Using GPS with SUPL sample in Asset Tracker application
I'm assuming AGPS in the Asset Tracker was designed to use nrf cloud.  I don't know if that will be suitable for production deployment at the moment.  The GPS with SUPL sample seems to work pretty well, so I'm trying to use that code in the Asset Tracker application.  In the Asset Tracker gps_handler(), it takes a struct gps_event, which is from \nrf\include\drivers\gps.h:
struct gps_event {
    enum gps_event_type type;
    union {
        struct gps_pvt pvt;
        struct gps_nmea nmea;
        struct gps_agps_request agps_request;
        enum gps_error error;
In the GPS sample, in order for supl_session() and inject_agps_type() to work, you use them with nrf_gnss_data_frame_t and nrf_gnss_agps_data_type_t data respectively, which are from \nrfxlib\bsdlib\include\nrf_socket.h:
/**@brief AGPS notification data frame used by the GPS module to let the application know it needs new APGS data. */
typedef struct
    uint32_t sv_mask_ephe; /**< Bit mask indicating the satellite PRNs for which the assistance GPS ephemeris data is needed. */
    uint32_t sv_mask_alm;  /**< Bit mask indicating the satellite PRNs for which the assistance GPS almanac data is needed. */
    uint32_t data_flags;   /**< Indicating other AGPS data models is needed by the GNSS module */
} nrf_gnss_agps_data_frame_t;
#define NRF_GNSS_PVT_DATA_ID  1
#define NRF_GNSS_NMEA_DATA_ID 2
#define NRF_GNSS_AGPS_DATA_ID 3
/**@brief Wrapper struct that used for all data frames read from the GNSS module */
typedef struct
    uint8_t data_id;
    union
        nrf_gnss_pvt_data_frame_t  pvt;  /**< PVT (Position, Velocity, and Time) data notification frame */
        nrf_gnss_nmea_data_frame_t nmea; /**< NMEA data notification frame */
        nrf_gnss_agps_data_frame_t agps; /**< AGPS data request notification */
} nrf_gnss_data_frame_t;
Both ways have a lot in common, but they're not compatible.  Is the Asset Tracker taking the GNSS data and repackaging it differently than the GPS sample?  Maybe I'm missing something.  Anyway, is there a way to make this work?  I want most of the framework of the Asset Tracker, but using the GPS with SUPL code.
  • Hi, Pete!
    Have you looked at the agps sample? It should show how you can use and external SUPL source for the aGPS. From what I can see the GPS driver is enabled to use aGPS(and SUPL) when configured to do so.
    Carl Richard
  • Hi again!
    Got back from the developers that it should be sufficient to add the following configs to prj.conf in the asset_tracker:
    CONFIG_NRF_CLOUD_AGPS=n
    CONFIG_AGPS_SRC_SUPL=y
    The required functions for SUPL will be setup "behind the scenes".
    Carl Richard
  • Hi!
    When using SUPL the GPS backend handles the calls. Nothing changes in the actual sample. If you are talking about the "gps_process_agps_data" function that is called on a CLOUD_EVT_DATA_RECEIVED event then you will see that it's implemented to do nothing if not using nRF Cloud AGPS.
    As the documentation states the sample communicates with the nRF Cloud for uploading data and controlling the device.  I did not try with your config, but got it working with the configs I referenced earlier.
    Did you try with the asset tracker?
    Carl Richard
  • Can it show any debug info?  I don't see any activity.  Does it do nothing until there's a fix?
    Which board did you try it with?
  • I tried the AGPS sample configured for SUPL with a DK board.  See attached log.  It eventually gets a fix, but if you compare where my custom board stops vs the DK, it suggests that it's being blocked on cloud calls.
    *** Booting Zephyr OS build v2.4.0-ncs1  ***
    Flash regions           Domain          Permissions
    00 00 0x00000 0x08000   Secure          rwxl
    01 31 0x08000 0x100000  Non-Secure      rwxl
    Non-secure callable region 0 placed in flash region 0 with size 32.
    SRAM region             Domain          Permissions
    00 07 0x00000 0x10000   Secure          rwxl
    08 31 0x10000 0x40000   Non-Secure      rwxl
    Peripheral              Domain          Status
    00 NRF_P0               Non-Secure      OK
    01 NRF_CLOCK            Non-Secure      OK
    02 NRF_RTC0             Non-Secure      OK
    03 NRF_RTC1             Non-Secure      OK
    04 NRF_NVMC             Non-Secure      OK
    05 NRF_UARTE1           Non-Secure      OK
    06 NRF_UARTE2           Secure          SKIP
    07 NRF_TWIM2            Non-Secure      OK
    08 NRF_SPIM3            Non-Secure      OK
    09 NRF_TIMER0           Non-Secure      OK
    10 NRF_TIMER1           Non-Secure      OK
    11 NRF_TIMER2           Non-Secure      OK
    12 NRF_SAADC            Non-Secure      OK
    13 NRF_PWM0             Non-Secure      OK
    14 NRF_PWM1             Non-Secure      OK
    15 NRF_PWM2             Non-Secure      OK
    16 NRF_PWM3             Non-Secure      OK
    17 NRF_WDT              Non-Secure      OK
    18 NRF_IPC              Non-Secure      OK
    19 NRF_VMC              Non-Secure      OK
    20 NRF_FPU              Non-Secure      OK
    21 NRF_EGU1             Non-Secure      OK
    22 NRF_EGU2             Non-Secure      OK
    23 NRF_DPPIC            Non-Secure      OK
    24 NRF_GPIOTE1          Non-Secure      OK
    25 NRF_REGULATORS       Non-Secure      OK
    SPM: NS image at 0xc000
    SPM: NS MSP at 0x2002ee30
    SPM: NS reset vector at 0x11769
    SPM: prepare to jump to Non-Secure image.
    I: A-GPS sample has started
    I: Connecting to LTE network. This may take minutes.
    I: PSM mode requested
    +CEREG: 2,"150D","00526D02",7,0,0,"11100000","11100000"
    +CSCON: 1
    +CEREG: 5,"150D","00526D02",7,,,"11100000","11100000"
    I: Connected to LTE network
    D: MAGPIO set: AT%XMAGPIO=1,0,0,1,1,1565,1586
    D: COEX0 set: AT%XCOEX0=1,1,1565,1586
    D: GPS socket created, fd: 1232491587
    I: CLOUD_EVT_CONNECTING
    I: CLOUD_EVT_CONNECTED
    I: CLOUD_EVT_PAIR_DONE
    E: Failed to save session state: -2
    I: CLOUD_EVT_READY
    I: Service info sent to cloud
    D: GPS mode is enabled
    D: GPS operational
    I: Periodic GPS search started with interval 240 s, timeout 120 s
    I: GPS_EVT_SEARCH_STARTED
    D: Waiting for time window to operate
    I: GPS_EVT_OPERATION_BLOCKED
    +CSCON: 0
    D: GPS has time window to operate
    I: GPS_EVT_OPERATION_UNBLOCKED
    D: Tracking: 0 Using: 0 Unhealthy: 0
    D: Seconds since last fix 18
    D: A-GPS data update needed
    I: GPS_EVT_AGPS_DATA_NEEDED
    D: Using GPS driver to input assistance data
    I: SUPL is initialized
    +CSCON: 1
    D: ip 173.194.79.192 (c04fc2ad) port 7276
    I: Starting SUPL session
    D: ULP encoding length: 39
    D: Bytes sent: 39
    D: Bytes received: 34
    D: ULP ossDecode success, choice 3
    D: SUPL server responded using version 2.0.4
    D: SUPL response received
    D: ULP encoding length: 58
    D: Bytes sent: 58
    D: Bytes received: 708
    D: ULP ossDecode more input 4
    D: Bytes received: 1416
    D: Bytes received: 2124
    D: Bytes received: 2832
    D: Bytes received: 3065
    D: ULP ossDecode success, choice 5
    D: Sent A-GPS data to modem, type: 1
    D: Injected AGPS data, type: 1, size: 16
    D: Sent A-GPS data to modem, type: 2
    D: Injected AGPS data, type: 2, size: 72
    D: Sent A-GPS data to modem, type: 3
    D: Injected AGPS data, type: 3, size: 32
    D: No integrity data available
    D: Sent A-GPS data to modem, type: 4
    D: Injected AGPS data, type: 4, size: 8
    D: Sent A-GPS data to modem, type: 7
    D: Injected AGPS data, type: 6, size: 144
    D: No location data available
    D: Sent A-GPS data to modem, type: 8
    D: Injected AGPS data, type: 7, size: 16
    D: MCC location info injected, MCC: 311
    D:      Lat: 4257684 Lon: -5241016
    D:      Unc semiminor: 127
    D:      Unc semimajor: 127
    D:      Confidence: 35
    D:      Orientation: 0
    D: SUPL POS received
    D: read again
    D: ULP ossDecode success, choice 6
    D: SUPLEND:
    D:      Mask: 0
    D:      Status: 0
    D: SUPL END received
    D: SUPL session internal resources released
    D: SUPL session finished
    I: SUPL session finished successfully
    +CSCON: 0
    D: Seconds since last fix 28
    D: Seconds since last fix 29
    D: Seconds since last fix 30
    D: Seconds since last fix 31
    D: Seconds since last fix 32
    D: Seconds since last fix 33
    D: Seconds since last fix 34
    I: Tracking: 8
    D: Tracking SV  8: not used,     healthy
    D: Tracking: 1 Using: 0 Unhealthy: 0
    D: Seconds since last fix 35
    D: Seconds since last fix 36
    D: Seconds since last fix 37
    D: Seconds since last fix 38
    D: Seconds since last fix 39
    D: Seconds since last fix 40
    D: Seconds since last fix 41
    D: Seconds since last fix 42
    D: Seconds since last fix 43
    D: Seconds since last fix 44
    I: Tracking: 8  30
    D: Tracking SV 30: not used,     healthy
    D: Tracking: 2 Using: 0 Unhealthy: 0
    D: Seconds since last fix 45
    D: Seconds since last fix 46
    D: Seconds since last fix 47
    I: Tracking: 8  27  30
    D: Tracking SV 27: not used,     healthy
    D: Tracking: 3 Using: 0 Unhealthy: 0
    D: Seconds since last fix 48
    D: Seconds since last fix 49
    D: Seconds since last fix 50
    D: Seconds since last fix 51
    I: Tracking: 8  27  28  30
    D: Tracking SV 28: not used,     healthy
    D: Tracking: 4 Using: 0 Unhealthy: 0
    D: Seconds since last fix 55
    D: GPS priority enabled
    D: Seconds since last fix 68
    D: Seconds since last fix 69
    D: Seconds since last fix 70
    D: Seconds since last fix 71
    D: Seconds since last fix 72
    D: Seconds since last fix 73
    D: Seconds since last fix 74
    I: Tracking: 8
    D: Seconds since last fix 75
    D: Seconds since last fix 76
    I: Tracking: 7  8
    D: Tracking SV  7: not used,     healthy
    D: Seconds since last fix 77
    D: Seconds since last fix 78
    D: Seconds since last fix 79
    D: Seconds since last fix 80
    D: Seconds since last fix 81
    I: Tracking: 7  8  9
    D: Tracking SV  9: not used,     healthy
    D: Seconds since last fix 82
    D: Seconds since last fix 83
    D: Seconds since last fix 84
    D: Seconds since last fix 85
    D: Seconds since last fix 86
    I: Tracking: 7  8  9  27
    D: Tracking SV  8:     used,     healthy
    D: Tracking SV  7:     used,     healthy
    D: Tracking SV  9:     used,     healthy
    D: Tracking: 4 Using: 3 Unhealthy: 0
    D: Seconds since last fix 87
    D: Seconds since last fix 88
    D: Seconds since last fix 89
    D: Seconds since last fix 90
    D: Seconds since last fix 91
    D: Seconds since last fix 92
    I: Tracking: 7  8  9  27  28
    D: Tracking SV 27:     used,     healthy
    D: Tracking: 5 Using: 4 Unhealthy: 0
    D: Seconds since last fix 93
    D: Seconds since last fix 94
    D: Seconds since last fix 95
    D: Seconds since last fix 96
    D: Seconds since last fix 97
    D: Seconds since last fix 98
    D: PVT: Position fix
    I: ---------       FIX       ---------
    I: Time to fix: 88 seconds
    I:
            Longitude:  -111.813017
            Latitude:   33.358843
            Altitude:   342.105499
            Speed:      0.074044
            Heading:    0.000000
            Date:       03-12-2020
            Time (UTC): 00:35:01
    I: -----------------------------------
    D: Tracking SV 28:     used,     healthy
    D: Tracking: 5 Using: 5 Unhealthy: 0
    D: Seconds since last fix 0
    D: NMEA: Position fix
    I: GPS position sent to cloud
    +CSCON: 1
    +CSCON: 0
  • Hi!
    I did indeed use the DK (v8.5.0) and saw the same behavior as you did for your DK. As mentioned the sample communicates with nRF Cloud for other purposes(control and location upload) so the device will have to connect to the cloud service. Have you made sure the custom board have the correct credentials and are registered for use with nRF Cloud?
    Carl Richard
  • Hi again!
    Got from the developers that if you want to test without nRF Cloud, just comment out the cloud stuff, call the relevant SUPL functions and start GPS right after.
    Carl Richard
