nrf5340 mcuboot build pm_config.h not found
Hello Nordicsemi community,
1) manual build of mcuboot - When trying to build the mcuboot for nrf5340 via the mcuboot/samples/zephyr via the west build command, the build fails with a missing header file pm_config.h.
It seems related to the pcd dfu.
[1/251] Preparing syscall dependency handling
[32/251] Building C object CMakeFiles/app.dir/main.c.obj
FAILED: CMakeFiles/app.dir/main.c.obj
ccache /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.4.0-ncs1-1711-g6bc4a6cda158 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"mcuboot-mbedtls-cfg.h\" -DNRF5340_XXAA_APPLICATION -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I../include -I../targets -I/opt/nrf/bootloader/mcuboot/boot/bootutil/include -I/opt/nrf/zephyr/include -Izephyr/include/generated -I/opt/nrf/zephyr/soc/arm/nordic_nrf/nrf53 -I/opt/nrf/nrf/include -I/opt/nrf/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nrf/modules/hal/nordic/nrfx -I/opt/nrf/modules/hal/nordic/nrfx/drivers/include -I/opt/nrf/modules/hal/nordic/nrfx/mdk -I/opt/nrf/modules/hal/nordic/. -I/opt/nrf/modules/crypto/mbedtls/include -I/opt/nrf/modules/crypto/mbedtls/configs -isystem /opt/nrf/zephyr/lib/libc/minimal/include -isystem /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem /opt/nrf/nrfxlib/crypto/nrf_cc312_platform/include -Og -imacros /opt/nrf/bootloader/mcuboot/boot/zephyr/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m33 -mthumb -mabi=aapcs -imacros /opt/nrf/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/opt/nrf/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nrf/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nrf=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/main.c.obj -MF CMakeFiles/app.dir/main.c.obj.d -o CMakeFiles/app.dir/main.c.obj -c ../main.c
In file included from ../main.c:57:
/opt/nrf/nrf/include/dfu/pcd.h:35:10: fatal error: pm_config.h: No such file or directory
   35 | #include <pm_config.h>
compilation terminated.
[39/251] Building C object CMakeFiles/app.dir/opt/nrf/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
FAILED: CMakeFiles/app.dir/opt/nrf/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
ccache /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.4.0-ncs1-1711-g6bc4a6cda158 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"mcuboot-mbedtls-cfg.h\" -DNRF5340_XXAA_APPLICATION -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I../include -I../targets -I/opt/nrf/bootloader/mcuboot/boot/bootutil/include -I/opt/nrf/zephyr/include -Izephyr/include/generated -I/opt/nrf/zephyr/soc/arm/nordic_nrf/nrf53 -I/opt/nrf/nrf/include -I/opt/nrf/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nrf/modules/hal/nordic/nrfx -I/opt/nrf/modules/hal/nordic/nrfx/drivers/include -I/opt/nrf/modules/hal/nordic/nrfx/mdk -I/opt/nrf/modules/hal/nordic/. -I/opt/nrf/modules/crypto/mbedtls/include -I/opt/nrf/modules/crypto/mbedtls/configs -isystem /opt/nrf/zephyr/lib/libc/minimal/include -isystem /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem /opt/nrf/nrfxlib/crypto/nrf_cc312_platform/include -Og -imacros /opt/nrf/bootloader/mcuboot/boot/zephyr/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m33 -mthumb -mabi=aapcs -imacros /opt/nrf/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/opt/nrf/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nrf/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nrf=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/opt/nrf/bootloader/mcuboot/boot/bootutil/src/loader.c.obj -MF CMakeFiles/app.dir/opt/nrf/bootloader/mcuboot/boot/bootutil/src/loader.c.obj.d -o CMakeFiles/app.dir/opt/nrf/bootloader/mcuboot/boot/bootutil/src/loader.c.obj -c /opt/nrf/bootloader/mcuboot/boot/bootutil/src/loader.c
In file included from /opt/nrf/bootloader/mcuboot/boot/bootutil/src/loader.c:49:
[41/251] Building C object CMakeFiles/app.dir/opt/nrf/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
2) config enabled mcuboot - If I do not build the mcuboot manually and just enable the CONFIG_BOOTLOADER_MCUBOOT=y in a  sample projects prj.conf, the child image for mcuboot seems to build fine. After the flash, the app crashes, I either suspect the app image is not signed with the mcuboot root key, or the mcuboot image itself is incorrect.
=== child image mcuboot -  begin ===
Including boilerplate (Zephyr base): /opt/nrf/zephyr/cmake/app/boilerplate.cmake
-- Application: /opt/nrf/bootloader/mcuboot/boot/zephyr
-- Zephyr version: 2.4.99 (/opt/nrf/zephyr)
-- Found Python3: /usr/bin/python3.6 (found suitable exact version "3.6.9") found components: Interpreter
-- Found west (found suitable version "0.8.0", minimum required is "0.7.1")
-- Board: nrf5340pdk_nrf5340_cpuapp
-- Cache files will be written to: /root/.cache/zephyr
CMake Warning at /opt/nrf/zephyr/cmake/host-tools.cmake:31 (message):
  Could NOT find dtc: Found unsuitable version "1.4.5", but required is at
  least "1.4.6" (found /usr/bin/dtc).  Optional devicetree error checking
  with dtc will not be performed.
  /opt/nrf/zephyr/cmake/app/boilerplate.cmake:570 (include)
  /opt/nrf/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
  /opt/nrf/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
  CMakeLists.txt:44 (find_package)
-- Found toolchain: gnuarmemb (/opt/gcc-arm-none-eabi-9-2019-q4-major)
-- Found BOARD.dts: /opt/nrf/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340pdk_nrf5340_cpuapp.dts
-- Found devicetree overlay: /opt/nrf/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: /tmp/my_zephyr_app/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /tmp/my_zephyr_app/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
Parsing /opt/nrf/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration '/opt/nrf/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340pdk_nrf5340_cpuapp_defconfig'
Merged configuration '/opt/nrf/bootloader/mcuboot/boot/zephyr/prj.conf'
Configuration saved to '/tmp/my_zephyr_app/build/mcuboot/zephyr/.config'
Kconfig header saved to '/tmp/my_zephyr_app/build/mcuboot/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-gcc
CMake Warning at /opt/nrf/zephyr/kernel/CMakeLists.txt:54 (message):
  Single threaded mode (CONFIG_MULTITHREADING=n) is deprecated
CMake Warning at /opt/nrf/zephyr/CMakeLists.txt:1354 (message):
        WARNING:  The board 'nrf5340pdk_nrf5340_cpuapp' is deprecated and will be
        removed in version v2.6.0
MCUBoot bootloader key file: /opt/nrf/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: /tmp/my_zephyr_app/build/mcuboot
=== child image mcuboot -  end ===
CMake Warning at /opt/nrf/nrf/cmake/mcuboot.cmake:120 (message):
        --- WARNING: Using default MCUBoot key, it should not ---
        --- be used for production.                           ---
  /opt/nrf/bootloader/mcuboot/zephyr/CMakeLists.txt:1 (include)
-- Build type:
-- Host:    Linux/x86_64
-- Target:  Generic/arm
-- Machine: cortexm
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- Machine: cortexm
-- C_FLAGS :  -Wall -Wextra
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
-- Configuring done
-- Generating done
[1/194] Preparing syscall dependency handling
[6/194] Performing build step for 'mcuboot_subimage'
[1/252] Preparing syscall dependency handling
[247/252] Linking C executable zephyr/zephyr_prebuilt.elf
           FLASH:       38228 B        48 KB     77.78%
            SRAM:       24144 B       504 KB      4.68%
        IDT_LIST:          72 B         2 KB      3.52%
[252/252] Linking C executable zephyr/zephyr.elf
[22/194] Building C object CMakeFiles/app.dir/src/main_thread_task.c.obj
[181/194] Linking C executable zephyr/zephyr_prebuilt.elf
           FLASH:       37508 B     491008 B      7.64%
            SRAM:       19336 B       504 KB      3.75%
        IDT_LIST:          88 B         2 KB      4.30%
[194/194] Generating zephyr/merged.hex
-- west flash: rebuilding
[0/1] cd /tmp/my_zephyr_app/build/zephyr/cmake/flash && /usr/local/bin/cmake -E echo
-- west flash: using runner nrfjprog
Using board 960164651
-- runners.nrfjprog: Flashing file: /tmp/my_zephyr_app/build/zephyr/merged.hex
-- runners.nrfjprog: Generating CP_APPLICATION hex file /tmp/my_zephyr_app/build/zephyr/GENERATED_CP_APPLICATION_merged.hex
Parsing hex file.
Erasing page at address 0x0.
Erasing page at address 0x1000.
Erasing page at address 0x2000.
Erasing page at address 0x3000.
Erasing page at address 0x4000.
Erasing page at address 0x5000.
Erasing page at address 0x6000.
Erasing page at address 0x7000.
Erasing page at address 0x8000.
Erasing page at address 0x9000.
Erasing page at address 0x10000.
Erasing page at address 0x11000.
Erasing page at address 0x12000.
Erasing page at address 0x13000.
Erasing page at address 0x14000.
Erasing page at address 0x15000.
Erasing page at address 0x16000.
Erasing page at address 0x17000.
Erasing page at address 0x18000.
Erasing page at address 0x19000.
Applying system reset.
Checking that the area to write is not protected.
Programming device.
Applying pin reset.
-- runners.nrfjprog: Board with serial number 960164651 flashed successfully.
*** Booting Zephyr OS build v2.4.0-ncs1-1711-g6bc4a6cda158  ***
[00:00:00.257,995] <err> fatal_error: Resetting system
Ideally I would like to be able to build the mcuboot manually and flash it onto the board prior to the primary image being flashed. (only building the mcuboot once)
Thank you for your support Face palm
  • More information and attempts.
    The version of MCUBoot I am utilizing is:
    root@molecule--vv-role-nrf-zephyr-dev:/opt/nrf/bootloader/mcuboot/boot# git remote -v
    ncs    github.com/.../sdk-mcuboot (fetch)
    ncs    github.com/.../sdk-mcuboot (push)
    commit 853e11283805ec66f157bc27a5286edb36046725 (HEAD, manifest-rev)
    Author: Torsten Rasmussen <[email protected]>
    Date:   Fri Nov 27 15:30:50 2020 +0100
        [nrf temphack]: remove CONFIG_DEBUG=y in Zephyr prj.conf
        This commit removes the `CONFIG_DEBUG=y` setting from Zephyr prj.conf
        to save <n>k flash size.
        Signed-off-by: Torsten Rasmussen <[email protected]>
    1) Attempt to build via make boot -DBOARD=<BOARDNAME> in samples/zephyr
    root@molecule--vv-role-nrf-zephyr-dev:/opt/nrf/bootloader/mcuboot/samples/zephyr# make boot BOARD=nrf5340pdk_nrf5340_cpuapp
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /opt/nrf/bootloader/mcuboot/samples/zephyr/build/nrf5340pdk_nrf5340_cpuapp/mcuboot
    [11/238] Building C object CMakeFiles/app.dir/main.c.obj
    ccache /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.4.0-ncs1-1711-g6bc4a6cda158 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"mcuboot-mbedtls-cfg.h\" -DNRF5340_XXAA_APPLICATION -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I/opt/nrf/bootloader/mcuboot/boot/zephyr/include -I/opt/nrf/bootloader/mcuboot/boot/zephyr/targets -I/opt/nrf/bootloader/mcuboot/boot/bootutil/include -I/opt/nrf/zephyr/include -Izephyr/include/generated -I/opt/nrf/zephyr/soc/arm/nordic_nrf/nrf53 -I/opt/nrf/nrf/include -I/opt/nrf/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nrf/modules/hal/nordic/nrfx -I/opt/nrf/modules/hal/nordic/nrfx/drivers/include -I/opt/nrf/modules/hal/nordic/nrfx/mdk -I/opt/nrf/modules/hal/nordic/. -I/opt/nrf/modules/crypto/mbedtls/include -I/opt/nrf/modules/crypto/mbedtls/configs -isystem /opt/nrf/zephyr/lib/libc/minimal/include -isystem /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem /opt/nrf/nrfxlib/crypto/nrf_cc312_platform/include -Os -imacros /opt/nrf/bootloader/mcuboot/samples/zephyr/build/nrf5340pdk_nrf5340_cpuapp/mcuboot/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m33 -mthumb -mabi=aapcs -imacros /opt/nrf/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/opt/nrf/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nrf/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nrf=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/main.c.obj -MF CMakeFiles/app.dir/main.c.obj.d -o CMakeFiles/app.dir/main.c.obj -c /opt/nrf/bootloader/mcuboot/boot/zephyr/main.c
    In file included from /opt/nrf/bootloader/mcuboot/boot/zephyr/main.c:59:
    [15/238] Building C object CMakeFiles/app.dir/opt/nrf/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    ccache /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.4.0-ncs1-1711-g6bc4a6cda158 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"mcuboot-mbedtls-cfg.h\" -DNRF5340_XXAA_APPLICATION -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I/opt/nrf/bootloader/mcuboot/boot/zephyr/include -I/opt/nrf/bootloader/mcuboot/boot/zephyr/targets -I/opt/nrf/bootloader/mcuboot/boot/bootutil/include -I/opt/nrf/zephyr/include -Izephyr/include/generated -I/opt/nrf/zephyr/soc/arm/nordic_nrf/nrf53 -I/opt/nrf/nrf/include -I/opt/nrf/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nrf/modules/hal/nordic/nrfx -I/opt/nrf/modules/hal/nordic/nrfx/drivers/include -I/opt/nrf/modules/hal/nordic/nrfx/mdk -I/opt/nrf/modules/hal/nordic/. -I/opt/nrf/modules/crypto/mbedtls/include -I/opt/nrf/modules/crypto/mbedtls/configs -isystem /opt/nrf/zephyr/lib/libc/minimal/include -isystem /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem /opt/nrf/nrfxlib/crypto/nrf_cc312_platform/include -Os -imacros /opt/nrf/bootloader/mcuboot/samples/zephyr/build/nrf5340pdk_nrf5340_cpuapp/mcuboot/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m33 -mthumb -mabi=aapcs -imacros /opt/nrf/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/opt/nrf/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nrf/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nrf=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/opt/nrf/bootloader/mcuboot/boot/bootutil/src/loader.c.obj -MF CMakeFiles/app.dir/opt/nrf/bootloader/mcuboot/boot/bootutil/src/loader.c.obj.d -o CMakeFiles/app.dir/opt/nrf/bootloader/mcuboot/boot/bootutil/src/loader.c.obj -c /opt/nrf/bootloader/mcuboot/boot/bootutil/src/loader.c
    [20/238] Building C object CMakeFiles/app.dir/opt/nrf/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
    Makefile:106: recipe for target 'boot' failed
    2) Attempt to build via cmake and ninja following these steps (minus the partition layout): https://github.com/mcu-tools/mcuboot/blob/master/docs/readme-zephyr.md
    root@molecule--vv-role-nrf-zephyr-dev:/opt/nrf/bootloader/mcuboot/boot/zephyr/build# cmake -GNinja -DBOARD=nrf5340pdk_nrf5340_cpuapp ..
    Including boilerplate (Zephyr base (cached)): /opt/nrf/zephyr/cmake/app/boilerplate.cmake
      /opt/nrf/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
    -- Generated zephyr.dts: /opt/nrf/bootloader/mcuboot/boot/zephyr/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /opt/nrf/bootloader/mcuboot/boot/zephyr/build/zephyr/include/generated/devicetree_unfixed.h
    Configuration saved to '/opt/nrf/bootloader/mcuboot/boot/zephyr/build/zephyr/.config'
    Kconfig header saved to '/opt/nrf/bootloader/mcuboot/boot/zephyr/build/zephyr/include/generated/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /opt/nrf/bootloader/mcuboot/boot/zephyr/build
    root@molecule--vv-role-nrf-zephyr-dev:/opt/nrf/bootloader/mcuboot/boot/zephyr/build# ninja
    [23/252] Building C object CMakeFiles/app.dir/main.c.obj
    ccache /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.4.0-ncs1-1711-g6bc4a6cda158 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"mcuboot-mbedtls-cfg.h\" -DNRF5340_XXAA_APPLICATION -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I../include -I../targets -I/opt/nrf/bootloader/mcuboot/boot/bootutil/include -I/opt/nrf/zephyr/include -Izephyr/include/generated -I/opt/nrf/zephyr/soc/arm/nordic_nrf/nrf53 -I/opt/nrf/nrf/include -I/opt/nrf/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nrf/modules/hal/nordic/nrfx -I/opt/nrf/modules/hal/nordic/nrfx/drivers/include -I/opt/nrf/modules/hal/nordic/nrfx/mdk -I/opt/nrf/modules/hal/nordic/. -I/opt/nrf/modules/crypto/mbedtls/include -I/opt/nrf/modules/crypto/mbedtls/configs -isystem /opt/nrf/zephyr/lib/libc/minimal/include -isystem /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem /opt/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem /opt/nrf/nrfxlib/crypto/nrf_cc312_platform/include -Os -imacros /opt/nrf/bootloader/mcuboot/boot/zephyr/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m33 -mthumb -mabi=aapcs -imacros /opt/nrf/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/opt/nrf/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nrf/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nrf=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/main.c.obj -MF CMakeFiles/app.dir/main.c.obj.d -o CMakeFiles/app.dir/main.c.obj -c ../main.c
    In file included from ../main.c:59:
    [32/252] Building C object CMakeFiles/app.dir/opt/nrf/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    I can confirm that if you try to configure and build mcuboot standalone, you will get this error with the nrf5340*dk_nrf5340_* boards.
    Thank you very much for making us aware of this issue, and I've made our R&D department aware of this issue. It seems that we're missing some #if guards in the scenario where mcuboot is built standalone for this specific board.
    The workaround for now is to use multi-build.
    Håkon
  • Hello On3,
    did you figure out how to solve this problem ?
  • Hi Håkon,
    Do you know if there has been any progress on solving this issue? I'm currently using NCS v1.5.1 and I see the same that was reported by On3.
    Thanks in advance.
    Unfortunately, this is not yet fixed. This PR should address this issue in the future:
    https://github.com/nrfconnect/sdk-mcuboot/pull/157
    Håkon
