USB event is not triggered every time a data array is being received
I am testing the USB CDC with nrf52840  and  I want to receive a predefined array of bytes over USB serial every time I send a specific array of bytes.
Just a simple data transmission from PC to nrf52840 and back. Nothing special
For instance, when I send 0x01 0x93 0x01 (command) through the terminal app (docklight) I want to receive 0x01 0x93 0x00 0x00 0x01 ( or whatever I have defined as answer).
The problem is that when I send the command continuously, every four times, I do not get back the answer from the nrf52840.
Also, I noticed that the event handler is not executed the times I get no response to the command I send
When I use another serial terminal app (terminal by Br@y++)  everything works fine and I get answer every time. So I am a little confused since serial configuration is the same for both terminal applications
Here is an image of  Tx and Rx data every time I send the command with docklight terminal ( the one with the issue)
and here is the code  for cdc_acm_event_handler and main () parts
 * @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t (headphones)
static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                    app_usbd_cdc_acm_user_event_t event)
    app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
    switch (event)
        case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:   // edw bainei molis anoixeis to serial port
            //bsp_board_led_on(LED_CDC_ACM_OPEN);
            devConnected = true;
            /*Setup first transfer*/
            ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
                                                   m_rx_buffer,
                                                   READ_SIZE);
            UNUSED_VARIABLE(ret);
        case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:  // edw bainei molis kleiseis to serial port
            //bsp_board_led_off(LED_CDC_ACM_OPEN);
            devConnected = false;
        case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:  // edw bainei molis oloklhrw8ei mia apostolh data
            //bsp_board_led_invert(LED_CDC_ACM_TX);
             usbd_tx_complete = true;
        case APP_USBD_CDC_ACM_USER_EVT_RX_DONE: // edw bainei molis oloklhrw8ei mia lhpsh data
            ret_code_t ret;
            NRF_LOG_INFO("Bytes waiting: %d", app_usbd_cdc_acm_bytes_stored(p_cdc_acm));
            do
                /*Get amount of data transfered*/
                size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
                NRF_LOG_INFO("RX: size: %lu char: %c", size, m_rx_buffer[0]);
                /* Fetch data until internal buffer is empty */
                                            m_rx_buffer,
                                            READ_SIZE);
            } while (ret == NRF_SUCCESS);
            usbd_rx_complete = true;
            // bsp_board_led_invert(LED_CDC_ACM_RX);
//--------------------main code-----------------
 while(1)
            while (app_usbd_event_queue_process());
            if( usbd_rx_complete == true)
                m_tx_buffer[0] = 0x01;
                m_tx_buffer[1] = 0x93;
                m_tx_buffer[2] = 0x00;
                m_tx_buffer[3] = 0x00;
                m_tx_buffer[4] = 0x01;
                err_code = app_usbd_cdc_acm_write(&m_app_cdc_acm, m_tx_buffer, 5);
                while (app_usbd_event_queue_process()); // wait while event process is complete
                usbd_rx_complete = false;
                RED_INV;
                usbd_tx_complete = false;
//                nrf_delay_ms(50);
             //nrf_delay_ms(20); BLUE_INV;
             NRF_WDT->RR[0] = WDT_RR_RR_Reload;  // refresh watchdog
Is there something that I have not taken into account?
Thank you for your time
