Members,
Thanks
GSC10 sensor
A what ?
Garmin GSC10 , can I retrieve the information from it with ANT background scanning ?
How can I use this function ?
void background_scanner_process(ant_evt_t * p_ant_evt, void * p_context)
uint32_t err_code;
UNUSED_PARAMETER(p_context);
if (p_ant_evt->channel != ANT_BS_CHANNEL_NUMBER)
return;
switch (p_ant_evt->event)
case EVENT_RX:
err_code = bsp_indication_set(BSP_INDICATE_RCV_OK);
if (p_ant_evt->message.ANT_MESSAGE_stExtMesgBF.bANTDeviceID)
m_last_device_id = uint16_decode(p_ant_evt->message.ANT_MESSAGE_aucExtData);
if (p_ant_evt->message.ANT_MESSAGE_stExtMesgBF.bANTRssi)
m_last_rssi = p_ant_evt->message.ANT_MESSAGE_aucExtData[5];
NRF_LOG_INFO("Message number %d", m_recieved);
NRF_LOG_INFO("Device ID: %d", m_last_device_id);
NRF_LOG_INFO("RSSI: %d", m_last_rssi);
m_recieved++;
What value should I enter in that (ant_evt_t * p_ant_evt, void * p_context) ?
Thanks
If I want to see the value of Garmin GSC10 cadence and speed sensor, how can I retrieve it ? thanks
Hi Kenneth,
Please give me suggestion, which example should I use for scanning Garmin GSC10 ?
Thanks
It is not easy to provide a simple answer here, but here it goes:
Any of the master examples should show how you can scan for ANT devices, while ANT+ is "just" defined configuration and usage of an ANT channel. So if you know how to scan for an ANT device, then you can go to the ANT+ profile you are interested in to find the specific configuration you need to set for the ANT channel to "find" the ANT+ device you are in specific interested in. You need to register as an ANT+ adopter on www.thisisant.com to be able to support ANT+.
Hi Kenneth,
Thanks for the reply,
................ So if you know how to scan for an ANT device, then you can go to the ANT+ profile you are interested in to find the specific configuration you need to set for the ANT channel to "find" the ANT+ device you are in specific interested in................
Which file should I change to configure my ANT code talking with my Garmin GSC-10?
What's the configuration (channel, frequency and so on ) for Garmin GSC-10 ?
Where can I find ANT+ profile I'm are interested in ,which file in code example?
...........................You need to register as an ANT+ adopter on www.thisisant.com to be able to support ANT+...............
I have registered, what will I do from that registration ? I have put ANT key license on my code.
Thanks
What should I change here for pairing with Garmin GSC10?
https://www.thisisant.com/directory/gsc-10-speed-cadence-bike-sensor
const ant_channel_config_t ms_channel_config =
.channel_number = ANT_MS_CHANNEL_NUMBER,
.channel_type = CHANNEL_TYPE_MASTER,
.ext_assign = 0x00,
.rf_freq = RF_FREQ,
.transmission_type = CHAN_ID_TRANS_TYPE,
.device_type = CHAN_ID_DEV_TYPE,
.device_number = dev_num,
.channel_period = CHAN_PERIOD,
.network_number = ANT_NETWORK_NUM,
const ant_channel_config_t bs_channel_config =
.channel_number = ANT_BS_CHANNEL_NUMBER,
.channel_type = CHANNEL_TYPE_SLAVE,
.ext_assign = EXT_PARAM_ALWAYS_SEARCH,
.rf_freq = RF_FREQ,
.device_number = 0x00, // Wild card
.channel_period = 0x00, // This is not taken into account.
Thanks
.ext_assign = 0x00,
.rf_freq = RF_FREQ,
.rf_freq = RF_FREQ,
Thanks
