I am trying to send an add_group_request to a device on the network, and want to capture the send status of the device to check the status of the call. I am doing this by assigning a callback function add_group_callback() to the ZB_ZCL_GROUPS_SEND_ADD_GROUP_REQ() function, as below:
ZB_ZCL_GROUPS_SEND_ADD_GROUP_REQ(bufid,
dst_addr,
ZB_APS_ADDR_MODE_16_ENDP_PRESENT,
dst_ep,
LIGHT_SWITCH_ENDPOINT,
ZB_AF_HA_PROFILE_ID,
ZB_ZCL_DISABLE_DEFAULT_RESPONSE,
add_group_callback,
group);
The command works just fine, and I am able to add the group to the receiving device's grouping table. However I just need some reassurance as to how I am supposed to parse the callback parameter.
I am currently trying to use the zb_buf_get_status() function in order to extract the status directly from the bufid, as below. This gives me a status of 0, which seems to make sense.
static zb_void_t add_group_callback(zb_bufid_t bufid) {
zb_uint16_t status_buf = zb_buf_get_status(bufid);
NRF_LOG_INFO("Add group status buff %d", status_buf);
if (bufid)
zb_buf_free(bufid);
My 3 questions are:
- Is the above method the correct way of getting the send status?
- I would like to capture the response of the device which receives the add_group_req command. How would I go about doing this? I am sure it will have something to do with the ZB_ZCL_GROUPS_GET_ADD_GROUP_RES() command, but I am not sure how to use it.
- Could you point me to a list of status codes and their meaning?
Thank you very much for your time,
Angry Oatmeal.
