nRF51822 FLASH Erase while in a connection
Hi everybody, i am working with a nrf51822. S110 with sdk6.1 IDE:keil
I want to do FLASH Erase while in a connection. I have read this page devzone.nordicsemi.com/.../ and found out that the fail is related to the connection interval.It have to sufficiently long for flash to erase. I changed the value of MAX_CONN_INTERVAL to 100 (125ms),but it doesn't work at all. Please ,does anyone have any suggestion for this question ?Thank you for any help.
below is my code int main(void) {
static uint8_t index = 0;
uint8_t index_backup = 0;
uint8_t newbyte;
	leds_init();//BLE LED
    timers_init();
	buttons_init();
    uart_init();
	ble_stack_init();
	gap_params_init();
	services_init();
	advertising_init();
    conn_params_init();
    sec_params_init();
     //advertising_start();
uint32_t *addr;
uint8_t   patwr;
uint8_t   patrd;
uint8_t   patold;
uint32_t  i;
uint32_t  pg_size;
uint32_t  pg_num;
init();//gpio read port and output port
patold  = 0;
pg_size = NRF_FICR->CODEPAGESIZE;
pg_num  = NRF_FICR->CODESIZE - 1;  // Use last page in flash
while (true)
    // Start address:
    addr = (uint32_t *)(pg_size * pg_num);
    // Erase page:
    flash_page_erase(addr);
    i = 0;
    while (1)
					nrf_delay_ms(1000);
				// Read pattern from port 0 (pins0-7), and write it to flash:
        patwr =  nrf_gpio_port_read(NRF_GPIO_PORT_SELECT_PORT0);
            flash_word_write(addr, (uint32_t)patwr);
        // Read pattern from flash and write it to port 1 (pins8-15):
        patrd = (uint8_t)*addr;
        nrf_gpio_port_write(NRF_GPIO_PORT_SELECT_PORT1, patrd);
