Hey all,
I have started working with this board around a month ago, and start to understand it little by little. I have a program that communicates with a display over UART. It works well when it is configured with UART 2 or 3. But when I try to configure with UART 1 it does not work. I did some reading on the forum and I found that you should add CONFIG_BSD_LIBRARY_TRACE_ENABLED=n in prj.conf but this also did nothing. So I would have just used UART 2 or 3 for the display, but this is also not an option because I have two other devices that use UART. And need 3 UART for the final system. The config file and overlay file are listed beneath. (UART 2 and 3 are config the same but I just change the number). Do you maybe know how to configure UART 1, or what I am doing wrong? NCS version: 1.3.0, Board: nrf9160dk_nrf9160 and I use SES V4.52.
.prj file:
CONFIG_SERIAL=y
CONFIG_SPI_1=n
CONFIG_I2C_1=n
overlay file:
&uart1 {
current-speed = <57600>;
status = "okay";
tx-pin = <19>;
rx-pin = <17>;
rts-pin = <0xFFFFFFFF>;
cts-pin = <0xFFFFFFFF>;
Thanks in advance for your time
