Background scanning ?
Dear Members,
For scanning GSC10 sensor,
can this example be used ?
https://infocenter.nordicsemi.com/topic/sdk_nrf5_v17.0.2/ant_examples_scanning.html
Thanks
  • If I want to see the value of Garmin GSC10 cadence and speed sensor, how can I retrieve it ? thanks
  • Hi Kenneth,
    Please give me suggestion, which example should I use for scanning Garmin GSC10 ?
    Thanks
  • It is not easy to provide a simple answer here, but here it goes:
    Any of the master examples should show how you can scan for ANT devices, while ANT+ is "just" defined configuration and usage of an ANT channel. So if you know how to scan for an ANT device, then you can go to the ANT+ profile you are interested in to find the specific configuration you need to set for the ANT channel to "find" the ANT+ device you are in specific interested in. You need to register as an ANT+ adopter on www.thisisant.com to be able to support ANT+.
  • Hi Kenneth,
    Thanks for the reply,
    ................ So if you know how to scan for an ANT device, then you can go to the ANT+ profile you are interested in to find the specific configuration you need to set for the ANT channel to "find" the ANT+ device you are in specific interested in................
    Which file should I change to configure my ANT code talking with my Garmin GSC-10?
    What's the configuration (channel, frequency and so on ) for Garmin GSC-10 ?
    Where can I find ANT+ profile I'm are interested in ,which file in code example?
    ...........................You need to register as an ANT+ adopter on www.thisisant.com to be able to support ANT+...............
    I have registered, what will I do from that registration ? I have put ANT key license on my code.
    Thanks
  • What should I change here for pairing with Garmin GSC10?
    https://www.thisisant.com/directory/gsc-10-speed-cadence-bike-sensor
     const ant_channel_config_t ms_channel_config =
            .channel_number    = ANT_MS_CHANNEL_NUMBER,
            .channel_type      = CHANNEL_TYPE_MASTER,
            .ext_assign        = 0x00,
            .rf_freq           = RF_FREQ,
            .transmission_type = CHAN_ID_TRANS_TYPE,
            .device_type       = CHAN_ID_DEV_TYPE,
            .device_number     = dev_num,
            .channel_period    = CHAN_PERIOD,
            .network_number    = ANT_NETWORK_NUM,
        const ant_channel_config_t bs_channel_config =
            .channel_number    = ANT_BS_CHANNEL_NUMBER,
            .channel_type      = CHANNEL_TYPE_SLAVE,
            .ext_assign        = EXT_PARAM_ALWAYS_SEARCH,
            .rf_freq           = RF_FREQ,
            .device_number     = 0x00,              // Wild card
            .channel_period    = 0x00,              // This is not taken into account.
    Thanks
