Hello Tao,
What SDK version do you use?
Regardless you can check out the simple_coap_server and simple_coap_client examples, which will form a network. In the nRF5 SDK for Thread and Zigbee, it uses thread_instance_init() in main.c with .autocommissioning = true.
If that is not what you are looking for, please let me know.
Edvin
Hello Edvin,
The SDK version is "nRF5_SDK_for_Thread_and_Zigbee_v4.1.0_32ce5f8".
I am going to use OTBR to form a Thread network with the Thread device by commssioning. So if I use the method thread_instance_init() in main.c with .autocommissioning = true on the Thread device, where should I set pskd?
The process I want to implement is that I run the command on the OTBR.
ot-ctl commissioner start
ot-ctl commissioner joiner add eui64 pskd.
Then let the Thread device boot up and commissioning will be done automatically.
Best,
Tao
Try using otThreadSetPskc(). Description from thread_ftd.h:
/** * Set the Thread PSKc * * This function will only succeed when Thread protocols are disabled. A successful * call to this function will also invalidate the Active and Pending Operational Datasets in * non-volatile memory. * * @param[in] aInstance A pointer to an OpenThread instance. * @param[in] aPskc A pointer to the new Thread PSKc. * * @retval OT_ERROR_NONE Successfully set the Thread PSKc. * @retval OT_ERROR_INVALID_STATE Thread protocols are enabled. * * @sa otThreadGetPskc * */ otError otThreadSetPskc(otInstance *aInstance, const otPskc *aPskc);
Does it work if you don't add the pre shared key?
Try checking the OpenThread Border Router test description.
BR,
Edvin
