I need to use nrf_dfu_settings.c to detect external firmware in Bank 1 during application boot. I also need to use Falsh Data Storage to save application parameters.
SDK version 17.0.2.
When compiling, I noticed conflicts with duplicated symbols :
fds.c :
NRF_FSTORAGE_DEF(nrf_fstorage_t m_fs) =
// The flash area boundaries are set in fds_init().
.evt_handler = fs_event_handler,
nrf_dfu_settings.c :
.evt_handler = dfu_fstorage_evt_handler,
.start_addr = MBR_SIZE,
.end_addr = BOOTLOADER_SETTINGS_ADDRESS + BOOTLOADER_SETTINGS_PAGE_SIZE
Temporarily, I modified the SDK but it's not a good practice :D Maybe I missed something...
This is my configuration in sdk_config.h :
// <i> NRF_FSTORAGE_SD uses the nrf_fstorage_sd backend implementation using the SoftDevice API. Use this if you have a SoftDevice present. // <i> NRF_FSTORAGE_NVMC uses the nrf_fstorage_nvmc implementation. Use this setting if you don't use the SoftDevice. // <1=> NRF_FSTORAGE_NVMC // <2=> NRF_FSTORAGE_SD #ifndef FDS_BACKEND #define FDS_BACKEND 2 #endif
Thanks for the help.
Thibaud
