Setting a watchpoint dynamically
I am trying to spot a bug in which some memory corruption is happening. I don't know in advance at which address the corruption will happen, as it happens in some circular buffer. Maybe something is wrongly reading an address referring to this buffer and then writing there. I don't know.
Anyhow, I have found some way to store in some global variable mem_corruption_address the  data memory address at which the corruption before it happens, just in case it would happen, and what I want to do it call some watch_corruption_enable function at some point before code section in which the corruption may happen and watch_corruption_disable after this code section.
So here is the code which I have written :
extern uint32_t const volatile* volatile mem_corruption_address;
uint32_t const volatile* volatile mem_corruption_address = NULL;
nrf_atomic_flag_t watch_corruption;
static void watch_corruption_set_watchpoint(void)
    if (watch_corruption) {
        DWT->COMP0     = (uintptr_t)mem_corruption_address;
        DWT->MASK0     = 0; // range = 1 × 32bit word.
        DWT->FUNCTION0 = (6<<0) // generate watch point debug event on WO match
            | (0<<7) // FUNCTION0.CYCMATCH == 0 for address comparison
            | (0<<8) // FUNCTIONn.DATAVMATCH == 0 for address comparison
            | (1<<5) // FUNCTIONn.EMITRANGE == 1 for trace packet generation
static void watch_corruption_reset_watchpoint(void)
    DWT->FUNCTION0 = 0;
void watch_corruption_enable(void)
    nrf_atomic_flag_set(&watch_corruption);
void watch_corruption_disable(void)
    if (nrf_atomic_flag_clear_fetch(&watch_corruption)) {
        watch_corruption_reset_watchpoint();
The watch_corruption_set_watchpoint is called after each valid writing to the potentially corrupted memory, so that a valid write won't trigger the watchpoint, and I am also sure that no subsequent valid writing can occur before watch_corruption_disable is called.
Now, I am debugging with the Segger JTracePro with Ozone IDE (so I compiled my FW with ENABLE_TRACE #define'd). My hope was after the watchpoint is triggered I can browse back the instruction trace to find what made the corruption.
So, my problem is the following : instead of what I expected/hoped to get, I get Ozone more or less frozen at some point of time, I cannot stop the debugging session. I need to for the Ozone application stop from system. So, it seems that what I am doing it messing up how Ozone interfaces with the JTracePro.
I would like to know how to do it properly.
  • Dear ,
    I did a test as you recommended, with flashing a LED on a regular basis.
    And at some point the program writes to the address watched out by DWT (like *(uint32_t*)STACK_LIMIT in your example).
    So, I launched the RTTlogger only after seeing the LED flash stopping, and it worked as expected, I got the log trace done by DebugMon_Handler.
    What is more interesting : I exited the RTTlogger, and then connected gdb, and it also worked, I could see the stack frame with DebugMon_Handler on the top of it.
    So, OK, good to know that with the RTTlogger, your method works fine provided that some caution is taken not to connect the Jlink before the break occurs.
    So one needs some other signal (like a LED or some GPO to a scope) that lets you know that you are still running and the break is not yet reached.
