Hello
We are developing a unit, based on nRF9160.
In that design LTE switch QM12038 is used.
The manufacturer Qovro has stopped production, so now we are looking for a replacement.
We like to support different frequencies, but do not need GPS, so a switch with 6 channels would be sufficient.
So far we found: Qovro QPC6064 SP6T and infineon BGS18GA14 SP8T.
The LTE is mostly OFF, when it is not charging the battery, and LTE is active when it is charging.
1. Can these circuits do the job?
2. Does the mux work both as TX & RX in these circuits? ( Many filters, one antenna )
3. Which would suit our need best, low power when OFF, low power consumptions and minimal change to the control software. We run the system on 3V3 volt only!
Regards
/Martin
