im getting debug error in my code . please try to slove this . coding on ble.dfu.buttonless.app update with nrf52810 using ses
 * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
/** @example examples/ble_peripheral/ble_app_buttonless_dfu
 * @brief Secure DFU Buttonless Service Application main file.
 * This file contains the source code for a sample application using the proprietary
 * Secure DFU Buttonless Service. This is a template application that can be modified
 * to your needs. To extend the functionality of this application, please find
 * locations where the comment "// YOUR_JOB:" is present and read the comments.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nrf_dfu_ble_svci_bond_sharing.h"
#include "nrf_svci_async_function.h"
#include "nrf_svci_async_handler.h"
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "ble_conn_state.h"
#include "ble_dfu.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "fds.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_clock.h"
#include "nrf_power.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_bootloader_info.h"
#define DEVICE_NAME                     "Nordic_Buttonless"                         /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                300                                         /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)            /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)            /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                            /**< Handle of the current connection. */
static void advertising_start(bool erase_bonds);                                    /**< Forward declaration of advertising start function */
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}};
/**@brief Handler for shutdown preparation.
 * @details During shutdown procedures, this function will be called at a 1 second interval
 *          untill the function returns true. When the function returns true, it means that the
 *          app is ready to reset to DFU mode.
 * @param[in]   event   Power manager event.
 * @retval  True if shutdown is allowed by this power manager handler, otherwise false.
static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_DFU:
            NRF_LOG_INFO("Power management wants to reset to DFU mode.");
            // YOUR_JOB: Get ready to reset into DFU mode
            // If you aren't finished with any ongoing tasks, return "false" to
            // signal to the system that reset is impossible at this stage.
            // Here is an example using a variable to delay resetting the device.
            // if (!m_ready_for_reset)
            //      return false;
            // else
            //    // Device ready to enter
            //    uint32_t err_code;
            //    err_code = sd_softdevice_disable();
            //    APP_ERROR_CHECK(err_code);
            //    err_code = app_timer_stop_all();
            // YOUR_JOB: Implement any of the other events available from the power management module:
            //      -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
            //      -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
            //      -NRF_PWR_MGMT_EVT_PREPARE_RESET
            return true;
    NRF_LOG_INFO("Power management allowed to reset to DFU mode.");
    return true;
//lint -esym(528, m_app_shutdown_handler)
/**@brief Register application shutdown handler with priority 0.
NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context)
    if (state == NRF_SDH_EVT_STATE_DISABLED)
        // Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
        nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
        //Go to system off.
        nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
/* nrf_sdh state observer. */
NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) =
    .handler = buttonless_dfu_sdh_state_observer,
static void advertising_config_get(ble_adv_modes_config_t * p_config)
    memset(p_config, 0, sizeof(ble_adv_modes_config_t));
    p_config->ble_adv_fast_enabled  = true;
    p_config->ble_adv_fast_interval = APP_ADV_INTERVAL;
    p_config->ble_adv_fast_timeout  = APP_ADV_DURATION;
static void disconnect(uint16_t conn_handle, void * p_context)
    UNUSED_PARAMETER(p_context);
    ret_code_t err_code = sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    if (err_code != NRF_SUCCESS)
        NRF_LOG_WARNING("Failed to disconnect connection. Connection handle: %d Error: %d", conn_handle, err_code);
        NRF_LOG_DEBUG("Disconnected connection handle %d", conn_handle);
// YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
/**@brief Function for handling dfu events from the Buttonless Secure DFU service
 * @param[in]   event   Event from the Buttonless Secure DFU service.
static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
    switch (event)
        case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
            NRF_LOG_INFO("Device is preparing to enter bootloader mode.");
            // Prevent device from advertising on disconnect.
            ble_adv_modes_config_t config;
            advertising_config_get(&config);
            config.ble_adv_on_disconnect_disabled = true;
            ble_advertising_modes_config_set(&m_advertising, &config);
            // Disconnect all other bonded devices that currently are connected.
            // This is required to receive a service changed indication
            // on bootup after a successful (or aborted) Device Firmware Update.
            uint32_t conn_count = ble_conn_state_for_each_connected(disconnect, NULL);
            NRF_LOG_INFO("Disconnected %d links.", conn_count);
        case BLE_DFU_EVT_BOOTLOADER_ENTER:
            // YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
            //           by delaying reset by reporting false in app_shutdown_handler
            NRF_LOG_INFO("Device will enter bootloader mode.");
        case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
            NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
            // YOUR_JOB: Take corrective measures to resolve the issue
            //           like calling APP_ERROR_CHECK to reset the device.
        case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
            NRF_LOG_ERROR("Request to send a response to client failed.");
            APP_ERROR_CHECK(false);
            NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    uint32_t err_code = app_timer_init();
    // Create timers.
    /* YOUR_JOB: Create any timers to be used by the application.
                 Below is an example of how to create a timer.
                 For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                 one.
       uint32_t err_code;
       err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
       APP_ERROR_CHECK(err_code); */
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    uint32_t                err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    /* YOUR_JOB: Use an appearance value matching the application's use case.
       err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
 * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
 * @details This function will be called for all YY Service events which are passed to
 *          the application.
 * @param[in]   p_yy_service   YY Service structure.
 * @param[in]   p_evt          Event received from the YY Service.
   static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                          ble_yy_service_evt_t * p_evt)
    switch (p_evt->evt_type)
        case BLE_YY_NAME_EVT_WRITE:
            APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
            // No implementation needed.
    uint32_t                  err_code;
    nrf_ble_qwr_init_t        qwr_init  = {0};
    ble_dfu_buttonless_init_t dfus_init = {0};
    dfus_init.evt_handler = ble_dfu_evt_handler;
    err_code = ble_dfu_buttonless_init(&dfus_init);
    /* YOUR_JOB: Add code to initialize the services used by the application.
       uint32_t                           err_code;
       ble_xxs_init_t                     xxs_init;
       ble_yys_init_t                     yys_init;
       // Initialize XXX Service.
       memset(&xxs_init, 0, sizeof(xxs_init));
       xxs_init.evt_handler                = NULL;
       xxs_init.is_xxx_notify_supported    = true;
       xxs_init.ble_xx_initial_value.level = 100;
       err_code = ble_bas_init(&m_xxs, &xxs_init);
       // Initialize YYY Service.
       memset(&yys_init, 0, sizeof(yys_init));
       yys_init.evt_handler                  = on_yys_evt;
       yys_init.ble_yy_initial_value.counter = 0;
       err_code = ble_yy_service_init(&yys_init, &yy_init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for starting timers.
static void application_timers_start(void)
    /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
       uint32_t err_code;
       err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
    // Prepare wakeup buttons.
    //Disable SoftDevice. It is required to be able to write to GPREGRET2 register (SoftDevice API blocks it).
    //GPREGRET2 register holds the information about skipping CRC check on next boot.
    err_code = nrf_sdh_disable_request();
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code = NRF_SUCCESS;
        case BLE_GAP_EVT_CONNECTED:
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init()
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/** @brief Clear bonding information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
 * @param[in]   event   Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
            break; // BSP_EVENT_SLEEP
        case BSP_EVENT_DISCONNECT:
            break; // BSP_EVENT_DISCONNECT
        case BSP_EVENT_WHITELIST_OFF:
            break; // BSP_EVENT_KEY_0
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    advertising_config_get(&init.config);
    uint32_t err_code;
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
/**@brief Function for the Power manager.
static void log_init(void)
    uint32_t err_code = NRF_LOG_INIT(NULL);
/**@brief   Function for initializing the GATT module.
 * @details The GATT module handles ATT_MTU and Data Length update procedures automatically.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        NRF_LOG_DEBUG("advertising is started");
    uint32_t err_code = nrf_pwr_mgmt_init();
        nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
    bool       erase_bonds;
  log_init();
    // Initialize the async SVCI interface to bootloader before any interrupts are enabled.
      err_code = ble_dfu_buttonless_async_svci_init();
     timers_init();
    power_management_init();
    ble_stack_init();
    peer_manager_init();
    gap_params_init();
   gatt_init();
   advertising_init();
    services_init();
   conn_params_init();
    NRF_LOG_INFO("Buttonless DFU Application started.");
     //Start execution.
   application_timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
