Hello
I'm trying to implement the click and double click and long click of a button in sdk v17.
Code for entering button.
int click_count; //check click or double click unsigned long timePress = 0; unsigned long timePressLimit = 0; static uint32_t pressed_time, released_time, pressed_duration = 0; static bool pressed_cnt= false; static uint32_t app_button_duration(void) //press time { pressed_duration = (released_time - pressed_time)*2; //ms return pressed_duration; } static void app_button_init_time_variable(void) { pressed_duration = 0; //press time } static void app_button_event_generator(void) //button press time { ret_code_t err_code; app_button_init_time_variable(); } static void app_button_event_handler(uint8_t pin_no, uint8_t button_action) { ret_code_t err_code; static uint32_t first_pressed; static uint32_t long_pressed; switch (pin_no) { case BUTTON_1: switch (button_action) { case APP_BUTTON_PUSH: { NRF_LOG_INFO("Button pressed..."); printf("Button pressed"); //get pressed time pressed_time = app_timer_cnt_get()*1000/32768;//milli-sec NRF_LOG_INFO("pressed_time: %d", (int)pressed_time); printf("pressed_time: %d\n", (int)pressed_time); pressed_cnt = true; PowerOff_timers_start(); //press timer count if(click_count == 0) //first click { printf("One click\n"); timePress = app_timer_cnt_get()*1000/32768; timePressLimit = timePress + 500; //time press + 0.5sec click_count = 1; } else if(click_count == 1 && app_timer_cnt_get()*1000/32768 < timePressLimit) // double click, click time < timePressLimit { printf("Double Click!\n"); //set variables back to 0 timePress = 0; timePressLimit = 0; click_count = 0; } if(click_count == 1 && timePressLimit != 0 && app_timer_cnt_get()*1000/32768 > timePressLimit) //second click but time's up { printf("One click\n"); //set variables back to 0 timePress = 0; timePressLimit = 0; click_count = 0; } } break; case APP_BUTTON_RELEASE: { NRF_LOG_INFO("Button releaed..."); if (pressed_cnt) { released_time = app_timer_cnt_get()*1000/32768; //milli-sec NRF_LOG_INFO("released_time: %d", (int)released_time); printf("released_time: %d\n", (int)released_time); } pressed_cnt = false; PowerOff_timers_stop(); } break; } break; default: APP_ERROR_HANDLER(pin_no); break; } if(app_button_duration()) { app_button_event_generator(); } app_button_init_time_variable(); } static void app_buttons_init(void) { uint32_t err_code; static const app_button_cfg_t app_buttons[BUTTONS_NUMBER] = { {BUTTON_1, false, BUTTON_PULL, app_button_event_handler}, }; err_code = app_button_init((app_button_cfg_t *)app_buttons, BUTTONS_NUMBER, // 1 APP_TIMER_TICKS(50)); //debounce APP_ERROR_CHECK(err_code); }
But there are two problems with this code.
1. Double-click will stop the board. (A single click or long push seems fine.)
2. When I click a button, I must be able to determine whether it is a single click or a double click. However, this code also executes a single click code when double-click.
(There should be time to wait for the next button after pressing the button to determine if there is a double click)
When debugging, double click to print the following error in the terminal.
<info> app: 13 <info> app: 14 <info> app: 12 <info> app: 12 <info> app: 12 <info> app: 13 <info> app: 14 <info> app: 12 <info> app: 12 <info> app: 12 <info> app: 13 <info> app: 14 <info> app: 12 <info> app: 12 <info> app: 12 <info> app: 13 <info> app: 14 <info> app: 12 <info> app: 12 <info> app: 12 <info> app: 13 <info> app: 14 <info> app: 12 <info> app: 12 <info> app: 12 <info> app: Button pressed... <info> app: pressed_time: 8572 <info> app: Button releaed... <info> app: released_time: 8598 <info> app: 11 <info> app: 9 <info> app: 10 <info> app: 10 <info> app: 12 <info> app: 11 <info> app: 9 [1;31mLogs dropped (1)[0m <info> app: 10 [1;31mLogs dropped (1)[0m <info> app: 10 [1;31mLogs dropped (1)[0m <info> app: 12 [1;31mLogs dropped (1)[0m <info> app: 11 [1;31mLogs dropped (1)[0m <info> app: 9 [1;31mLogs dropped (1)[0m <info> app: 10 [1;31mLogs dropped (1)[0m <info> app: 10 [1;31mLogs dropped (1)[0m <info> app: 12 [1;31mLogs dropped (1)[0m <info> app: 11
Can I know the cause of this error and what I can refer to about double-click?
