Setting a watchpoint dynamically
I am trying to spot a bug in which some memory corruption is happening. I don't know in advance at which address the corruption will happen, as it happens in some circular buffer. Maybe something is wrongly reading an address referring to this buffer and then writing there. I don't know.
Anyhow, I have found some way to store in some global variable mem_corruption_address the  data memory address at which the corruption before it happens, just in case it would happen, and what I want to do it call some watch_corruption_enable function at some point before code section in which the corruption may happen and watch_corruption_disable after this code section.
So here is the code which I have written :
extern uint32_t const volatile* volatile mem_corruption_address;
uint32_t const volatile* volatile mem_corruption_address = NULL;
nrf_atomic_flag_t watch_corruption;
static void watch_corruption_set_watchpoint(void)
    if (watch_corruption) {
        DWT->COMP0     = (uintptr_t)mem_corruption_address;
        DWT->MASK0     = 0; // range = 1 × 32bit word.
        DWT->FUNCTION0 = (6<<0) // generate watch point debug event on WO match
            | (0<<7) // FUNCTION0.CYCMATCH == 0 for address comparison
            | (0<<8) // FUNCTIONn.DATAVMATCH == 0 for address comparison
            | (1<<5) // FUNCTIONn.EMITRANGE == 1 for trace packet generation
static void watch_corruption_reset_watchpoint(void)
    DWT->FUNCTION0 = 0;
void watch_corruption_enable(void)
    nrf_atomic_flag_set(&watch_corruption);
void watch_corruption_disable(void)
    if (nrf_atomic_flag_clear_fetch(&watch_corruption)) {
        watch_corruption_reset_watchpoint();
The watch_corruption_set_watchpoint is called after each valid writing to the potentially corrupted memory, so that a valid write won't trigger the watchpoint, and I am also sure that no subsequent valid writing can occur before watch_corruption_disable is called.
Now, I am debugging with the Segger JTracePro with Ozone IDE (so I compiled my FW with ENABLE_TRACE #define'd). My hope was after the watchpoint is triggered I can browse back the instruction trace to find what made the corruption.
So, my problem is the following : instead of what I expected/hoped to get, I get Ozone more or less frozen at some point of time, I cannot stop the debugging session. I need to for the Ozone application stop from system. So, it seems that what I am doing it messing up how Ozone interfaces with the JTracePro.
I would like to know how to do it properly.
  • I tried to call NVIC_SetPendingIRQ(DebugMonitor_IRQn), both before starting FreeRTOS, and also after FreeRTOS is started, at the beginning of a thread function.
    In both cases, I cannot see the trace output of DebugMon_Handler happening, and the program goes past the call of NVIC_SetPendingIRQ(DebugMonitor_IRQn) without any effect of it, and continues what is next.
    Please note that in both cases, I had called
     NVIC_SetPriority(DebugMonitor_IRQn, _PRIO_SD_HIGH);
    NVIC_EnableIRQ(DebugMonitor_IRQn);
    at some point of time before calling NVIC_SetPendingIRQ(DebugMonitor_IRQn ).
  • FYI, I also had a look at the .elf.map file, and I can see that the DebugMon_Handler is there, and it is from the C source file where I typed it.
    So, the problem is not that another implementation of it is called by way of some erroneous linking.
  • Sorry, I forgot that you can only use the NVIC_EnableIRQ()/NVIC_SetPendingIRQ() CMSIS function for nRF specific interrupts (non-negative IRQ numbers), so that wasn't a good test.
    Can you try to use my code to see if the interrupt gets triggered then? I just tested it with the ble_app_hrs_freertos example in SDK 17.0.2:
    Modified main.c
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    // Board/nrf6310/ble/ble_app_hrs_rtx/main.c
     * @brief Heart Rate Service Sample Application with RTX main file.
     * This file contains the source code for a sample application using RTX and the
     * Heart Rate service (and also Battery and Device Information services).
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_bas.h"
    #include "ble_hrs.h"
    #include "ble_dis.h"
    #include "ble_conn_params.h"
    #include "sensorsim.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_freertos.h"
    #include "app_timer.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "bsp_btn_ble.h"
    #include "FreeRTOS.h"
    #include "task.h"
    #include "timers.h"
    #include "semphr.h"
    #include "fds.h"
    #include "ble_conn_state.h"
    #include "nrf_drv_clock.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME                         "Nordic_HRM"                            /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME                   "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_BLE_OBSERVER_PRIO               3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                    300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    #define APP_ADV_DURATION                    18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define BATTERY_LEVEL_MEAS_INTERVAL         2000                                    /**< Battery level measurement interval (ms). */
    #define MIN_BATTERY_LEVEL                   81                                      /**< Minimum simulated battery level. */
    #define MAX_BATTERY_LEVEL                   100                                     /**< Maximum simulated battery level. */
    #define BATTERY_LEVEL_INCREMENT             1                                       /**< Increment between each simulated battery level measurement. */
    #define HEART_RATE_MEAS_INTERVAL            1000                                    /**< Heart rate measurement interval (ms). */
    #define MIN_HEART_RATE                      140                                     /**< Minimum heart rate as returned by the simulated measurement function. */
    #define MAX_HEART_RATE                      300                                     /**< Maximum heart rate as returned by the simulated measurement function. */
    #define HEART_RATE_INCREMENT                10                                      /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
    #define RR_INTERVAL_INTERVAL                300                                     /**< RR interval interval (ms). */
    #define MIN_RR_INTERVAL                     100                                     /**< Minimum RR interval as returned by the simulated measurement function. */
    #define MAX_RR_INTERVAL                     500                                     /**< Maximum RR interval as returned by the simulated measurement function. */
    #define RR_INTERVAL_INCREMENT               1                                       /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
    #define SENSOR_CONTACT_DETECTED_INTERVAL    5000                                    /**< Sensor Contact Detected toggle interval (ms). */
    #define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
    #define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(650, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
    #define SLAVE_LATENCY                       0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY      5000                                    /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY       30000                                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT        3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                      0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                      0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
    #define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define OSTIMER_WAIT_FOR_QUEUE              2                                       /**< Number of ticks to wait for the timer queue to be ready */
    BLE_BAS_DEF(m_bas);                                                 /**< Battery service instance. */
    BLE_HRS_DEF(m_hrs);                                                 /**< Heart rate service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
    static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
    static bool     m_rr_interval_enabled = true;                       /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
    static sensorsim_cfg_t   m_battery_sim_cfg;                         /**< Battery Level sensor simulator configuration. */
    static sensorsim_state_t m_battery_sim_state;                       /**< Battery Level sensor simulator state. */
    static sensorsim_cfg_t   m_heart_rate_sim_cfg;                      /**< Heart Rate sensor simulator configuration. */
    static sensorsim_state_t m_heart_rate_sim_state;                    /**< Heart Rate sensor simulator state. */
    static sensorsim_cfg_t   m_rr_interval_sim_cfg;                     /**< RR Interval sensor simulator configuration. */
    static sensorsim_state_t m_rr_interval_sim_state;                   /**< RR Interval sensor simulator state. */
    static ble_uuid_t m_adv_uuids[] =                                   /**< Universally unique service identifiers. */
        {BLE_UUID_HEART_RATE_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    static TimerHandle_t m_battery_timer;                               /**< Definition of battery timer. */
    static TimerHandle_t m_heart_rate_timer;                            /**< Definition of heart rate timer. */
    static TimerHandle_t m_rr_interval_timer;                           /**< Definition of RR interval timer. */
    static TimerHandle_t m_sensor_contact_timer;                        /**< Definition of sensor contact detected timer. */
    #if NRF_LOG_ENABLED
    static TaskHandle_t m_logger_thread;                                /**< Definition of Logger thread. */
    #define STACK_LIMIT 0x2003e000
    void DebugMon_Handler(void)
        NRF_LOG_INFO("Debug Monitor interrupt triggered");
        NRF_LOG_INFO("Current SP 0x%x", __get_MSP());
        NRF_LOG_FINAL_FLUSH();
    static void dwt_stack_guard_init()
        uint32_t num;
        CoreDebug->DEMCR |= CoreDebug_DEMCR_TRCENA_Msk | CoreDebug_DEMCR_MON_EN_Msk;
        NRF_LOG_INFO("CoreDebug->DEMCR : 0x%x", CoreDebug->DEMCR);
        num = (DWT->CTRL & DWT_CTRL_NUMCOMP_Msk) >> DWT_CTRL_NUMCOMP_Pos;
        NRF_LOG_INFO("Number of DWT comparators: %d", num);
        NVIC_SetPriority(DebugMonitor_IRQn, 6);
        DWT->COMP0 = STACK_LIMIT;
        DWT->MASK0 = 4;
        DWT->FUNCTION0 = (7 << DWT_FUNCTION_FUNCTION_Pos);
        NRF_LOG_INFO("DWT->COMP0 : 0x%x", DWT->COMP0);
        NRF_LOG_INFO("DWT->MASK0 : 0x%x", DWT->MASK0);
        NRF_LOG_INFO("DWT->FUNCTION0 : 0x%x", DWT->FUNCTION0);
    static void advertising_start(void * p_erase_bonds);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in]   line_num   Line number of the failing ASSERT call.
     * @param[in]   file_name  File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        bool delete_bonds = false;
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                advertising_start(&delete_bonds);
    /**@brief Function for performing battery measurement and updating the Battery Level characteristic
     *        in Battery Service.
    static void battery_level_update(void)
        ret_code_t err_code;
        uint8_t  battery_level;
        battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
        err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
        if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
    /**@brief Function for handling the Battery measurement timer time-out.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in] xTimer Handler to the timer that called this function.
     *                   You may get identifier given to the function xTimerCreate using pvTimerGetTimerID.
    static void battery_level_meas_timeout_handler(TimerHandle_t xTimer)
        UNUSED_PARAMETER(xTimer);
        battery_level_update();
        *(uint32_t *) STACK_LIMIT = 1;
    /**@brief Function for handling the Heart rate measurement timer time-out.
     * @details This function will be called each time the heart rate measurement timer expires.
     *          It will exclude RR Interval data from every third measurement.
    static void heart_rate_meas_timeout_handler(TimerHandle_t xTimer)
        static uint32_t cnt = 0;
        uint16_t        heart_rate;
        heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
        cnt++;
        err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
        // Disable RR Interval recording every third heart rate measurement.
        // NOTE: An application will normally not do this. It is done here just for testing generation
        // of messages without RR Interval measurements.
        m_rr_interval_enabled = ((cnt % 3) != 0);
    /**@brief Function for handling the RR interval timer time-out.
     * @details This function will be called each time the RR interval timer expires.
    static void rr_interval_timeout_handler(TimerHandle_t xTimer)
        if (m_rr_interval_enabled)
            uint16_t rr_interval;
            rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
                                                      &m_rr_interval_sim_cfg);
            ble_hrs_rr_interval_add(&m_hrs, rr_interval);
    /**@brief Function for handling the Sensor Contact Detected timer time-out.
     * @details This function will be called each time the Sensor Contact Detected timer expires.
    static void sensor_contact_detected_timeout_handler(TimerHandle_t xTimer)
        static bool sensor_contact_detected = false;
        sensor_contact_detected = !sensor_contact_detected;
        ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        // Create timers.
        m_battery_timer = xTimerCreate("BATT",
                                       BATTERY_LEVEL_MEAS_INTERVAL,
                                       pdTRUE,
                                       NULL,
                                       battery_level_meas_timeout_handler);
        m_heart_rate_timer = xTimerCreate("HRT",
                                          HEART_RATE_MEAS_INTERVAL,
                                          pdTRUE,
                                          NULL,
                                          heart_rate_meas_timeout_handler);
        m_rr_interval_timer = xTimerCreate("RRT",
                                           RR_INTERVAL_INTERVAL,
                                           pdTRUE,
                                           NULL,
                                           rr_interval_timeout_handler);
        m_sensor_contact_timer = xTimerCreate("SCT",
                                              SENSOR_CONTACT_DETECTED_INTERVAL,
                                              pdTRUE,
                                              NULL,
                                              sensor_contact_detected_timeout_handler);
        /* Error checking */
        if ( (NULL == m_battery_timer)
             || (NULL == m_heart_rate_timer)
             || (NULL == m_rr_interval_timer)
             || (NULL == m_sensor_contact_timer) )
            APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
    /**@brief Function for initializing the GATT module. */
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        APP_ERROR_HANDLER(nrf_error);
     * @details Initialize the Heart Rate, Battery and Device Information services.
        ble_hrs_init_t     hrs_init;
        ble_bas_init_t     bas_init;
        ble_dis_init_t     dis_init;
        uint8_t            body_sensor_location;
        // Initialize Heart Rate Service.
        body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
        memset(&hrs_init, 0, sizeof(hrs_init));
        hrs_init.evt_handler                 = NULL;
        hrs_init.is_sensor_contact_supported = true;
        hrs_init.p_body_sensor_location      = &body_sensor_location;
        // Here the sec level for the Heart Rate Service can be changed/increased.
        hrs_init.hrm_cccd_wr_sec = SEC_OPEN;
        hrs_init.bsl_rd_sec      = SEC_OPEN;
        err_code = ble_hrs_init(&m_hrs, &hrs_init);
        // Initialize Battery Service.
        memset(&bas_init, 0, sizeof(bas_init));
        // Here the sec level for the Battery Service can be changed/increased.
        bas_init.bl_rd_sec        = SEC_OPEN;
        bas_init.bl_cccd_wr_sec   = SEC_OPEN;
        bas_init.bl_report_rd_sec = SEC_OPEN;
        bas_init.evt_handler          = NULL;
        bas_init.support_notification = true;
        bas_init.p_report_ref         = NULL;
        bas_init.initial_batt_level   = 100;
        err_code = ble_bas_init(&m_bas, &bas_init);
        // Initialize Device Information Service.
        memset(&dis_init, 0, sizeof(dis_init));
        ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
        dis_init.dis_char_rd_sec = SEC_OPEN;
        err_code = ble_dis_init(&dis_init);
    /**@brief Function for initializing the sensor simulators. */
    static void sensor_simulator_init(void)
        m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
        m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
        m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
        m_battery_sim_cfg.start_at_max = true;
        sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
        m_heart_rate_sim_cfg.min          = MIN_HEART_RATE;
        m_heart_rate_sim_cfg.max          = MAX_HEART_RATE;
        m_heart_rate_sim_cfg.incr         = HEART_RATE_INCREMENT;
        m_heart_rate_sim_cfg.start_at_max = false;
        sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
        m_rr_interval_sim_cfg.min          = MIN_RR_INTERVAL;
        m_rr_interval_sim_cfg.max          = MAX_RR_INTERVAL;
        m_rr_interval_sim_cfg.incr         = RR_INTERVAL_INCREMENT;
        m_rr_interval_sim_cfg.start_at_max = false;
        sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
    /**@brief   Function for starting application timers.
     * @details Timers are run after the scheduler has started.
    static void application_timers_start(void)
        // Start application timers.
        if (pdPASS != xTimerStart(m_battery_timer, OSTIMER_WAIT_FOR_QUEUE))
        if (pdPASS != xTimerStart(m_heart_rate_timer, OSTIMER_WAIT_FOR_QUEUE))
        if (pdPASS != xTimerStart(m_rr_interval_timer, OSTIMER_WAIT_FOR_QUEUE))
        if (pdPASS != xTimerStart(m_sensor_contact_timer, OSTIMER_WAIT_FOR_QUEUE))
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
     * @param[in]   p_evt   Event received from the Connection Parameters Module.
    /**@brief Function for handling a Connection Parameters error.
    /**@brief Function for initializing the Connection Parameters module. */
        cp_init.start_on_notify_cccd_handle    = m_hrs.hrm_handles.cccd_handle;
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
     * @param[in]   event   Event generated by button press.
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
            case BSP_EVENT_WHITELIST_OFF:
    /**@brief Function for the Peer Manager initialization. */
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage. */
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
    /**@brief Function for initializing the Advertising functionality. */
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    static void log_init(void)
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    /**@brief Function for starting advertising. */
        bool erase_bonds = *(bool*)p_erase_bonds;
        if (erase_bonds)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    #if NRF_LOG_ENABLED
    /**@brief Thread for handling the logger.
     * @details This thread is responsible for processing log entries if logs are deferred.
     *          Thread flushes all log entries and suspends. It is resumed by idle task hook.
     * @param[in]   arg   Pointer used for passing some arbitrary information (context) from the
     *                    osThreadCreate() call to the thread.
    static void logger_thread(void * arg)
        UNUSED_PARAMETER(arg);
        while (1)
            NRF_LOG_FLUSH();
            vTaskSuspend(NULL); // Suspend myself
    #endif //NRF_LOG_ENABLED
    /**@brief A function which is hooked to idle task.
     * @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
    void vApplicationIdleHook( void )
    #if NRF_LOG_ENABLED
         vTaskResume(m_logger_thread);
    /**@brief Function for initializing the clock.
    static void clock_init(void)
        ret_code_t err_code = nrf_drv_clock_init();
    /**@brief Function for application main entry.
        bool erase_bonds;
        // Initialize modules.
        log_init();
        clock_init();
        dwt_stack_guard_init();
        // Do not start any interrupt that uses system functions before system initialisation.
        // The best solution is to start the OS before any other initalisation.
    #if NRF_LOG_ENABLED
        // Start execution.
        if (pdPASS != xTaskCreate(logger_thread, "LOGGER", 256, NULL, 1, &m_logger_thread))
        // Activate deep sleep mode.
        SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
        // Configure and initialize the BLE stack.
        ble_stack_init();
        timers_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        sensor_simulator_init();
        conn_params_init();
        peer_manager_init();
        application_timers_start();
        // Create a FreeRTOS task for the BLE stack.
        // The task will run advertising_start() before entering its loop.
        nrf_sdh_freertos_init(advertising_start, &erase_bonds);
        NRF_LOG_INFO("HRS FreeRTOS example started.");
        // Start FreeRTOS scheduler.
        vTaskStartScheduler();
        for (;;)
            APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
    The interrupt is triggered by writing to the STACK_LIMIT address from the battery timer handler.
  • Hello ,
    Thank you for providing this code. I modified it too, in order to have some compile flags at the top of the main.c file and experiment a few variants as explained below.
    Here is the modified ble_app_hrs_freertos main.c file:
    #define DWT_GUARD_ENABLED 0
    #define NRF_LOG_BACKEND_RTT_ENABLED  0
    #define NRF_LOG_BACKEND_UART_ENABLED (!NRF_LOG_BACKEND_RTT_ENABLED)
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "ble.h"
    #include "task.h"
    #include "timers.h"
    #include "semphr.h"
    #include "fds.h"
    #if NRF_LOG_ENABLED
    #if DWT_GUARD_ENABLED
        uint32_t num;
        DWT->MASK0 = 4;
        cnt++;
        // Create timers.
                                       pdTRUE,
                                       NULL,
                                          pdTRUE,
                                          NULL,
                                           pdTRUE,
                                           NULL,
                                              pdTRUE,
                                              NULL,
        uint32_t err_code;
                sleep_mode_enter();
        uint32_t err_code;
            } break;
        switch (event)
                sleep_mode_enter();
        if (erase_bonds)
            delete_bonds();
    #if NRF_LOG_ENABLED
        while (1)
            NRF_LOG_FLUSH();
    #if NRF_LOG_ENABLED
        bool erase_bonds;
        log_init();
        clock_init();
    #if NRF_LOG_ENABLED
        // Start execution.
        ble_stack_init();
        timers_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
        for (;;)
    With this flag settings, this is the same compiled code as the original main.c file. I am using the ARM GCC compile chain and a PCA10056 DevKit, so I compile/flash it this way:
    cd pca10056/s140/armgcc
    make flash_softdevice flash
    And here is what I get in a terminal looking at the USB port:
    .<info> app: HRS FreeRTOS example started.
    <info> app: Fast advertising.
    So everything is wonderful like in the original example. Now let us set the first rows like this:
    #define DWT_GUARD_ENABLED 1
    This is the same as your example, and I get this in a terminal:
    .<info> app: CoreDebug->DEMCR : 0x1010000
    <info> app: Number of DWT comparators: 4
    <info> app: DWT->COMP0 : 0x2003E000
    <info> app: DWT->MASK0 : 0x4
    <info> app: DWT->FUNCTION0 : 0x7
    <info> app: Debug Monitor interrupt triggered
    <info> app: Current SP 0x2003FFD8
    One comment: to get it working a soft reset through SWD (like nrfjprog --reset) is not sufficient, a HW reset is needed !
    Now, I change again the two first lines of the main.c like this:
    #define NRF_LOG_BACKEND_RTT_ENABLED  1
    which means that I fallback to the original example, but with RTT log backend rather than UART. I compile and try it like this:
    make flash && JLinkRTTLogger -Device nrf52840_XXAA -If SWD -Speed 4000 -RTTCHannel 0 /dev/stdout
    It compiles without error, but there is not output. Frankly speaking this is the first time I am trying to use the PCA10056 with RTT logging. Does it mean that the PCA10056 does not contain a full Jlink implementation, but only some reduced set that allows flashing, but not RTT logging ?
    FYI, the reason why I am trying to set a dynamic watchpoint is to find out some bug on our product custom board. On this board we use only the RTT logging. So w/o RTT logging I won't be able to use your suggestion.
    Our using the UART backend is in principle possible, but that would require instrumenting our product board, and developing a new adaptation board for the JLink, so this is not a preferred way at this moment.
  • I think the problem is that the JLinkRTTLogger makes the J-link connect to the 52840 and override/reset  the DWT registers settings set by your FW. Can you try to connect the  JlinkRTTViewer/client after the interrupt has been triggered?
