How BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE event works ?
I was testing the BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE event and I did trigger the event but i was wondering if that it's normal that It triggers after I send all my packets instead of triggering after one packet.
That's my logs :
<info> app: packet sent
<info> app: Buffer empty
For information the version of my SDK is nRF5_SDK_17.0.2_d674dde
And I put the event in the void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context)
Here is my code :
    static uint16_t index = 0;
    uint32_t ret_val;
	static uint16_t length = 120;
	static uint8_t send_data[BLE_NUS_MAX_DATA_LEN];
    for (uint8_t i=0; i<length; i++)
		send_data[i]=i;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            if (//(data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= (m_ble_nus_max_data_len)))
                NRF_LOG_INFO("Ready to send data over BLE NUS");
                NRF_LOG_HEXDUMP_INFO(data_array, index);
                do
					for (uint8_t i; i<4; i++)
						if (ret_val == NRF_ERROR_RESOURCES)
							buf_busy = true;
						if(buf_busy == false)
							ret_val = ble_nus_c_string_send(&m_ble_nus_c, send_data, length);
							NRF_LOG_INFO("packet sent");
                    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                        APP_ERROR_CHECK(ret_val);
                } while (ret_val == NRF_ERROR_RESOURCES);
                index = 0;
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    ret_code_t            err_code;
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_CONNECTED:
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
            // start discovery of services. The NUS Client waits for a discovery result
            err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
            NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                         p_gap_evt->conn_handle,
                         p_gap_evt->params.disconnected.reason);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
            // Pairing not supported.
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
            NRF_LOG_INFO("PHY update request.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
            NRF_LOG_INFO("GATT Client Timeout.");
        case BLE_GATTS_EVT_TIMEOUT:
            NRF_LOG_INFO("GATT Server Timeout.");
		case BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE:
			NRF_LOG_INFO("Buffer empty");
			buf_busy = false;
