BLE Connect fail with Android-nRF-Toolbox
Dear Mr/Mrs,
I am learning to develop an Android BLE apk. I use the nRF Connect apk and Android-nRF-Toolbox to connect with my BLE device.
nRF Connect connect to the BLE device successfully while nRF Toolbox failed.
The mobile phone I used is Nova4 with Android OS 10.0.
the failed log is as following,
2020-11-30 14:55:35.611 5443-5443/no.nordicsemi.android.nrftoolbox I/HwViewRootImpl: removeInvalidNode all the node in jank list is out of time
2020-11-30 14:55:35.628 1320-8397/? W/ActivityManager: Receiver with filter android.content.IntentFilter@c1728bd already registered for pid 5443, callerPackage is no.nordicsemi.android.nrftoolbox
2020-11-30 14:55:35.628 5443-5443/no.nordicsemi.android.nrftoolbox I/BluetoothDevice: connectGatt
2020-11-30 14:55:43.485 5443-5479/no.nordicsemi.android.nrftoolbox W/BluetoothGatt: Unhandled exception in callback
java.lang.NullPointerException: Attempt to invoke virtual method 'void no.nordicsemi.android.nrftoolbox.ble.f.a(java.lang.String, int)' on a null object reference
at no.nordicsemi.android.nrftoolbox.ble.d$d.onConnectionStateChange(:730)
at android.bluetooth.BluetoothGatt$1$4.run(BluetoothGatt.java:279)
at android.bluetooth.BluetoothGatt.runOrQueueCallback(BluetoothGatt.java:793)
at android.bluetooth.BluetoothGatt.access$200(BluetoothGatt.java:41)
at android.bluetooth.BluetoothGatt$1.onClientConnectionState(BluetoothGatt.java:274)
at android.bluetooth.IBluetoothGattCallback$Stub.onTransact(IBluetoothGattCallback.java:192)
at android.os.Binder.execTransactInternal(Binder.java:1028)
at android.os.Binder.execTransact(Binder.java:1001)
I find that the nRF Connect does not call connectGatt method.
===== nRF Connect log ====
11-20 15:58:08.717 21503 21606 I bt_stack: [INFO:gatt_api.cc(961)] GATT_Register 0bb4b748-220d-7da0-ff81-8ca6d4fb1ff3
11-20 15:58:08.717 21503 21606 I bt_stack: [INFO:gatt_api.cc(981)] allocated gatt_if=8
11-20 15:58:08.739 3105 3696 D BtStatePassiveManager: btPassive save result is true
11-20 15:58:21.053 3189 3344 D BluetoothState: stop bt uid:10254 state:BLE_SCAN total(ms):22300
11-20 15:58:21.174 634 634 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x200000001,btStrd=4352,size=10256384,pid=634
11-20 15:58:21.188 634 634 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x200000001,btStrd=4352,size=10256384,pid=634
11-20 15:58:21.194 634 634 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x1,btStrd=2560,size=360448,pid=634
11-20 15:58:21.195 634 634 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x1,btStrd=2560,size=360448,pid=634
11-20 15:58:21.196 634 634 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x1,btStrd=2560,size=360448,pid=634
11-20 15:58:21.231 21503 21606 I bt_stack: [INFO:gatt_api.cc(961)] GATT_Register 56ab6932-7b1d-6557-21fe-5f602a6d5dbd
11-20 15:58:21.232 21503 21606 I bt_stack: [INFO:gatt_api.cc(981)] allocated gatt_if=8
11-20 15:58:21.241 21503 21606 I bt_stack: [INFO:gatt_api.cc(1119)] GATT_Connectgatt_if=8, address=ef:90:78:**:**:**
11-20 15:58:21.601 21503 21606 I bt_stack: [INFO:gatt_sr.cc(753)] MTU request PDU with MTU size 200
11-20 15:58:21.604 21503 21606 W bt_stack: [WARNING:gatt_utils.cc(745)] Call back not found for application conn_id=3
11-20 15:58:21.605 21503 21606 W bt_stack: [WARNING:gatt_utils.cc(745)] Call back not found for application conn_id=4
11-20 15:58:21.605 21503 21606 W bt_stack: [WARNING:gatt_utils.cc(745)] Call back not found for application conn_id=6
11-20 15:58:21.605 21503 21606 W bt_stack: [WARNING:gatt_utils.cc(745)] Call back not found for application conn_id=7
11-20 15:58:21.605 21503 21606 W bt_stack: [WARNING:gatt_utils.cc(745)] Call back not found for application conn_id=8
11-20 15:58:21.605 21503 21606 E bt_stack: [ERROR:bta_gattc_cache.cc(723)] bta_gattc_cache_load: can't open GATT cache file /data/misc/bluetooth/gatt_cache_ef9078563412 for reading, error: No such file or directory
11-20 15:58:21.606 21503 21606 I bt_stack: [INFO:hearing_aid.cc(1774)] GetDeviceCount: Not initialized yet
11-20 15:58:21.606 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=1, s_handle=0x0001, e_handle=0xffff
11-20 15:58:21.637 3105 3696 D Nc_Chr_BT: NcBtDftManager: bt ACL state old:2, new:1, date:2020-11-20 15:58:21
11-20 15:58:21.686 21503 21606 I bt_stack: [INFO:hearing_aid.cc(1774)] GetDeviceCount: Not initialized yet
11-20 15:58:23.208 634 634 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x1,btStrd=2304,size=323584,pid=634
11-20 15:58:23.211 634 634 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x1,btStrd=2304,size=323584,pid=634
11-20 15:58:23.217 634 14674 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x1,btStrd=2304,size=323584,pid=634
11-20 15:58:26.606 21503 21606 W bt_stack: [WARNING:gatt_utils.cc(595)] gatt_rsp_timeout retry discovery primary service
11-20 15:58:26.970 21503 21606 I bt_stack: [INFO:btsnoop.cc(464)] clear_l2cap_whitelist: Clearing whitelist from l2cap channel. conn_handle=0 cid=4:4
11-20 15:58:26.971 21503 21606 W bt_stack: [WARNING:l2c_ble.cc(177)] L2CA_EnableUpdateBleConnParams - unknown BD_ADDR ef:90:78:**:**:**
11-20 15:58:26.971 21503 21606 W bt_stack: [WARNING:bta_gattc_act.cc(1044)] bta_gattc_conn_cback: cif=3 connected=0 conn_id=0x0003 reason=0x0008
11-20 15:58:26.971 21503 21606 W bt_stack: [WARNING:bta_gattc_act.cc(1044)] bta_gattc_conn_cback: cif=4 connected=0 conn_id=0x0004 reason=0x0008
11-20 15:58:26.971 21503 21606 W bt_stack: [WARNING:bta_gattc_act.cc(1044)] bta_gattc_conn_cback: cif=6 connected=0 conn_id=0x0006 reason=0x0008
11-20 15:58:26.971 21503 21606 W bt_stack: [WARNING:bta_gattc_act.cc(1044)] bta_gattc_conn_cback: cif=7 connected=0 conn_id=0x0007 reason=0x0008
11-20 15:58:26.971 21503 21606 W bt_stack: [WARNING:bta_gattc_act.cc(1044)] bta_gattc_conn_cback: cif=8 connected=0 conn_id=0x0008 reason=0x0008
11-20 15:58:26.999 21503 21606 E bt_stack: [ERROR:bta_gattc_act.cc(293)] No such connection need to be cancelled
11-20 15:58:27.000 21503 21606 E bt_stack: [ERROR:bta_gattc_utils.cc(433)] bta_gattc_mark_bg_conn unable to find the bg connection mask for bd_addr=ef:90:78:**:**:**
11-20 15:58:27.059 3105 3696 D Nc_Chr_BT: NcBtDftManager: bt ACL state old:1, new:2, date:2020-11-20 15:58:27
11-20 15:58:27.070 3105 3696 E Nc_Chr_BT: NcBtDftManager: bt SCO state not changed, state:2
11-20 15:58:27.114 634 14674 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x1,btStrd=2304,size=323584,pid=634
11-20 15:58:27.115 634 634 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x1,btStrd=2304,size=323584,pid=634
11-20 15:58:27.116 634 634 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x1,btStrd=2304,size=323584,pid=634
11-20 15:58:38.232 21503 21606 I bt_stack: [INFO:gatt_api.cc(961)] GATT_Register 21efe26e-716f-8b15-2af6-69d4374e8fac
11-20 15:58:38.232 21503 21606 I bt_stack: [INFO:gatt_api.cc(981)] allocated gatt_if=8
11-20 15:58:38.239 21503 21606 I bt_stack: [INFO:gatt_api.cc(1119)] GATT_Connectgatt_if=8, address=ef:90:78:**:**:**
11-20 15:58:38.707 21503 21606 I bt_stack: [INFO:gatt_sr.cc(753)] MTU request PDU with MTU size 200
11-20 15:58:38.707 21503 21606 W bt_stack: [WARNING:gatt_utils.cc(745)] Call back not found for application conn_id=3
11-20 15:58:38.707 21503 21606 W bt_stack: [WARNING:gatt_utils.cc(745)] Call back not found for application conn_id=4
11-20 15:58:38.707 21503 21606 W bt_stack: [WARNING:gatt_utils.cc(745)] Call back not found for application conn_id=6
11-20 15:58:38.707 21503 21606 W bt_stack: [WARNING:gatt_utils.cc(745)] Call back not found for application conn_id=7
11-20 15:58:38.707 21503 21606 W bt_stack: [WARNING:gatt_utils.cc(745)] Call back not found for application conn_id=8
11-20 15:58:38.708 21503 21606 E bt_stack: [ERROR:bta_gattc_cache.cc(723)] bta_gattc_cache_load: can't open GATT cache file /data/misc/bluetooth/gatt_cache_ef9078563412 for reading, error: No such file or directory
11-20 15:58:38.708 21503 21606 I bt_stack: [INFO:hearing_aid.cc(1774)] GetDeviceCount: Not initialized yet
11-20 15:58:38.708 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=1, s_handle=0x0001, e_handle=0xffff
11-20 15:58:38.727 3105 3696 D Nc_Chr_BT: NcBtDftManager: bt ACL state old:2, new:1, date:2020-11-20 15:58:38
11-20 15:58:38.771 21503 21606 I bt_stack: [INFO:hearing_aid.cc(1774)] GetDeviceCount: Not initialized yet
11-20 15:58:38.863 634 634 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x1,btStrd=2304,size=323584,pid=634
11-20 15:58:38.866 634 634 I GRALLOC : getCallingPid=700, shrFd=12,fmt=0x1,intFmt=0x1,btStrd=2304,size=323584,pid=634
11-20 15:58:39.456 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=3, s_handle=0x0001, e_handle=0x000b
11-20 15:58:39.806 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=4, s_handle=0x0001, e_handle=0x000b
11-20 15:58:40.507 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=3, s_handle=0x000c, e_handle=0x000f
11-20 15:58:40.656 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=4, s_handle=0x000c, e_handle=0x000f
11-20 15:58:41.756 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=5, s_handle=0x000f, e_handle=0x000f
11-20 15:58:41.856 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=3, s_handle=0x0010, e_handle=0x0013
11-20 15:58:42.456 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=4, s_handle=0x0010, e_handle=0x0013
11-20 15:58:42.956 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=5, s_handle=0x0013, e_handle=0x0013
11-20 15:58:43.206 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=3, s_handle=0x0014, e_handle=0xffff
11-20 15:58:43.607 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=4, s_handle=0x0014, e_handle=0xffff
11-20 15:58:44.257 21503 21606 I bt_stack: [INFO:gatt_api.cc(647)] GATTC_Discover conn_id=0x0008, disc_type=5, s_handle=0x0019, e_handle=0xffff
11-20 15:58:44.758 21503 21606 I bt_stack: [INFO:bta_gattc_cache.cc(178)] bta_gattc_explore_srvc_finished: service discovery finished
11-20 15:58:44.773 21503 21606 I bt_stack: [INFO:hearing_aid.cc(1774)] GetDeviceCount: Not initialized yet
Could you please help me to analysis it? Thanks a lot!
