NUS central example can't send more than 4 packets of 244 Bytes
Hi everybody,
I have some trouble fixing the ERROR 19 [NRF_ERROR_RESOURCES]. I think it's something about the buffer queue size that is too busy. But I don't know how to fix it because most of the resolution on that matter was on the peripheral side with BLE_GATTS_EVT_HVN_TX_COMPLETE but it's a server whereas on the central side it's a client.
So I think I can't solve my problem with BLE_GATTS_EVT_HVN_TX_COMPLETE or I misunderstood something.
If you could enlighten me on that matter or give me some solutions. It would be great.
Some informations that might be useful :
NRF_SDH_BLE_GAP_EVENT_LENGTH is 320
NRF_SDH_BLE_GAP_DATA_LENGTH is 251
NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE 1408
// Where I send my 244 Bytes data
    static uint16_t index = 0;
	static uint32_t ret_val;
    static uint16_t length = 244;
	static uint8_t j;
	static uint8_t send_data[BLE_NUS_MAX_DATA_LEN];
	for (uint8_t i=0; i<length; i++)
		send_data[i]=i;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            if (//(data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= (m_ble_nus_max_data_len)))
                NRF_LOG_INFO("Ready to send data over BLE NUS");
                NRF_LOG_HEXDUMP_INFO(data_array, index);
                do
					if (index % 4 != 0 || index > 4)
						for (int i=0;i<10;i++)
								ret_val = ble_nus_c_string_send(&m_ble_nus_c, send_data, length);
                    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) &&
						(ret_val != NRF_ERROR_NOT_FOUND))
                        APP_ERROR_CHECK(ret_val);
                } while (ret_val == NRF_ERROR_RESOURCES);
                index = 0;
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
Best Regards,
