Central connection with password
Hello.
My application serve as a central that connect to device by its name. I use the example \ble_central\ble_app_uart_c
On the device side I have password for connecting.
I want to connect only to device that has the require password.
I know on phone I do it by hand and type the password.
But how can I do it in the nRF52840 automatically?
Is there a place to write the require password , and what setting I have to add to the central to use that password when connect?
Thanks
Bar.
  • Thanks Sigurd.
    I get progress and place the events and the request according the link you gave me.
    static void _blenus_ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context)
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
           // signaling connection
            for(uint8_t s=0;s<4;s++)
                nrf_gpio_pin_set(41);// Green LED
                nrf_delay_ms(500);
                nrf_gpio_pin_clear(41);
    //            err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
    //            APP_ERROR_CHECK(err_code);
                NRF_LOG_INFO("Disconnected");
    			_driver_bundle->G.is_connected = 0u;
                // signaling disconnection
                    nrf_gpio_pin_set(9);// Red LED
                    nrf_delay_ms(500);
                    nrf_gpio_pin_clear(9);
                if(!_driver_bundle->PHY.if_scan)// if not central
                    if(_driver_bundle->G.is_bonded){
                    // Change advertising mode to whitelist advertising
                    sd_ble_gap_adv_stop(m_advertising.adv_handle);
                    _blenus_advertising_init();
                    ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
                else // if central need to told the PC on disconnect and doesn't connect again automaticly
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
    		case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
    			NRF_LOG_DEBUG("Connection interval request: [%d, %d]",
    				p_ble_evt->evt.gap_evt.params.conn_param_update_request.conn_params.min_conn_interval,
    				p_ble_evt->evt.gap_evt.params.conn_param_update_request.conn_params.max_conn_interval);
            case BLE_GAP_EVT_CONN_PARAM_UPDATE:
    			NRF_LOG_DEBUG("Connection interval: [%d, %d]",
    				p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.min_conn_interval,
    				p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.max_conn_interval);
    //		case PM_EVT_CONN_SEC_SUCCEEDED:
    //        	// Sent after the connection has been secured,
    //        	NRF_LOG_INFO("Bonded successfully");
    //        	_driver_bundle->G.is_bonded = true;
    //        	pm_whitelist_set(&(p_evt->peer_id), 1);
    //        	pm_sec_params_set(NULL);	// Disallow new bonds
    //        	break;
                // Pairing not supported
    //            err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
    //            err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0);
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
            case BLE_GAP_EVT_AUTH_KEY_REQUEST:// request to send a keypass which write in teh periph
                    NRF_LOG_INFO("Request password from central");
                    err_code = sd_ble_gap_auth_key_reply(m_conn_handle,BLE_GAP_AUTH_KEY_TYPE_PASSKEY ,_driver_bundle->PHY.passkey);
            case BLE_GAP_EVT_CONN_SEC_UPDATE: // when accept the keypass the central send to the periph
                   NRF_LOG_INFO("accept the password from central");
            case BLE_GAP_EVT_AUTH_STATUS: // seccuss connect to periph with passkey
                   NRF_LOG_INFO("seccuss connect with password");
                    nrf_gpio_pin_set(12);// Blue LED
                    nrf_delay_ms(500);
                    nrf_gpio_pin_clear(12);
                // No implementation needed.
    I get the connection and after it it just jump to the gatt and set thing there also my peripheral has a keypass enable and request its identical (we use it against phone where it request it there).
    Here are the my debug terminal during connection process
     [0m[00:00:00.000,000] <debug> ble_scan: Connecting[0m
    [0m[00:00:00.000,000] <debug> ble_scan: Connection status: 0[0m
    [0m[00:00:00.000,000] <debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0.[0m
    [0m[00:00:00.000,000] <debug> nrf_ble_gatt: Updating data length to 251 on connection 0x0.[0m
    [1;32m[00:00:00.000,000] <info> blenus: Connected[0m
    [0m[00:00:00.000,000] <debug> nrf_ble_gatt: Peer on connection 0x0 requested an ATT MTU of 247 bytes.[0m
    [0m[00:00:00.000,000] <debug> nrf_ble_gatt: Updating ATT MTU to 247 bytes (desired: 247) on connection 0x0.[0m
    [0m[00:00:00.000,000] <debug> nrf_ble_gatt: ATT MTU updated to 247 bytes on connection 0x0 (response).[0m
    [1;32m[00:00:00.000,000] <info> blenus: Data len is set to 0xF4(244)[0m
    [0m[00:00:00.000,000] <debug> blenus: ATT MTU exchange completed. central 0xF7 peripheral 0xF7[0m
    [0m[00:00:00.000,000] <debug> nrf_ble_gatt: max_rx_octets: 251[0m
    [0m[00:00:00.000,000] <debug> nrf_ble_gatt: max_tx_octets: 251[0m
    [0m[00:00:00.000,000] <debug> nrf_ble_gatt: max_rx_time: 2120[0m
    It doesn't get to
    Is there any more setting I need to do at the central init in the peer_manager to let him know it should also wait for passkey change?
    Thanks
    Bar.
    Typically you initialize the Peer Manager like shown in the snippet below. Try to set SEC_PARAM_IO_CAPABILITIES to BLE_GAP_IO_CAPS_KEYBOARD_ONLY on the central.
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        ret_code_t err_code;
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    See "Passkey bonding with keyboard capabilities:" at this link: https://infocenter.nordicsemi.com/topic/sdk_nrf5_v17.0.2/lib_pm_usage.html#lib_pm_usage_security
  • Hello.
    I follow the prievies answer.
    I found that compare to the link you specifay before https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.s140.api.v7.2.0%2Fgroup___b_l_e___g_a_p___c_e_n_t_r_a_l___b_o_n_d_i_n_g___p_k___p_e_r_i_p_h___o_o_b___m_s_c.html
    I need to use event also from the pm handle. For example instead of  BLE_GAP_EVT_SEC_PARAMS_REQUEST I see I get event PM_EVT_CONN_SEC_PARAMS_REQso I need to use pm_conn_sec_params_reply.
    I also use the pm_peers_delete(); but on run every time it told me it connect to all ready bond unit. After that in get to disconnect by BLE_GAP_EVT_DISCONNECTED:
    attach the log (use the Insert->code)
    [00:00:00.000,000] <info> blenus: Setting BLE scan init filter name is WizmiPixi_18BD22
    [00:00:00.000,000] <debug> ble_scan: Scanning
    [00:00:00.000,000] <info> blenus:  BLE scan start with error 0x0
    [00:00:00.000,000] <debug> peer_manager_handler: Connected, securing connection. conn_handle: 0
    [00:00:00.000,000] <info> blenus: Request for secure parameters from central.
    [00:00:00.000,000] <info> blenus: Start secure connection.
    [00:00:00.000,000] <info> blenus: Connected to a previously bonded device.
    [00:00:00.000,000] <warning> blenus: Failed to secure
    So I don't know why after connect it disconnect from the device.
    Any hint where to look for?
    Bar.
  • I do some more work around it.
    1. I block on the BLE event BLE_GAP_EVT_SEC_PARAMS_REQUEST so it only get replay from PM_EVT_CONN_SEC_PARAMS_REQ with pm_conn_sec_params_reply, because when both was open it get first to the PM event and then to the BLE evt by on relay get err = 0x08
    NRF_ERROR_INVALID_STATE.
    THen I add those 3 function at start of PM event handler copy from rscs App
    pm_handler_on_pm_evt(p_evt);
    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    So I get also more LOG information and 2 of the PM event handle here.
    The next print is the log I get on my run when try to connect to device with the request name (filter by name).
    It is look that it get almost till the end by PM_EVT_PEER_DATA_UPDATE_SUCCEEDED event but then from nowhere I get to BLE  event BLE_GAP_EVT_DISCONNECTED.
    I also write all the BLE unhandled event  and I get at the end 2 which not part of the BLE_GAP_EVTS enum
    <debug> blenus: Unhandled BLE event 0x35
    <debug> blenus: Unhandled BLE event 0x36
    It is far away from the list I have around 55 where the enum get only till 38. What events are those?
    <info> blenus: BLE Connected
    <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_PARAMS_REQ
    <debug> peer_manager_handler: Security parameter request
    <info> blenus: PM Request for secure parameters from central.
    <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_START
    <debug> blenus: Unhandled BLE event 0x55
    <debug> blenus: Unhandled BLE event 0x13
    <info> blenus: BLE Request password from central
    <info> blenus: BLE accept the password from central
    <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_SUCCEEDED
    <info> peer_manager_handler: Connection secured: role: Central, conn_handle: 0, procedure: Bonding
    <debug> peer_manager_handler: pm_peer_rank_highest() returned NRF_ERROR_NOT_SUPPORTED for peer id 0
    <info> blenus: PM Connection secured: role: Central, conn_handle: 0, procedure: Bonding, Peer ID: 0
    <debug> peer_manager_handler: Event PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Bonding data, action: Update
    <info> blenus: PM New Bond, add the peer to the whitelist if possible
    <info> blenus: m_whitelist_peer_cnt 2, MAX_PEERS_WLIST 8
    <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Central address resolution, action: Update
    For ble_app_uart_c code with passkey and Peer Manger, you can find some example code here:
    https://devzone.nordicsemi.com/f/nordic-q-a/44658/communication-problems-between-ble_peripheral-and-ble_central-in-nrf52-project
     If it's in hex, then it's BLE_GATTC_EVT_CHAR_VAL_BY_UUID_READ_RSP and BLE_GATTC_EVT_READ_RSP
    If it's in dec, then it's BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST and BLE_GAP_EVT_DATA_LENGTH_UPDATE.
