Trying to use nordic_nrf_temp in Zephyr open thread
I have the driver setup like all of the other sensor drivers I'm using, but I can't seem to find a device tree or Kconfig
This should be enabled by the CONFIG_SOC_NRF52840_QIAA=y enabling config HAS_HW_NRF_TEMP
Do I need something in the board overlay, dts or ????
#define TEMP_NODE DT_INST(0, nordic_nrf_temp)
#if DT_NODE_HAS_STATUS(TEMP_NODE, okay)
#define TEMP_LABEL DT_LABEL(TEMP_NODE)
#else
#error Your devicetree has no enabled nodes with compatible "nordic,nordic_nrf_temp"
#define TEMP_LABEL "<none>"
    const struct device *chip = device_get_binding(TEMP_LABEL);
    if (chip == NULL) {
        printk("No device Nordic nrf temp found; did initialization fail?\n");
    } else {
        printk("Found device Nordic nrf temp Thermistor\n");
        fchip = true;
      if (fchip) {
            ret = sensor_sample_fetch(chip);
            if (ret < 0) {
                printk("Chip Die temp Fetch error %d\n", ret);
            } else {
                struct sensor_value temp;
                sensor_channel_get(chip, SENSOR_CHAN_DIE_TEMP, &temp);
                printf("Chip die Temperature: %.2f C\n", sensor_value_to_double(&temp));
