I'm designing a EEPROM type of memory using a SDCard. The write and read functions works fine, but the initialization does not work sometimes and it stays in a loop (because of the way the event handler is working). I'm using the 12.3 version of the SDK and the nRF51822. Does anybodi know how to fix it? I've already tried in different Cards, but the error is the same.
#include "lk_types.h"
#include "lk_board_lk2.h"
#include "lk_gpio.h"
#include "lk_eeprom.h"
#include "lk_sd_card.h"
#include "lk_errors.h"
#include <stdlib.h>
#include "app_sdcard.h"
#include "lk_millis.h"
#include <string.h>
#include "nrf_drv_spi.h"
// #include "lk_eeprom_sdc.h"
#if defined DEBUG_MSG_SD_CARD
#include "lk_printf.h"
#include "lk_test_sd_card.h"
#if defined LK_TEST_EEPROM
#include <stdlib.h>
#define SDC_SCK_PIN 2 ///< SDC serial clock (SCK) pin.
#define SDC_MOSI_PIN 3 ///< SDC serial data in (DI) pin.
#define SDC_MISO_PIN 4 ///< SDC serial data out (DO) pin.
#define SDC_CS_PIN 30 ///< SDC chip select (CS) pin.
static const app_sdc_config_t sdc_cfg = {
.mosi_pin = SDC_MOSI_PIN,
.miso_pin = SDC_MISO_PIN,
.sck_pin = SDC_SCK_PIN,
.cs_pin = SDC_CS_PIN
#define SIZE_BLOCK 512
uint32_t last_block= 0xFFFFFFFF;
uint8_t last_block_buff[SIZE_BLOCK];
volatile uint8_t lk_flag = 0;
void sdc_handler(sdc_evt_t const * p_event)
switch(p_event->type)
case SDC_EVT_INIT:
if (p_event->result != SDC_SUCCESS)
lk_flag = 0;
lk_flag = 1;
case SDC_EVT_READ:
// lk_printf("Event read result: %u", p_event->result);
/* Read successful. */
default: break;
return;
static bool _lk_initialized = false;
uint8_t flag_sdc = 0;
static uint8_t lk_check_sdc (void)
uint16_t timeout = 0xFFFF;
while(app_sdc_busy_check() && --timeout);
if (timeout != 0)
return 0;
flag_sdc = 1;
return 1;
uint32_t lk_eeprom_init(void){
lk_printf("lk_eeprom_sdc_init\n");
flag_sdc = 0;
uint32_t timeout = 0xFFFF;
uint16_t count_init = 0;
while(!lk_flag)
timeout = 0xFFFF;
app_sdc_init(&sdc_cfg, sdc_handler);
count_init++;
lk_printf("Iteracoes: %u\n", count_init);
while (!lk_flag && --timeout);
lk_printf("Init counter: %u\n", count_init);
return 0;
uint32_t lk_eeprom_write_byte(uint16_t Address, uint8_t data){
lk_printf("lk_eeprom_write_sdc_byte\n");
uint32_t lk_error = app_sdc_block_write(&data, Address, 1);
return lk_error;
uint32_t lk_eeprom_read_byte(uint16_t Address, uint8_t *data){
lk_printf("lk_eeprom_read_sdc_byte\n");
uint32_t lk_error = app_sdc_block_read(data, Address, 1);
return lk_error;
uint32_t lk_eeprom_write_page(uint16_t Address, uint8_t* pData, uint8_t size)
// lk_printf("lk_eeprom_write_sdc_page\n");
// lk_printf("Flag: %i\n", flag_sdc);
if (flag_sdc == 1)
return LK_EEPROM_SDC_CARD_NOT_FOUND;
uint16_t block_address = Address % 512;
uint32_t block = Address/512;
uint16_t aux1 = 512 - block_address;
uint8_t buff[512];
uint16_t i = 0;
uint16_t time_in, time_out;
uint32_t lk_error;
time_in = lk_millis_get();
//Read the first block
lk_check_sdc();
lk_error = app_sdc_block_read(buff, block, 1);
if (lk_error != LK_SUCCESS)
return lk_error;
if (size > aux1)
// Save the first block bytes at the buffer
uint16_t aux2 = size - aux1;
for (i = 0; i < aux1;i++)
buff[block_address + i] = pData[i];
// Write the first block
lk_check_sdc();
lk_error = app_sdc_block_write(buff, block, 1);
return lk_error;
lk_check_sdc();
lk_error = app_sdc_block_read(last_block_buff, block, 1);
if ((memcmp(buff, last_block_buff, SIZE_BLOCK)) != 0)
return LK_EEPROM_SDC_WRITE_ERROR;
// Read second block
lk_check_sdc();
lk_error = app_sdc_block_read(buff, (block+1), 1);
return lk_error;
// Save the second block bytes at the buffer
for (i = 0; i < aux2; i++)
buff[i] = pData[aux1 + i];
// Write the second block
lk_check_sdc();
lk_error = app_sdc_block_write(buff, block+1, 1);
return lk_error;
lk_check_sdc();
lk_error = app_sdc_block_read(last_block_buff, block+1, 1);
last_block = block+1;
memcpy(last_block_buff, buff, sizeof(buff));
time_out = lk_millis_get();
// Save the block bytes at the buffer
for (i = 0; i < size; i++)
// Write the block
lk_check_sdc();
return lk_error;
lk_check_sdc();
last_block = block;
uint32_t time = time_out-time_in;
// lk_printf("Time: %lu\n", time);
return LK_SUCCESS;
uint32_t lk_eeprom_read_page(uint16_t Address, uint8_t* pData, uint8_t size){
// lk_printf("lk_eeprom_read_sdc_page\n");
if (flag_sdc == 1)
uint32_t lk_error;
uint16_t i = 0;
if (block == last_block)
// memcpy(buff, last_block_buff, sizeof(buff));
lk_check_sdc();
// lk_check_sdc();
return lk_error;
// memcpy(last_block_buff, buff, sizeof(buff));
if (size > aux1)
// Save the first block bytes at output
pData[i] = last_block_buff[block_address + i];
lk_check_sdc();
lk_error = app_sdc_block_read(last_block_buff, (block+1), 1);
// lk_check_sdc();
return lk_error;
// Save the second block bytes at the output
pData[aux1 + i] = last_block_buff[i];
last_block = block;
return LK_SUCCESS;
