Advertise Configuration of manufacturer specific data
I want to configure 32bytes sensor measurement data in advertise manufacturer specific data as follows.
But does not work, please help me.
My environment as follows.
SDK 17.0.2
nRF52832
Edit advertising_init() of the "nRF5_SDK_17.0.2\examples\ble_peripheral\ble_app_proximity"
    ret_code_t             err_code;
    ble_advertising_init_t init;
    // Configuration of manufacturer specific data ----------------------
	ble_advdata_manuf_data_t manuf_data; //Variable to hold manufacturer specific data
	uint8_t data[] ="01234567890123456789012345678901";
	manuf_data.company_identifier = 0xFFFF;
	manuf_data.data.p_data = data;
	manuf_data.data.size = sizeof(data);
	init.advdata.p_manuf_specific_data = &manuf_data;
	NRF_LOG_INFO("Size of manufacturer specific data: %d", manuf_data.data.size);
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
Post
  • The max length is 31 bytes, 32 is not an option. Have a look at my answer here for an explanation length-error-with-this-advertisement
  • Thank you for quick reply.
    I found following information "Extended Advertising support", why I can extend manufacturer specific data size?
    infocenter.nordicsemi.com/index.jsp
    S132 SoftDevice Specification
    Key features
    • Advertising and scanning up to 255 bytes of advertising data in an advertising event
  • Ah, maybe have a look at .\examples\ble_peripheral\ble_app_rscs I seem to recall that project uses extended advertising. Otherwise someone from Nordic pitch in here?
  • Hi there
    Indeed, the Running Speed and Cadence application does include extended advertising, so you can use the advertising_init() function there as reference when setting up your advertiser. From a first glance, it doesn't seem like you have included init.config.ble_adv_extended_enabled = true; to your advertising init function. I would also suggest setting the advertising data flags to BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE to put it in General Discoverable Mode when using extended advertising.
    Simon
  • Hi Simonr-san,
    Thank you for your sound advice.
    Following code work fine using ble_app_proximity sample code.
    //                            1         2         3         4         5         6
    	uint8_t data[] ="01234567890123456789012345678901234567890123456789012345678901";
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
