Hello Nordic Community,
I am currently following the SMP guide provided here: https://docs.zephyrproject.org/latest/samples/subsys/mgmt/mcumgr/smp_svr/README.html
The examples are oriented towards the nrf52 boards, but I am currently working with the nrf5340_pdfk which contains the two cores (app and net). I was successfully able to build the MCUBoot for the appcore and flash the appcore with the MCUBoot. It seems to be working with the hello world example.
*** Booting Zephyr OS build v2.4.0-ncs1-1-ga3a6410b55fa ***
[00:00:00.385,620] <inf> mcuboot: Starting bootloader
[00:00:00.391,815] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
[00:00:00.401,916] <inf> mcuboot: Boot source: none
[00:00:00.407,409] <inf> mcuboot: Swap type: none
[00:00:00.494,567] <inf> mcuboot: Bootloader chainload address offset: 0x10000
[00:00:00.502,410] <inf> mcuboot: Jumping to the first image slot
Hello World from Zephyr on nrf5340pdk_nrf5340_cpuapp!
I am able to successfully build the MCUBoot for the netcore utilizing the -b nrf5340pdk_nrf5340_cpunet during the west build procedure. But during the flash of the MCUBoot image to the flash area of the netcore, it says that the region is not empty, meaning the previous erase command was not successful. I have tried with nrfjprog --eraseall but this yields the same results with flash failing due to a non empty target address.
Possibly, the MCUBoot (and OTA DFU) is only possible for the main app core?
So is it possible to utilize mcumgr for the netcore on nrf5340?
If anyone could give more guidance on how to do MCUBoot and effectively the SMP/mcumgr/OTA DFU on the netapp core, it would be much appreciated.
Thank you for your support,
