Hi everyone,
I'm starting from USBD example and I want to implement a composite device.
If I want to implement a composite device I have to add one interface and then the related descriptor, is it enough?
Thanks
BR
Hi everyone,
Thanks
BR
Hi
There is a composite example in the SDK showing how to add two different USB interfaces in the same example:
\nRF5_SDK_17.0.2_d674dde\examples\peripheral\usbd_hid_composite
The principle is the same for other USB classes (such as CDC or MSC), you just need to initialize multiple USB classes in the init phase.
You also need to ensure that you assign unique USB endpoints to the different classes, so there is no conflict.
As I mentioned in the other case I think it is important first to investigate if a composite device is really needed in your application. It might be a single CDC class is sufficient.
Best regards
Torbjørn
